[GeoNode-users] GeoNode 2.6.x installation problem
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed May 24 06:27:08 PDT 2017
That's quite strange. I need to debug the issue. It will take some time,
please be patient.
On May 24, 2017 10:55, "Rasika Chinchwade" <rasikachinchwade31 at gmail.com>
wrote:
> thank you so much for your answer.
> After trying on 3/4 times I have been able to install the geonode 2.6.x on
> windows 10.In installation out of 8 layers 7 was successfully created.
> Now, the problem that I am facing is while making *a map with exiting
> layers or with new map creation.The problem is*
> [Wed May 24 14:15:00.538469 2017] [wsgi:error] [pid 4652:tid 2704]
> Internal Server Error: /maps/new/data
> Traceback (most recent call last):
> [Wed May 24 14:15:00.538469 2017] [wsgi:error] [pid 4652:tid 2704]   File
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\
> django\\core\\handlers\\base.py", line 132, in get_response
> response = wrapped_callback(request, *callback_args, **callback_kwargs)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\maps\\views.py", line 501, in
> new_map_json
> map_obj.save()
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\polymorphic\\models.py",
> line 72, in save
> return super(PolymorphicModel, self).save(*args, **kwargs)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\db\\models\\base.py",
> line 734, in save
> force_update=force_update, update_fields=update_fields)
> line 771, in save_base
> update_fields=update_fields, raw=raw, using=using)
> django\\dispatch\\dispatcher.py", line 189, in send
> response = receiver(signal=self, sender=sender, **named)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\geoserver\\signals.py", line
> 490, in geoserver_post_save_map
> create_gs_thumbnail(instance, overwrite=True)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\geoserver\\helpers.py", line
> 1820, in create_gs_thumbnail
> ogc_client=http_client, overwrite=overwrite, check_bbox=check_bbox)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\layers\\utils.py", line 721,
> in create_thumbnail
> resp, image = ogc_client.request(thumbnail_create_url)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\httplib2\\__init__.py",
> line 1659, in request
> (response, content) = self._request(conn, authority, uri, request_uri,
> method, body, headers, redirections, cachekey)
> line 1399, in _request
> (response, content) = self._conn_request(conn, request_uri, method, body,
> headers)
> line 1355, in _conn_request
> response = conn.getresponse()
> "C:\\GeoNode-2.6.x\\Python27\\Lib\\httplib.py", line 1132, in getresponse
> response.begin()
> "C:\\GeoNode-2.6.x\\Python27\\Lib\\httplib.py", line 453, in begin
> version, status, reason = self._read_status()
> "C:\\GeoNode-2.6.x\\Python27\\Lib\\httplib.py", line 409, in _read_status
> line = self.fp.readline(_MAXLINE + 1)
> "C:\\GeoNode-2.6.x\\Python27\\Lib\\socket.py", line 480, in readline
> data = self._sock.recv(self._rbufsize)
> [Wed May 24 14:15:00.538469 2017] [wsgi:error] [pid 4652:tid 2704] error:
> [Errno 10053] An established connection was aborted by the software in your
> host machine
> [Wed May 24 14:15:25.184784 2017] [wsgi:error] [pid 4652:tid 2636]
> [Wed May 24 14:15:25.184784 2017] [wsgi:error] [pid 4652:tid 2636]   File
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\maps\\views.py", line 513, in
> new_map_json
> map_obj.update_from_viewer(body)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\maps\\models.py", line 197,
> in update_from_viewer
> MapLayer, layer, source_for(layer), ordering
> django\\db\\models\\fields\\related.py", line 750, in add
> obj.save()
> line 734, in save
> line 758, in save_base
> 485, in geoserver_pre_save_maplayer
> raise e
> [Wed May 24 14:15:25.184784 2017] [wsgi:error] [pid 4652:tid 2636] error:
> host machine
> What I have to need to do further to solve this problem.
> Thank you.
> On Wed, May 24, 2017 at 1:18 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Double check that the Tomcat service has been installed and has started
>> correctly.
>> It is recommended to run Windows executable on a system without previous
>> versions of Tomcat already installed on it.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> github <https://github.com/afabiani?tab=overview>
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <0584%20962313>
>> fax:     +39 0584 1660272 <0584%20166%200272>
>> mob:   +39 331 6233686 <331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Wed, May 24, 2017 at 9:06 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi I'm not expert of windows installations but from the erro I can tell
>>> you that geoserver is not responding on localhost:8080 or 127.0.0.1:8080.
>>> Check the geoserver installation.
>>> Hope this helps
>>> 2017-05-24 5:21 GMT+02:00 Rasika Chinchwade <
>>> rasikachinchwade31 at gmail.com>:
>>>> hello all,
>>>> whenever I tried to install GeoNode 2.6.x on windows 10 OS layer
>>>> creation gets failed.Also while uploading of layer or creating a new map
>>>> that is giving me erroe like:
>>>> 488] AH00354: Child: Starting 250 worker threads.
>>>> [Wed May 24 08:35:24.219358 2017] [proxy:error] [pid 2552:tid 2552] (OS
>>>> 10061)No connection could be made because the target machine actively
>>>> refused it.  : AH00957: HTTP: attempt to connect to 127.0.0.1:8080
>>>> (localhost) failed
>>>> AH00959: ap_proxy_connect_backend disabling worker for (localhost) for 60s
>>>> [Wed May 24 08:35:24.219358 2017] [proxy_http:error] [pid 2552:tid
>>>> 2552] [client ::1:52302] AH01114: HTTP: failed to make connection to
>>>> backend: localhost
>>>> [Wed May 24 08:44:00.415267 2017] [wsgi:error] [pid 2552:tid 2568]
>>>> [Errno 10061] No connection could be made because the target machine
>>>> actively refused it
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\layers\\views.py",
>>>> line 168, in layer_upload
>>>> metadata_uploaded_preserve=form.cleaned_data["metadata_uploa
>>>> ded_preserve"]
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\layers\\utils.py",
>>>> line 499, in file_upload
>>>> defaults=defaults
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\db\\models\\manager.py",
>>>> line 127, in manager_method
>>>> return getattr(self.get_queryset(), name)(*args, **kwargs)
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\modeltranslation\\manager.py",
>>>> line 389, in get_or_create
>>>> return super(MultilingualQuerySet, self).get_or_create(**kwargs)
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\db\\models\\query.py",
>>>> line 407, in get_or_create
>>>> return self._create_object_from_params(lookup, params)
>>>> line 439, in _create_object_from_params
>>>> obj = self.create(**params)
>>>> line 381, in create
>>>> return super(MultilingualQuerySet, self).create(**kwargs)
>>>> line 348, in create
>>>> obj.save(force_insert=True, using=self.db)
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\polymorphic\\models.py",
>>>> line 72, in save
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\db\\models\\base.py",
>>>> line 734, in save
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\dispatch\\dispatcher.py",
>>>> line 189, in send
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\geoserver\\signals.py",
>>>> line 93, in geoserver_pre_save
>>>> charset=instance.charset)
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\geoserver\\helpers.py",
>>>> line 1059, in geoserver_upload
>>>> workspace = cat.get_default_workspace()
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\geoserver\\catalog.py",
>>>> line 875, in get_default_workspace
>>>> ws.fetch()
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\geoserver\\support.py",
>>>> line 176, in fetch
>>>> self.dom = self.catalog.get_xml(self.href)
>>>> line 211, in get_xml
>>>> response, content = self.http.request(rest_url)
>>>> File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\httplib2\\__init__.py",
>>>> headers)
>>>> line 1319, in _conn_reques
>>>> line 958, in connect
>>>> raise socket.error, msg
>>>> error: [Errno 10061] No connection could be made because the target machine
>>>> actively refused it
>>>> [Wed May 24 08:44:16.567777 2017] [proxy:error] [pid 2552:tid 2568] (OS
>>>> (localhost) failed
>>>> [Wed May 24 08:44:16.567777 2017] [proxy_http:error] [pid 2552:tid
>>>> 2568] [client ::1:52793] AH01114: HTTP: failed to make connection to
>>>> backend: localhost, referer: http://localhost/maps/new
>>>> [Wed May 24 08:44:16.567777 2017] [proxy:error] [pid 2552:tid 2544] (OS
>>>> (localhost) failed
>>>> 2544] [client ::1:52795] AH01114: HTTP: failed to make connection to
>>>> [Wed May 24 08:44:30.040790 2017 <040%20790%202017>] [wsgi:error] [pid
>>>> 2552:tid 2568] Internal Server Error: /maps/new/data
>>>> 2552:tid 2568] Traceback (most recent call last):
>>>> 2552:tid 2568]   File "C:\\GeoNode-2.6.x\\geonode-2.
>>>> 6.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 132,
>>>> in get_response
>>>> 2552:tid 2568]     response = wrapped_callback(request, *callback_args,
>>>> **callback_kwargs)
>>>> 2552:tid 2568]   File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\maps\\views.py",
>>>> line 501, in new_map_json
>>>> 2552:tid 2568]     map_obj.save()
>>>> 6.x\\lib\\site-packages\\polymorphic\\models.py", line 72, in save
>>>> 2552:tid 2568]     return super(PolymorphicModel, self).save(*args,
>>>> **kwargs)
>>>> 6.x\\lib\\site-packages\\django\\db\\models\\base.py", line 734, in
>>>> save
>>>> 2552:tid 2568]     force_update=force_update, update_fields=update_fields)
>>>> 6.x\\lib\\site-packages\\django\\db\\models\\base.py", line 771, in
>>>> save_base
>>>> 2552:tid 2568]     update_fields=update_fields, raw=raw, using=using)
>>>> 6.x\\lib\\site-packages\\django\\dispatch\\dispatcher.py", line 189,
>>>> in send
>>>> 2552:tid 2568]     response = receiver(signal=self, sender=sender, **named)
>>>> 6.x\\geonode\\geoserver\\signals.py", line 490, in
>>>> 2552:tid 2568]     create_gs_thumbnail(instance, overwrite=True)
>>>> 6.x\\geonode\\geoserver\\helpers.py", line 1820, in create_gs_thumbnail
>>>> 2552:tid 2568]     ogc_client=http_client, overwrite=overwrite,
>>>> 6.x\\geonode\\layers\\utils.py", line 721, in create_thumbnail
>>>> 2552:tid 2568]     resp, image = ogc_client.request(thumbnail_c
>>>> reate_url)
>>>> 6.x\\lib\\site-packages\\httplib2\\__init__.py", line 1659, in request
>>>> 2552:tid 2568]     (response, content) = self._request(conn, authority,
>>>> uri, request_uri, method, body, headers, redirections, cachekey)
>>>> 6.x\\lib\\site-packages\\httplib2\\__init__.py", line 1399, in _request
>>>> 2552:tid 2568]     (response, content) = self._conn_request(conn,
>>>> request_uri, method, body, headers)
>>>> 6.x\\lib\\site-packages\\httplib2\\__init__.py", line 1319, in
>>>> _conn_request
>>>> 2552:tid 2568]     conn.connect()
>>>> 6.x\\lib\\site-packages\\httplib2\\__init__.py", line 958, in connect
>>>> 2552:tid 2568]     raise socket.error, msg
>>>> 2552:tid 2568] error: [Errno 10061] No connection could be made because the
>>>> target machine actively refused it
>>>> Please tell me what should I do .
>>>> Thank You
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/5a11e7eb/attachment-0001.html>
More information about the geonode-users mailing list
