[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Federico Gianoli alpacagis at gmail.com
Mon May 29 02:59:17 PDT 2017
Hi Alessio,
I still have some issues with restore command.
The backup command works fine, however, in the zip file, are present some
file that I had delete.
Looking for these files, I noted that they are present on Geoserver
datastore but not in Geonode layer list.
Anyway, I am able to create the zip file with the backup of the sistem (the
name of the file is 2017-05-26_051407.zip), but when I try to restore
geonode on another server (geonde 2.6 stable) I have this errors:
 OSError: [Errno 2] No such file or directory: '/tmp/restore/2017-05-26_
051407/static_dirs/media'
(here the complete error log: https://pastebin.com/ZE7r5s5a )
So, I have created manually the missing folder, but then the error was this:
 https://pastebin.com/kBAPkEyd
At the end, Geonode says that the restore was completed, but it's not true.
Furthermore, at the end of this restore, I am not more able to enter in
geonode with my user and password, I was closed out from my geonode istance
and I had to reinstall Geonode.
Thanks a lot
Federico
2017-05-25 11:58 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
> Thanks a lot Alessio!
> I have taken my time to try your suggestions, but I still don't get
> geoserver_catalog.zip copied into backup zip file.
> However, the log of backup.py seems to work correctly. Please pay
> attention to the last line. Backup.py seems to get the data from
> "geoserver_data/data/data". "data" folder is repeated in the path, and that
> only happens when I set "/geoserver_data/data" in geoserver data dir in
> settings.ini.
> Dumping 'GeoServer Catalog [http://-----]' into '/var/opt/geonode/backups/
> 2017-05-25_043616/geoserver_catalog.zip'.
> STARTED - 1/9
> COMPLETED - 9/9
> Dumped GeoServer Uploaded Data from '/geoserver_data/data/data/geonode'.
> Anyway, I still can't get copied "geoserver_catalog.zip".
> Best regards,
> Enrique
> El 24-05-2017 a las 11:52, Alessio Fabiani escribió:
> Hmm,
> yes, it is clear that there's something corrupted on your GeoServer
> configuration.
> Of course it is not easy to understand what's going on from those
> screenshots.
> From that interface try to enter Settings > Global
> [image: Inline image 1]
> edit and save. Also try to reload the catalog from
> [image: Inline image 2]
> finally if backup still does not work, try to restart Tomcat (be carefull,
> your GeoServer may not restart correctly given that error above).
> In any case your GeoServer Data Dis *must* be set to ->
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Wed, May 24, 2017 at 12:42 PM, Enrique Cerrillo Cuenca <
> cerrillo at uevora.pt> wrote:
>> Thanks again, Alessio. There is not such a zip file inside the zipped
>> backup file.
>> Here is a screenshot from the Geoserver status:
>> [image: Imágenes integradas 1]
>> If I try to perform a backup I get the following java-related error:
>> [image: Imágenes integradas 2]
>> Thanks
>> 2017-05-24 11:30 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> Enrique,
>>> can you please unzip this file /var/opt/geonode/backups/2017-05-24_
>>> 041950 <041%20950>.zip and see if there is a geoserver_catalog.zip
>>> inside?
>>> Can you also unzip that one too?
>>> Also, to be fully sure you are setting the correct GeoServer Data Dir
>>> into settings.ini, go to the GeoServer Admin GUI and check this option
>>> From here you can also test your GeoServer backup and restore
>>> functionality through this interface
>>> You can test the "geoserver_catalog.zip" file throught a DRY-RUN restore
>>> here also.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> mob:   +39 331 6233686 <%28331%29%20623-3686>
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Wed, May 24, 2017 at 11:41 AM, Enrique Cerrillo Cuenca <
>>>> I forgot to mention that the settings.ini file is as follows:
>>>> [geoserver]
>>>> datadir = /geoserver_data/
>>>> dumpvectordata = yes
>>>> dumprasterdata = yes
>>>> If I set "datadir" to /geoserver_data/data/ I got errors.
>>>> 2017-05-24 10:29 GMT+01:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>
>>>>> Thanks Alessio for all your help. I expect to help you finding the
>>>>> bugs. Things are not working here. I do get the "COMPLETE[9/9]” message,
>>>>> but I get an error when trying to restore the backup file.
>>>>> Best regards,
>>>>> Enrique
>>>>> manage.py backup --backup-dir=/var/opt/geonode/backups
>>>>> System check identified some issues:
>>>>> WARNINGS:
>>>>> *base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>>>>> ManyToManyField.*
>>>>> Before proceeding with the Backup, please ensure that:
>>>>>  1. The backend (DB or whatever) is accessible and you have rights
>>>>>  2. The GeoServer is up and running and reachable from this machine
>>>>> Dumping 'GeoServer Catalog [http:----]' into
>>>>> '//var/opt/geonode/backups/2017-05-24_041950 <041%20950>
>>>>> STARTED - 1/9
>>>>> COMPLETED - 9/9
>>>>> Dumped GeoServer Uploaded Data from '/geoserver_data/data/geonode'.
>>>>> Deactivating GeoNode Signals...
>>>>> ...done!
>>>>> Dumping 'people' into 'people.json'.
>>>>> Dumping 'account' into 'accounts.json'.
>>>>> Dumping 'avatar.avatar' into 'avatars.json'.
>>>>> Dumping 'base.backup' into 'backups.json'.
>>>>> Dumping 'base.license' into 'licenses.json'.
>>>>> Dumping 'base.topiccategory' into 'topiccategories.json'.
>>>>> Dumping 'base.region' into 'regions.json'.
>>>>> Dumping 'base.resourcebase' into 'resourcebases.json'.
>>>>> Dumping 'base.contactrole' into 'contactroles.json'.
>>>>> Dumping 'base.link' into 'links.json'.
>>>>> Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.
>>>>> Dumping 'base.spatialrepresentationtype' into
>>>>> 'spatialrepresentationtypes.json'.
>>>>> Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.
>>>>> Dumping 'guardian.groupobjectpermission' into
>>>>> 'groupopermissions.json'.
>>>>> Dumping 'layers.uploadsession' into 'uploadsessions.json'.
>>>>> Dumping 'layers.style' into 'styles.json'.
>>>>> Dumping 'layers.layer' into 'layers.json'.
>>>>> Dumping 'layers.attribute' into 'attributes.json'.
>>>>> Dumping 'layers.layerfile' into 'layerfiles.json'.
>>>>> Dumping 'maps.map' into 'maps.json'.
>>>>> Dumping 'maps.maplayer' into 'maplayers.json'.
>>>>> Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.
>>>>> Dumping 'documents.document' into 'documents.json'.
>>>>> Dumping 'taggit' into 'tags.json'.
>>>>> Saved Media Files from '/var/opt/geonode/backups/geonode/uploaded'.
>>>>> Saved Static Root from '/var/opt/geonode/backups/static_root'.
>>>>> Saved Static Files from '/var/opt/geonode/backups/geonode/static'.
>>>>> Saved Locale Files from '/var/opt/geonode/backups/geonode/locale'.
>>>>> Backup Finished. Archive generated.
>>>>> Reactivating GeoNode Signals...
>>>>> ...done!
>>>>> /var/opt/geonode/backups/2017-05-24_041950 <041%20950>.zip
>>>>> manage.py restore --backup-file=/var/opt/geonode/backups/2017-05-24_
>>>>> WARNINGS:
>>>>> ManyToManyField.*
>>>>> Before proceeding with the Restore, please ensure that:
>>>>> WARNING: The restore will overwrite ALL GeoNode data. You want to
>>>>> proceed? [n]|y: y
>>>>> Restoring 'GeoServer Catalog [http://------]' into
>>>>> '/tmp/restore/2017-05-24_041950/geoserver_catalog.zip'.
>>>>> Traceback (most recent call last):
>>>>>   File "manage.py", line 29, in <module>
>>>>>     execute_from_command_line(sys.argv)
>>>>>   File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 354, in execute_from_command_line
>>>>>     utility.execute()
>>>>> line 346, in execute
>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>   File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>> line 394, in run_from_argv
>>>>>     self.execute(*args, **cmd_options)
>>>>> line 445, in execute
>>>>>     output = self.handle(*args, **options)
>>>>>   File "/usr/src/app/geonode/base/management/commands/restore.py",
>>>>> line 97, in handle
>>>>>     raise ValueError('Could not find GeoServer Backup file [' +
>>>>> geoserver_bk_file + ']')
>>>>> ValueError: Could not find GeoServer Backup file
>>>>> [/tmp/restore/2017-05-24_041950/geoserver_catalog.zip]
>>>>> El 24 may 2017, a las 8:43, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> escribió:
>>>>> Those error are due to settings issues I guess.
>>>>> There are open issues to let backup/restore command more resilient and
>>>>> more stable. We need to find some time to improve it soon.
>>>>> @Enrique, your error is caused by GeoServer backup. Basically for some
>>>>> reason it is not able to complete the backup of the catalog. Until you see
>>>>> a message "COMPLETE[9/9]" the backup of GeoServer is not fully done. You
>>>>> should take a look at the GeoServer logs in order to see why it is failing.
>>>>> Usually this depends on some wrong configuration of datastores.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Tue, May 23, 2017 at 10:32 PM, Federico Gianoli <
>>>>> alpacagis at gmail.com> wrote:
>>>>>> Finally it works!
>>>>>> Thanks Alessio for your help. Tomorrow morning I'll try to migrate
>>>>>> data.
>>>>>> Creating manually the folder */home/federico/gn_fede/gn_fede/locale* it
>>>>>> works.
>>>>>> but using restore command without Sudo I have this error
>>>>>> *$ python manage.py restore
>>>>>> --backup-file=/tmp/backup/2017-05-23_132655.zip*
>>>>>> *Before proceeding with the Restore, please ensure that:*
>>>>>> * 1. The backend (DB or whatever) is accessible and you have rights*
>>>>>> * 2. The GeoServer is up and running and reachable from this machine*
>>>>>> *WARNING: The restore will overwrite ALL GeoNode data. You want to
>>>>>> proceed? [n]|y: y*
>>>>>> *Traceback (most recent call last):*
>>>>>> *  File "manage.py", line 11, in <module>*
>>>>>> *    execute_from_command_line(sys.argv)*
>>>>>> *  File
>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>> 354, in execute_from_command_line*
>>>>>> *    utility.execute()*
>>>>>> *  File
>>>>>> 346, in execute*
>>>>>> *    self.fetch_command(subcommand).run_from_argv(self.argv)*
>>>>>> *  File
>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
>>>>>> 394, in run_from_argv*
>>>>>> *    self.execute(*args, **cmd_options)*
>>>>>> *  File
>>>>>> 445, in execute*
>>>>>> *    output = self.handle(*args, **options)*
>>>>>> *  File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>>>>>> line 87, in handle*
>>>>>> *    target_folder = helpers.unzip_file(backup_file, restore_folder)*
>>>>>> *  File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>>>>>> line 224, in unzip_file*
>>>>>> *    os.makedirs(target_folder)*
>>>>>> *  File "/usr/lib/python2.7/os.py", line 157, in makedirs*
>>>>>> *    mkdir(name, mode)*
>>>>>> *OSError: [Errno 13] Permission denied:
>>>>>> '/tmp/restore/2017-05-23_132655'*
>>>>>> *with sudo command I have the error later:*
>>>>>> *$ sudo python manage.py restore
>>>>>> *[sudo] password for federico:*
>>>>>> proceed? [n]|y: y*
>>>>>> *Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/
>>>>>> <http://212.237.232.12/geoserver/>]' into
>>>>>> '/tmp/restore/2017-05-23_132655/geoserver_catalog.zip'.*
>>>>>> *STARTED - 3/9*
>>>>>> *FAILED - 8/9*
>>>>>> *Cleaned out old GeoServer Data Dir:
>>>>>> /usr/share/geoserver/data/data/geonode*
>>>>>> *GeoServer Uploaded Data Restored to
>>>>>> '/usr/share/geoserver/data/data/geonode'.*
>>>>>> *Cleaned out old GeoServer GWC Layers Config:
>>>>>> /usr/share/geoserver/data/gwc-layers*
>>>>>> *Restoring GeoServer Vectorial Data : popolazione_veneto*
>>>>>> *Restoring GeoServer Vectorial Data : gcgw_wells_tayarat*
>>>>>> *Restoring GeoServer Vectorial Data : main_groundwater_flow*
>>>>>> *Restoring GeoServer Vectorial Data : swl_asl*
>>>>>> *Restoring GeoServer Vectorial Data : contour_lines*
>>>>>> *Restoring GeoServer Vectorial Data : swl_asl_map_area*
>>>>>> *Restoring GeoServer Vectorial Data : springs_perennial_no_data*
>>>>>> *Restoring GeoServer Vectorial Data : c0506121_ccs2012s*
>>>>>> *Restoring GeoServer Vectorial Data : tectonic_structures*
>>>>>> *Restoring GeoServer Vectorial Data : springs_perennial*
>>>>>> *Restoring GeoServer Vectorial Data : springs_temporary*
>>>>>> *Operations to perform:*
>>>>>> *  Synchronize unmigrated apps: tasks, modeltranslation,
>>>>>> django_extensions, polymorphic, treebeard, gis,
>>>>>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>>>>>> geoserver, storages, mptt, friendlytagloader, staticfiles, geoexplorer,
>>>>>> gn_fede, sitemaps, proxy, pinax_theme_bootstrap, pagination,
>>>>>> autocomplete_light, messages, leaflet, api, avatar, social, security*
>>>>>> *  Apply all migrations: dialogos, people, tastypie, agon_ratings,
>>>>>> documents, actstream, sites, maps, contenttypes, announcements,
>>>>>> user_messages, layers, sessions, guardian, auth, base, groups, services,
>>>>>> oauth2_provider, account, admin, djcelery, upload, taggit*
>>>>>> *Synchronizing apps without migrations:*
>>>>>> *  Creating tables...*
>>>>>> *    Running deferred SQL...*
>>>>>> *  Installing custom SQL...*
>>>>>> *Running migrations:*
>>>>>> *  No migrations to apply.*
>>>>>> *  Your models have changes that are not yet reflected in a
>>>>>> migration, and so won't be applied.*
>>>>>> *  Run 'manage.py makemigrations' to make new migrations, and then
>>>>>> re-run 'manage.py migrate' to apply them.*
>>>>>> *Deactivating GeoNode Signals...*
>>>>>> *...done!*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/people.json*
>>>>>> *Installed 2 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/accounts.json*
>>>>>> *Installed 3 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/avatars.json*
>>>>>> *Installed 0 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/backups.json*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/licenses.json*
>>>>>> *Installed 7 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/topiccategories.json*
>>>>>> *Installed 20 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/regions.json*
>>>>>> *Installed 259 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/resourcebases.json*
>>>>>> *Installed 13 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/contactroles.json*
>>>>>> *Installed 26 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/links.json*
>>>>>> *Installed 296 object(s) from 1 fixture(s)*
>>>>>> *Deserializing
>>>>>> /tmp/restore/2017-05-23_132655/restrictioncodetypes.json*
>>>>>> *Installed 8 object(s) from 1 fixture(s)*
>>>>>> *Deserializing
>>>>>> /tmp/restore/2017-05-23_132655/spatialrepresentationtypes.json*
>>>>>> *Installed 6 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/useropermissions.json*
>>>>>> *Installed 141 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/groupopermissions.json*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/uploadsessions.json*
>>>>>> *Installed 18 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/styles.json*
>>>>>> *Installed 12 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/layers.json*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/attributes.json*
>>>>>> *Installed 122 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/layerfiles.json*
>>>>>> *Installed 104 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/maps.json*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/maplayers.json*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/mapsnapshots.json*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/documents.json*
>>>>>> *Installed 1 object(s) from 1 fixture(s)*
>>>>>> *Deserializing /tmp/restore/2017-05-23_132655/tags.json*
>>>>>> *Media Files Restored into '/var/www/geonode/uploaded'.*
>>>>>> *Static Root Restored into '/var/www/geonode/static/'.*
>>>>>> *Reactivating GeoNode Signals...*
>>>>>> *...done!*
>>>>>> *  File
>>>>>> *  File
>>>>>> 346, in execute*
>>>>>> *  File
>>>>>> *  File
>>>>>> 445, in execute*
>>>>>> *  File
>>>>>> line 290, in handle*
>>>>>> *    static_files_folder)*
>>>>>> *  File
>>>>>> line 203, in copy_tree*
>>>>>> *    for item in os.listdir(src):*
>>>>>> *OSError: [Errno 2] No such file or directory:
>>>>>> '/tmp/restore/2017-05-23_132655/static_dirs/media'*
>>>>>> *Creating manually the folder:
>>>>>>  /tmp/restore/2017-05-23_132655/static_dirs/media everythings works
>>>>>> correctly.*
>>>>>> *Tomorrow morning I'll try again, but I hope to have solved the
>>>>>> issue, thanks again Alessio for your help.*
>>>>>> *Good night*
>>>>>> *Federico*
>>>>>> 2017-05-23 21:04 GMT+02:00 Enrique Cerrillo Cuenca <
>>>>>>> I tried to do that yesterday. The file do exist in the path and it
>>>>>>> was allegedly created with no errors. However I’m getting this error:
>>>>>>> python manage.py restore --backup-file=backup/2017-05-17_045850
>>>>>>> <045%20850>.zip
>>>>>>> WARNINGS:
>>>>>>> ManyToManyField.*
>>>>>>> proceed? [n]|y: y
>>>>>>> Restoring 'GeoServer Catalog [http://atlas.cidehusdigital.u
>>>>>>> evora.pt/geoserver/]' into '/tmp/restore/2017-05-17_04585
>>>>>>>     utility.execute()
>>>>>>> line 97, in handle
>>>>>>> [/tmp/restore/2017-05-17_045850/geoserver_catalog.zip]
>>>>>>> Best regards,
>>>>>>> Enrique
>>>>>>> El 23 may 2017, a las 19:12, Alessio Fabiani <
>>>>>>> Except for the latest issue, which should be a warning (I will need
>>>>>>> to double check this), you should not restore the geoserver_catalog.zip but
>>>>>>> the geonode backup file which should be something like
>>>>>>> --backup-file=/tmp/backup/2017-05-23_120201.zip*
>>>>>>> If it does not exists that means that the latest warning prevents
>>>>>>> you to finalize the backup.
>>>>>>> A quick and dirty workaround is to create the folder
>>>>>>> */home/federico/gn_fede/gn_fede/locale'*
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Tue, May 23, 2017 at 7:39 PM, Federico Gianoli <
>>>>>>>> Thanks a lot Alessio and Enrique,
>>>>>>>> I think we are on the right way to solve the issue... but I still
>>>>>>>> have some errors.
>>>>>>>> I really thank you for your precious help.
>>>>>>>> *$ python manage.py backup --backup-dir=/tmp/backup/*
>>>>>>>> *Before proceeding with the Backup, please ensure that:*
>>>>>>>> machine*
>>>>>>>> *You want to proceed? [n]|y: y*
>>>>>>>> *Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
>>>>>>>> '/tmp/backup/2017-05-23_120201/geoserver_catalog.zip'.*
>>>>>>>> *STARTED - 1/9*
>>>>>>>> *COMPLETED - 9/9*
>>>>>>>> *Dumped GeoServer Uploaded Data from
>>>>>>>> *Dumping GeoServer Vectorial Data : swl_asl*
>>>>>>>> *Dumping GeoServer Vectorial Data : c0506121_ccs2012s*
>>>>>>>> *Dumping GeoServer Vectorial Data : popolazione_veneto*
>>>>>>>> *Dumping GeoServer Vectorial Data : swl_asl_map_area*
>>>>>>>> *Dumping GeoServer Vectorial Data : contour_lines*
>>>>>>>> *Dumping GeoServer Vectorial Data : tectonic_structures*
>>>>>>>> *Dumping GeoServer Vectorial Data : gcgw_wells_tayarat*
>>>>>>>> *Dumping GeoServer Vectorial Data : main_groundwater_flow*
>>>>>>>> *Dumping GeoServer Vectorial Data : springs_perennial*
>>>>>>>> *Dumping GeoServer Vectorial Data : springs_perennial_no_data*
>>>>>>>> *Dumping GeoServer Vectorial Data : springs_temporary*
>>>>>>>> *...done!*
>>>>>>>> *Dumping 'people' into 'people.json'.*
>>>>>>>> *Dumping 'account' into 'accounts.json'.*
>>>>>>>> *Dumping 'avatar.avatar' into 'avatars.json'.*
>>>>>>>> *Dumping 'base.backup' into 'backups.json'.*
>>>>>>>> *Dumping 'base.license' into 'licenses.json'.*
>>>>>>>> *Dumping 'base.topiccategory' into 'topiccategories.json'.*
>>>>>>>> *Dumping 'base.region' into 'regions.json'.*
>>>>>>>> *Dumping 'base.resourcebase' into 'resourcebases.json'.*
>>>>>>>> *Dumping 'base.contactrole' into 'contactroles.json'.*
>>>>>>>> *Dumping 'base.link' into 'links.json'.*
>>>>>>>> *Dumping 'base.restrictioncodetype' into
>>>>>>>> 'restrictioncodetypes.json'.*
>>>>>>>> *Dumping 'base.spatialrepresentationtype' into
>>>>>>>> 'spatialrepresentationtypes.json'.*
>>>>>>>> *Dumping 'guardian.userobjectpermission' into
>>>>>>>> 'useropermissions.json'.*
>>>>>>>> *Dumping 'guardian.groupobjectpermission' into
>>>>>>>> 'groupopermissions.json'.*
>>>>>>>> *Dumping 'layers.uploadsession' into 'uploadsessions.json'.*
>>>>>>>> *Dumping 'layers.style' into 'styles.json'.*
>>>>>>>> *Dumping 'layers.layer' into 'layers.json'.*
>>>>>>>> *Dumping 'layers.attribute' into 'attributes.json'.*
>>>>>>>> *Dumping 'layers.layerfile' into 'layerfiles.json'.*
>>>>>>>> *Dumping 'maps.map' into 'maps.json'.*
>>>>>>>> *Dumping 'maps.maplayer' into 'maplayers.json'.*
>>>>>>>> *Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.*
>>>>>>>> *Dumping 'documents.document' into 'documents.json'.*
>>>>>>>> *Dumping 'taggit' into 'tags.json'.*
>>>>>>>> *Saved Media Files from '/var/www/geonode/uploaded'.*
>>>>>>>> *Saved Static Root from '/var/www/geonode/static/'.*
>>>>>>>> *Saved Static Files from '/etc/geonode/media'.*
>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/static'.*
>>>>>>>> *Saved Static Files from '/home/federico/gn_fede/gn_fede/static'.*
>>>>>>>> *Saved Template Files from '/etc/geonode/templates'.*
>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/templates'.*
>>>>>>>> *...done!*
>>>>>>>> *  File
>>>>>>>> *  File
>>>>>>>> 346, in execute*
>>>>>>>> *  File
>>>>>>>> *  File
>>>>>>>> 445, in execute*
>>>>>>>> *  File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>>>>>> line 243, in handle*
>>>>>>>> *    helpers.copy_tree(locale_files_folder, locale_folder)*
>>>>>>>> *  File
>>>>>>>> '/home/federico/gn_fede/gn_fede/locale'*
>>>>>>>> *The restore issue:*
>>>>>>>> * $ python manage.py restore
>>>>>>>> --backup-file=/tmp/backup/2017-05-23_120201/geoserver_catalog.zip Before
>>>>>>>> proceeding with the Restore, please ensure that:  1. The backend (DB or
>>>>>>>> whatever) is accessible and you have rights  2. The GeoServer is up and
>>>>>>>> running and reachable from this machine WARNING: The restore will overwrite
>>>>>>>> ALL GeoNode data. You want to proceed? [n]|y: y Traceback (most recent call
>>>>>>>> last):   File "manage.py", line 11, in <module>
>>>>>>>> execute_from_command_line(sys.argv)   File
>>>>>>>> 354, in execute_from_command_line     utility.execute()   File
>>>>>>>> 346, in execute     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>>>>> line 394, in run_from_argv     self.execute(*args, **cmd_options)   File
>>>>>>>> 445, in execute     output = self.handle(*args, **options)   File
>>>>>>>> line 87, in handle     target_folder = helpers.unzip_file(backup_file,
>>>>>>>> restore_folder)   File
>>>>>>>> line 227, in unzip_file     z.extractall(target_folder)   File
>>>>>>>> "/usr/lib/python2.7/zipfile.py", line 1040, in extractall
>>>>>>>> self.extract(zipinfo, path, pwd)   File "/usr/lib/python2.7/zipfile.py",
>>>>>>>> line 1028, in extract     return self._extract_member(member, path, pwd)
>>>>>>>> File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member
>>>>>>>> file(targetpath, "wb") as target: IOError: [Errno 13] Permission denied:
>>>>>>>> u'/tmp/restore/geoserver_catalog/store.dat.1' *
>>>>>>>> * Usuìing SUDO command, the error is different:*
>>>>>>>> $ sudo python manage.py restore --backup-file=/tmp/backup/2017
>>>>>>>> proceed? [n]|y: y
>>>>>>>> Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/]'
>>>>>>>> into '/tmp/restore/geoserver_catalog/geoserver_catalog.zip'.
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>>>>>     utility.execute()
>>>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>>>>>>>> line 97, in handle
>>>>>>>> [/tmp/restore/geoserver_catalog/geoserver_catalog.zip]
>>>>>>>> *Anyway, using Enrique suggestion, the system doesn't work and I
>>>>>>>> have this error:*
>>>>>>>> Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/]'
>>>>>>>> into '/tmp/backup/2017-05-23_122247/geoserver_catalog.zip'.
>>>>>>>> STARTED - 1/9
>>>>>>>> COMPLETED - 9/9
>>>>>>>>     utility.execute()
>>>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>>>>>> line 150, in handle
>>>>>>>>     helpers.copy_tree(gs_data_root, gs_data_folder)
>>>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver
>>>>>>>> /data/geonode'
>>>>>>>> 2017-05-23 18:16 GMT+02:00 Enrique Cerrillo Cuenca <
>>>>>>>>> Hi,
>>>>>>>>> I have the same problem that Federico. A few days ago, I made that
>>>>>>>>> change, “datadir = geoserver/data”, and the backup also failed. However,
>>>>>>>>> when i set “datadir” to “geoserver/“ it works, although “geoserver_catalog”
>>>>>>>>> is not included in the backup zip file.
>>>>>>>>> Best regards,
>>>>>>>>> Enrique
>>>>>>>>> El 23 may 2017, a las 16:52, Alessio Fabiani <
>>>>>>>>> Ok, so, the GeoServer backup has been done "COMPLETED - 9/9" but
>>>>>>>>> there's an error on the backup settings.
>>>>>>>>> It looks like it cannot find the GeoServer Data Dir path on the
>>>>>>>>> local server.
>>>>>>>>> Edit this file
>>>>>>>>> geonode/base/management/commands/settings.ini
>>>>>>>>> and be sure to change this "datadir = *geoserver/data*" with the
>>>>>>>>> absolute path to the GEOSERVER_DATA_DIR
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Tue, May 23, 2017 at 5:45 PM, Federico Gianoli <
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> This is the result of these commands:
>>>>>>>>>> * Before proceeding with the Backup, please ensure that:  1. The
>>>>>>>>>> backend (DB or whatever) is accessible and you have rights  2. The
>>>>>>>>>> GeoServer is up and running and reachable from this machine *
>>>>>>>>>> '/tmp/backup/2017-05-23_103754/geoserver_catalog.zip'.*
>>>>>>>>>> * STARTED - 1/9 COMPLETED - 9/9 Traceback (most recent call
>>>>>>>>>> line 150, in handle     helpers.copy_tree(gs_data_root, gs_data_folder)
>>>>>>>>>> File
>>>>>>>>>> line 203, in copy_tree     for item in os.listdir(src): OSError: [Errno 2]
>>>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'
>>>>>>>>>> The backup is created but with the error (*OSError: [Errno 2] No
>>>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'*
>>>>>>>>>> ), and the restore command doesn't work
>>>>>>>>>> --backup-file=/tmp/backup/2017-05-23_103754/geoserver_catalog.zip*
>>>>>>>>>> rights*
>>>>>>>>>> machine*
>>>>>>>>>> *  File
>>>>>>>>>> *  File
>>>>>>>>>> 346, in execute*
>>>>>>>>>> *  File
>>>>>>>>>> *  File
>>>>>>>>>> 445, in execute*
>>>>>>>>>> *  File
>>>>>>>>>> line 87, in handle*
>>>>>>>>>> restore_folder)*
>>>>>>>>>> *  File
>>>>>>>>>> line 227, in unzip_file*
>>>>>>>>>> *    z.extractall(target_folder)*
>>>>>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1040, in extractall*
>>>>>>>>>> *    self.extract(zipinfo, path, pwd)*
>>>>>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1028, in extract*
>>>>>>>>>> *    return self._extract_member(member, path, pwd)*
>>>>>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1083, in
>>>>>>>>>> _extract_member*
>>>>>>>>>> *    file(targetpath, "wb") as target:*
>>>>>>>>>> *IOError: [Errno 13] Permission denied:
>>>>>>>>>> u'/tmp/restore/geoserver_catalog/store.dat.1'*
>>>>>>>>>> Thanks for your help
>>>>>>>>>> Federico
>>>>>>>>>> 2017-05-23 17:33 GMT+02:00 Alessio Fabiani <
>>>>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>>>>> Federico, before doing anything, can you try to do this test?
>>>>>>>>>>> sudo mkdir /tmp/backup
>>>>>>>>>>> sudo chmod -Rf 777 /tmp/backup
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Italy
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> On Tue, May 23, 2017 at 5:24 PM, Federico Gianoli <
>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>> thanks for your quick answer,
>>>>>>>>>>>> I have checked, but I have not the files 2 and 3 on my geonode
>>>>>>>>>>>> instance. How is it possible? I have installed geonode via ppa.
>>>>>>>>>>>> I have overwritten all "commands" folder, in order to be sure
>>>>>>>>>>>> to have the latest files, bu it is still not working.
>>>>>>>>>>>> There is another way to do the backup?
>>>>>>>>>>>> In your opinion, if I upgrade my version of geonode (2.6rc) to
>>>>>>>>>>>> the last stable (sudo apt-get upgrade   right?), this issue will be solved?
>>>>>>>>>>>> How dangerous could be for my data?
>>>>>>>>>>>> Thanks a lot
>>>>>>>>>>>> Fede
>>>>>>>>>>>> 2017-05-23 12:38 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>> Digging to the source code of both GeoNode management command
>>>>>>>>>>>>> [1] and GeoServer Backup Plugin [2] and [3], seems like that GeoServer
>>>>>>>>>>>>> can't access the "${target_folder}/geoserver_catalog.zip"
>>>>>>>>>>>>> The ${target_folder} should be composed by the join of ${backup_dir}
>>>>>>>>>>>>> and ${dir_time_suffix}, something like ${backup_dir}/<time_stamp>
>>>>>>>>>>>>> where ${backup_dir} is the parameter provided when running
>>>>>>>>>>>>> the backup command from GeoNode.
>>>>>>>>>>>>> Now, the latest GeoNode code [4] tries to set chmod(777) to
>>>>>>>>>>>>> this temporary folder, which will be deleted at the end, in order to allow
>>>>>>>>>>>>> to GeoServer to write the file.
>>>>>>>>>>>>> That means that most probably the user running GeoNode must
>>>>>>>>>>>>> have full rights on the ${backup_dir} folder.
>>>>>>>>>>>>> Can you maybe try to double check this?
>>>>>>>>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>>>>>>>> ase/management/commands/backup.py#L92
>>>>>>>>>>>>> [2] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>>>>>>>> mmunity/backup-restore/rest/src/main/java/org/geoserver/back
>>>>>>>>>>>>> uprestore/rest/BackupResource.java#L155
>>>>>>>>>>>>> [3] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>>>>>>>> mmunity/backup-restore/core/src/main/java/org/geoserver/back
>>>>>>>>>>>>> uprestore/Backup.java#L328
>>>>>>>>>>>>> [4] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>>>>>>>> ase/management/commands/backup.py#L86
>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <
>>>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>>>> I have checked the Geoserver Log, and here you can find the
>>>>>>>>>>>>>> complete geoserver log: https://pastebin.com/c9JeR1NU
>>>>>>>>>>>>>> The error that I have noted on the log is this one:
>>>>>>>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to
>>>>>>>>>>>>>> perform backup: :Could not create file.*
>>>>>>>>>>>>>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] -
>>>>>>>>>>>>>> Compressing output for mimetype: text/plain*
>>>>>>>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>>>>>>>>>>>>>> *org.geoserver.rest.RestletException:
>>>>>>>>>>>>>> java.lang.IllegalStateException: Could not create file.*
>>>>>>>>>>>>>> * at org.geoserver.backuprestore.re
>>>>>>>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.runBackup(BackupResource.java:172)*
>>>>>>>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.handlePost(BackupResource.java:108)*
>>>>>>>>>>>>>> The rights of  /usr/share/geoserver/data are these:
>>>>>>>>>>>>>> drwxr-xr-x  21 tomcat7 tomcat7      4096 May 23 04:49 data
>>>>>>>>>>>>>> I have also changed the folder rights adding user: tomcat7
>>>>>>>>>>>>>> and user:user, but without any result.
>>>>>>>>>>>>>> Thanks a lot for your help and your patience
>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>>>> It is possible that GeoServer cannot write to the target
>>>>>>>>>>>>>>> folder. Take a look at the GeoServer logs. Also try to rise up the log
>>>>>>>>>>>>>>> level if you don't find anything useful.
>>>>>>>>>>>>>>> This can be done from the GeoServer admin gui.
>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>>>>>>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>> which version of GeoServer are you using?
>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>>>>>>>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>>>>>>>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>>>>>>>>>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <
>>>>>>>>>>>>>>>>> Thanks a lot Alessio,
>>>>>>>>>>>>>>>>> I have changed the files according to your suggestions,
>>>>>>>>>>>>>>>>> but now I have this error:
>>>>>>>>>>>>>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>>>>>>>>>>>>>> have rights*
>>>>>>>>>>>>>>>>> this machine*
>>>>>>>>>>>>>>>>> [http://212.237.232.12/geoserver/ <http://212.237.232.12/geoserver/>]' into
>>>>>>>>>>>>>>>>> 'backup/2017-05-19_050730 <050%20730>/geoserver_catalog.zip'.*
>>>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>>>> 346, in execute*
>>>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>>>> 445, in execute*
>>>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>>>> line 101, in handle*
>>>>>>>>>>>>>>>>> *    gs_backup = r.json()*
>>>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/requests/models.py", line 808, in json*
>>>>>>>>>>>>>>>>> *    return complexjson.loads(self.text, **kwargs)*
>>>>>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/__init__.py", line 339,
>>>>>>>>>>>>>>>>> in loads*
>>>>>>>>>>>>>>>>> *    return _default_decoder.decode(s)*
>>>>>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 364, in
>>>>>>>>>>>>>>>>> decode*
>>>>>>>>>>>>>>>>> *    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 382, in
>>>>>>>>>>>>>>>>> raw_decode*
>>>>>>>>>>>>>>>>> *    raise ValueError("No JSON object could be decoded")*
>>>>>>>>>>>>>>>>> *ValueError: No JSON object could be decoded*
>>>>>>>>>>>>>>>>> *Thanks a lot for your help*
>>>>>>>>>>>>>>>>> *Fede*
>>>>>>>>>>>>>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>>>>>>> PR here
>>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>>>> currently the backup and restore utility should be
>>>>>>>>>>>>>>>>>>> aligned with latest updates I guess. There are also several issues /
>>>>>>>>>>>>>>>>>>> improvements we are working on to improve this tool.
>>>>>>>>>>>>>>>>>>> We will find some spare time soon to devote to those
>>>>>>>>>>>>>>>>>>> tasks. We will send updates as soon as possible.
>>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>> Hi Federico,
>>>>>>>>>>>>>>>>>>>> there seems to be an issue in the commands, simplejson
>>>>>>>>>>>>>>>>>>>> is not available anymore, json has to be used. we should fix it.
>>>>>>>>>>>>>>>>>>>> @afabiani, is that correct?
>>>>>>>>>>>>>>>>>>>> node/blob/2.6.x/geonode/base/m
>>>>>>>>>>>>>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>>>>>>>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>>>>>>>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <
>>>>>>>>>>>>>>>>>>>> alpacagis at gmail.com>:
>>>>>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>>>>>> I would like to create a backup of my geonode project
>>>>>>>>>>>>>>>>>>>>> and I am using this guide: http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>>>>>>>>>>>>>> From my django admin page (Base => backups) I tried to
>>>>>>>>>>>>>>>>>>>>> do a backup, but, when I run the backup, on a fully writable folder (777),
>>>>>>>>>>>>>>>>>>>>> there is this server error:
>>>>>>>>>>>>>>>>>>>>> Internal Server Error
>>>>>>>>>>>>>>>>>>>>> The server encountered an internal error or
>>>>>>>>>>>>>>>>>>>>> misconfiguration and was unable to complete your request.
>>>>>>>>>>>>>>>>>>>>> I have double checked the settings.ini file, and I
>>>>>>>>>>>>>>>>>>>>> have noted that the configuration file is not yet update for the 2.6
>>>>>>>>>>>>>>>>>>>>> version, it has these lines:
>>>>>>>>>>>>>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>>>>>>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>>>>>>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>>>>>>>>>>>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>>>>>>>>>>>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_
>>>>>>>>>>>>>>>>>>>>> to_24.LayerAttributesMangler,g
>>>>>>>>>>>>>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>>>>>>>>>>>>>> Is it correct? Have I to change these lines
>>>>>>>>>>>>>>>>>>>>> accordingly to the 2.6 version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>>>>>>>>>>>>>> When I try to run the backup from command line there
>>>>>>>>>>>>>>>>>>>>> is the following error about the file backup.py
>>>>>>>>>>>>>>>>>>>>> How can I solved this issue?
>>>>>>>>>>>>>>>>>>>>> Tanks a lot
>>>>>>>>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170529/8bd07b45/attachment-0011.png>
More information about the geonode-users mailing list
