[GeoNode-users] geoserver authentication in multi-geosites
Alessio Fabiani alessio.fabiani at gmail.com
Wed May 31 06:47:13 PDT 2017
P.S.: I kindly suggest you to change the default admin password of GeoServer
On Wed, May 31, 2017 at 3:45 PM, Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> Hello Eugenio,
> so, just do a quick test... if the layer is public, go to
> http://geothoponode.igg.cnr.it/geoserver2 and, as anonymous user, try to
> hit Layer Preview.
> If you don't see your layer listed here, that means that the security (at
> least on that geoserver2 instance) does not allow you to access it as an
> anonymous user.
> On Wed, May 31, 2017 at 3:20 PM, Eugenio Trumpy <frippe12573 at hotmail.com>
> wrote:
>> Hi Alessio,
>> the raster layer is a public layer. It can be seen by anyone (check box
>> marked). There is also my name among the users. The same for download
>> capabilities.
>> I saw this information in the 'Change layer permissions' panel.
>> What do you mean with "Is the geotiff present and configured on the
>> second instance too"? If you mean that the raster layer is listed also
>> in the child site,
>> the answer is yes.
>> I don't know how to catch the request, however the geoserver log output
>> is:
>> https://pastebin.com/W0K9LHde
>> any hints?
>> E.
>> *Da:* Alessio Fabiani <alessio.fabiani at gmail.com>
>> *Inviato:* mercoledì 24 maggio 2017 15.50
>> *A:* Eugenio Trumpy
>> *Cc:* geonode-users; Simone Dalmasso
>> *Oggetto:* Re: [GeoNode-users] geoserver authentication in multi-geosites
>> Is the geotiff present and configured on the second instance too? Is it
>> private or publicly accessible? Can you somehow intercept the requests and
>> send them here?
>> On May 20, 2017 15:20, "Eugenio Trumpy" <frippe12573 at hotmail.com> wrote:
>>> Hi all,
>>> unfortunately I was not able to solve the issue raised in this thread. I
>>> was just living in the situation described.
>>> However, today I have to face a consequent, I guess, issue.
>>> From a child site I'm not able to download a raster layer (uploaded as
>>> tif) in geotiff format (i.e. in the download menu there is not the item
>>> 'Geotiff').
>>> If I try to download the same raster layer from the master site it is
>>> possible (i.e. in the download menu there is the item 'Geotiff').
>>> I think is a matter of geoserver configuration/authentication in
>>> geonode-multitenancy environment.
>>> Have you got any suggestion?
>>> E.
>>> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
>>> *Inviato:* mercoledì 5 aprile 2017 15.39
>>> *A:* Eugenio Trumpy
>>> *Cc:* geonode-users at lists.osgeo.org
>>> *Oggetto:* Re: geoserver authentication in multi-geosites
>>> Eugenio, I don't see wrong config. It is ok I guess to leave the master
>>> site host in the gs config as well as I think it is ok that you cannot log
>>> in directly into gs from a child site. That said, when geosites was
>>> developed, the geoserver ext was modified to make sure that geoserver pings
>>> the same host that made the http request for authentication instead of
>>> relying on the base url parameter. So ideally it should work as you would
>>> expect.
>>> 2017-04-05 14:39 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Hi,
>>>> I'm working on geonode 2.4 in a Ubuntu server 14.04LTS (tomcat7, java8).
>>>> I had to upgrade geoserver from 2.7.x version up to 2.9.x.
>>>> In the system I configured geonode to work as multi-geosites.
>>>> The master site is the normal geonode site, I mean it use the
>>>> local_setting.py I have in /geonode/geonode
>>>> The geosites are in /geonode/geonode/contrib/geosites, and they use
>>>> the relative config files.
>>>> The documentation: https://github.com/terranodo/geosites-project
>>>> /blob/master/GEOSITES-README.md
>>>> indicates to leave empty <baseurl> in config.xml in
>>>> security/auth/geonodeauthprovider/
>>>> In that way I have this error:
>>>> java.lang.IllegalArgumentException: host parameter is null
>>>> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:206)
>>>> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:155)
>>>> 	org.apache.commons.httpclient.SimpleHttpConnectionManager.getConnectionWithTimeout(SimpleHttpConnectionManager.java:175)
>>>> 	org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:153)
>>>> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
>>>> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
>>>> 	org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
>>>> 	org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>>>> 	org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>>>> 	org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
>>>> 	org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
>>>> 	org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
>>>> 	org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
>>>> 	org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:94)
>>>> 	org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
>>>> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>> 	org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>>>> 	org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>>> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>> 	org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>>> 	org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
>>>> 	org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
>>>> 	org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
>>>> 	org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>> 	org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
>>>> 	org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>>> 	org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>> 	org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>>> 	org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>>> 	org.springframework.web.filter.CharacterEncodingFilter.doFilterIntaernal(CharacterEncodingFilter.java:121)
>>>> 	org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
>>>> both if I use the geoserver link in the menu (once logged in) and if I
>>>> call geoserver by using the geoserver url in the browser address bar.
>>>> If set the doman name of the master site in <baseurl> in config.xml in
>>>> I'm able to enter in geoserver as admin from the menu, by the way doing
>>>> the same operation from a geosite
>>>> I got the geoserverage but not logged.
>>>> The master site virtualhost as well as those of the geosites have the
>>>> proxypass and reverse pointing to http://localhost:8080/geoserver
>>>> The same in /geonode/geonode/contrib/geosites/local_setting.py and
>>>> pre-setting.py I have http://localhost:8080/geoserver
>>>> Is there a wrong configuration?
>>>> Any hints?
>>> Simone
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170531/2a07c699/attachment-0001.html>
More information about the geonode-users mailing list
