[GeoNode-users] problem with sld
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Nov 27 01:32:16 PST 2017
Hi guys,
those SLD issues have been solved with latest GeoNode / GeoServer versions.
Also with GeoServer 2.12.x SLDs are compatible with QGIs exported ones also.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Sat, Nov 25, 2017 at 3:13 PM, Ivan Marchesini <ivan.marchesini at gmail.com>
wrote:
> Thank you Ariel
> It is useful to know that some others have found the same problem and
> thank you for the workaround
> In case I do not find another solution I will try to write a python code
> to do this..
> thank you
> Ivan
> On 24/11/2017 19:31, Ariel Neri wrote:
> Hi, I had to adapt many complicated, hundred of clases simbology sld made
> in qgis to be used in Geoserver some time ago.  I tried some programs with
> no luck, so finally I changed a few things in the QGis sld file to make it
> work in Geoserver.
> Basically it´s just 3 steps, using the "search and replace" tool:
> 1-  i replaced the first line with one from an existing geoserver sld:
> <?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns="
> http://www.opengis.net/sld" xmlns:sld="http://www.opengis.net/sld"
> xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.
> net/gml" version="1.0.0">
> 2- Also copy the first lines raplacing the "****" with your own
> <sld:NamedLayer>
>                             <sld:Name>****** </sld:Name>
>                              <sld:UserStyle>
>                                              <sld:Name>*****</sld:Name>
>                                              <sld:Title>******</sld:Title>
>                                              <sld:Abstract>******</sld:
> Abstract>
>                                              <sld:FeatureTypeStyle>
> <sld:Name>name</sld:Name>
> and do the same with the closings
>                                                </sld:FeatureTypeStyle>
>                                </sld:UserStyle>
>                 </sld:NamedLayer>
> </sld:StyledLayerDescriptor>
> 3- Use the search and replace tool: replace    “<se:”  and   “</se:” with “<sld:
> (…)”  and  “</sld: (…)” respectivly. And replace  “SvgParameter” with
> “CssParameter”
> Sorry if i don´t use correct vocabulary, i´m not so much into coding,
> neather into english language.
> A co-worker made a script to do the steps before automatically with
> RStudio and made it even simpler for me.
> This was a good enough work-around for me and solved my problem. Probably
> now there´s a better way (i hope so). I share anyway in case it helps you.
> 2017-11-24 14:43 GMT-03:00 Ivan Marchesini <ivan.marchesini at gmail.com>:
>> Dear geonode users and developer
>> I apologize if this is a well known problem but browsing on Internet
>> (including the mailing list) I wasn't able to find a good solution
>> I have recently installed geonode2.6 (ubuntu, ppa) for a project where
>> multiple and not skilled users will be involved.
>> I have tried to do a couple of things:
>> 1) I uploaded a shapefile (separate files) together with a sld file
>> exported from qgis. It happened to me that (i) the corresponding sld file
>> created in geoserver is very different from the  original one (tipicaly the
>> colors are lost)  and (ii) since the <Title> tag is not present geonode is
>> only able to show me a style called "none"
>> 2) I uploaded a shapefile (separate files) together with a sld file
>> exported from udig. It happened to me that (ii) since the <Title> tag is
>> not present geonode is only able to show me a style called "none"
>> is there a way for creating a well formatted sld file for
>> geoserver/geonode using some desktop GIS or some other tools with a GUI?
>> It is very important to me since I can't ask the other colleagues to edit
>> directly the xml files..  they will be too much scared by that!!
>> thank you for your answers
>> Ivan
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171127/3168f2ea/attachment.html>
More information about the geonode-users mailing list
