[GeoNode-users] How do I enable the "Create Layer" application?
Joe Hotchkiss joe.hotchkiss at envsys.co.uk
Wed Oct 25 08:05:51 PDT 2017
Thank you for the quick (and informative) reply.
What got me worried about about not seeing this facility wasn't so much
not-being-able-to-create-empty-layers, as the implication that PostGIS
wasn't enabled for GeoNode and that GeoNode might not be using the postgres
databases that have been created for it.  This might be me worrying over
nothing and all is as well as it can be for this version of GeoNode, but I
wanted to know if there is something else I need to set up.
On 25 October 2017 at 15:40, Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> createlayer is available only in latest source code, not in 2.6.x
> Sorry about it
> regards
> p
> On Wed, Oct 25, 2017 at 10:31 AM, Joe Hotchkiss
> <joe.hotchkiss at envsys.co.uk> wrote:
> > http://docs.geonode.org/en/master/tutorials/users/
> managing_layers/create.html
> > states:
> > In GeoNode it is possible to create empty layers, that can be populated
> with
> > features at a later stage using the mapping client editing tools.
> > This is possible using the createlayer application, which can be enabled
> if
> > GeoNode is installed with PostGIS.
> > Once the application is enabled in GeoNode you will be able to create an
> > empty layer by browsing to “Data > Create Layer”.
> > I have GeoNode 2.6.3 installed and running.  The geonode and geonode_data
> > databases exist, and geonode_data has the postgis extension.
> > What do I need to do to 'enable the application in GeoNode'?
> > Joe Hotchkiss
> > Software Developer
> > Environment Systems
> > Tel: +44 (0) 1970 626688
> > www.envsys.co.uk
> > The information contained in this e-mail is intended only for the use of
> the
> > person(s) to whom it is addressed and may contain confidential or
> privileged
> > information. If you have received this e-mail in error please contact the
> > sender and delete the material without copying, distributing or
> disclosing
> > the content. All reasonable precautions have been taken to ensure that
> this
> > e-mail is free from any virus, however, the recipient should verify this
> to
> > be the case. Please 'think before you print'
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
*Joe HotchkissSoftware DeveloperEnvironment Systems*
www.envsys.co.uk
the person(s) to whom it is addressed and may contain confidential or
privileged information. If you have received this e-mail in error please
contact the sender and delete the material without copying, distributing or
disclosing the content. All reasonable precautions have been taken to
ensure that this e-mail is free from any virus, however, the recipient
should verify this to be the case. Please 'think before you print'
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171025/173005ab/attachment.html>
More information about the geonode-users mailing list
