[GeoNode-users] OAuth external authentication/authorization
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Sep 22 05:22:35 PDT 2017
It depends on the OAuth service. If not one of the standard ones you might
need to write a small extension (mostly configuration stuff). Usually the
OAuth providers have different forms.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Sep 22, 2017 at 11:43 AM, Stefano Menegon <ste.menegon at gmail.com>
wrote:
> Hi Francesco e Alessio,
>  thanks for the answers.
> > In principle is possible, but you should add configuration and settings
> both
> > to GeoNode and GeoServer. Also GeoNode should have some code to retrieve
> > valid tokens from the external service also instead of internal provider.
> so, if I understand, your are talking about customization on python
> code and it's not necessary to write code on GeoServer (e.g. new
> custom classes). is that correct?
> //ste
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170922/3b6dbcb9/attachment.html>
More information about the geonode-users mailing list
