[GeoNode-users] Customizing Geonode (Installed via apt-get) from Geonode-project Dev (Installed via Python Virtualenv)
Dave Kennewell davekennewell at gmail.com
Wed Apr 18 08:24:53 PDT 2018
Hi Julierme,
The missing maps and users suggests to me that geonode is now using a
different database. If it is still working, but just with no maps or users,
my guess is:
Prior to configuring geonode.conf, you would have been using the default
postgresql database that is installed with geonode via apt-get. This is
likely where your 6 maps & 2 users currently reside.
After configuring geonode.conf, you will likely be using
your_geonode_project.wsgi.py, which will point to
your_geonode_project.settings. This settings file will override the default
postgresql database with whatever you have in there (either in
your_geonode_project.settings or local_settings.py)
The next steps to "fix" this depends on which database you want to use
long-term?
Does this sound right or do you think it is something else?
regards
Dave
On 18 April 2018 at 19:13, juliermeopensourcedeveloper [via OSGeo.org] <
ml+s1560n5361932h7 at n6.nabble.com> wrote:
> Dear all,
> I just finished configuring *geonode.conf* in order to customize Geonode
> main layout (installed via apt-get) based on changes made through
> Geonode-Project Dev layout (installed via Python Virtualenv). Before
> configuring *geonode.conf*, I had 6 Maps and 2 users in my Geonode and
> after applying Geonode-Project Dev layout by changing *geonode.conf*, I
> faced the following problems:
> 1 - The 6 Maps and 2 Users I had in Geonode are gone;
> 2 - I am unable to log in even with Geonode default credentials;
> Could someone tell me why I am facing these problems and figure out one
> way to fix them?
> Thank you very much for your time and patience in advance.
> Best Regards
> Julierme
> geonode-users mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5361932&i=0>
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Customizing-
> Geonode-Installed-via-apt-get-from-Geonode-project-Dev-
> Installed-via-Python-Virtualenv-tp5361932.html
> To unsubscribe from GeoNode users, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185389&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OXwtOTI1NjEyMTk0>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180418/9f48b4f7/attachment-0001.html>
More information about the geonode-users mailing list
