[GeoNode-users] GeoNode-Project: migration and createsuperuser (Julierme Pinheiro)
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu Aug 2 06:22:29 PDT 2018
Dear Francesco,
Thank you very much for your reply and resource suggestion. I am taking a
python course and as soon as I finished it, I will devour the information
in http://www.paolocorti.net/foss4g_2017_geonode_solr/.
<http://www.paolocorti.net/foss4g_2017_geonode_solr/>
Regarding Gdalinfo, I have gdal at 2.2.1 and pygdal at 2.2.1.3
geo at gis:~$ gdal-config --version
2.2.1
2.2.1
geo at gis:~$ pip show pygdal
Version: 2.2.1.3
Before entering to the resource you sent me, let me just give some more
information about what I am trying to do. I created three virtualenv for
GeoNode-Project named by: my_geonode, geonode_project, and sipam_geonode.
Sorry if I am misunderstanding, but I think I can do that without mixing
the requirements  (requirements.txt) for each GeoNode vesrion. Also I
created three users /home/my_geonode; /home/geonode_project and
/home/sipam_geonode.
(my_geonode) geo at gis: /home/my_geonode/my_geonode  # contains
GeoNode-Project at 2.8.0. installed according to the pdf in attached.
Fine. GeoNode is up and running.
One issue only: I collected the static directory by running python
manage.py collectstatic, but I did not see css changes on the index.html.
site_base.css ---> .home .jumbotron { background: yellow }
(geonode_project) geo at gis: /home/geonode_project/my_geonode  # contains
GeoNode-Project at 2.9.0. installed according to
https://github.com/geosolutions-it/geonode-project
Issue1: paver sync
Response:
 pavement.sync
 python -W ignore manage.py makemigrations --noinput
  File "manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
    utility.execute()
  File
line 356, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/base.py",
line 283, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 327, in execute
    self.check()
  File
line 359, in check
    include_deployment_checks=include_deployment_checks,
  File
line 346, in _run_checks
    return checks.run_checks(**kwargs)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/registry.py",
line 81, in run_checks
    new_errors = check(app_configs=app_configs)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/urls.py",
line 16, in check_url_config
    return check_resolver(resolver)
  File
line 26, in check_resolver
    return check_method()
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/urls/resolvers.py",
line 254, in check
    for pattern in self.url_patterns:
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/functional.py",
line 35, in __get__
    res = instance.__dict__[self.name] = self.func(instance)
  File
line 405, in url_patterns
    patterns = getattr(self.urlconf_module, "urlpatterns",
self.urlconf_module)
  File
line 35, in __get__
  File
line 398, in urlconf_module
    return import_module(self.urlconf_name)
  File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
    __import__(name)
  File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24, in
<module>
    from geonode.urls import urlpatterns
  File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py", line
89, in <module>
    url(r'^catalogue/', include('geonode.catalogue.urls')),
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/conf/urls/__init__.py",
line 50, in include
    urlconf_module = import_module(urlconf_module)
    __import__(name)
  File
"/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
line 22, in <module>
    from . import views
  File
"/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
line 29, in <module>
    from pycsw import server
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pycsw/__init__.py",
line 35, in <module>
    __version__ = pkg_resources.require("pycsw")[0].version
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pkg_resources/__init__.py",
line 892, in require
    needed = self.resolve(parse_requirements(requirements))
  File
line 783, in resolve
    raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
(/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
Captured Task Output:
---> pavement.sync
Build failed running pavement.sync: Subprocess return code: 1
Issue2: paver start
*Note*: The issue seems to be related to xmltodict version. It is installed
xmltodict 0.9.2, but it requires xmltodict 0.10.2. My concern is to try to
upgrade the requirements version and get everything messed up.
(geonode_project) geo at gis:/home/geonode_project/my_geonode$ pip show
xmltodict
Version: 0.9.2
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/autoreload.py",
line 228, in wrapper
    fn(*args, **kwargs)
  File
"/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/commands/runserver.py",
line 124, in inner_run
    self.check(display_num_errors=True)
  File
line 359, in check
  File
  File
  File
  File
  File
line 254, in check
  File
line 35, in __get__
  File
  File
line 35, in __get__
  File
    __import__(name)
<module>
89, in <module>
  File
line 50, in include
    __import__(name)
  File
    from . import views
  File
  File
  File
  File
GeoNode is now available.
(sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode  # contains
GeoNode-Project at 2.6.x. installed according to
http://geonode.org/dev-workshop/#/2/3
Issues: python manage.py migrate
           python manage.py createsuperuser
           python manage.py shell
Response:
  File "manage.py", line 29, in <module>
  File
"/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
  File
line 328, in execute
    django.setup()
  File
"/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
line 18, in setup
    apps.populate(settings.INSTALLED_APPS)
  File
"/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/registry.py",
line 108, in populate
    app_config.import_models(all_models)
  File
"/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/config.py",
line 198, in import_models
    self.models_module = import_module(models_module_name)
    __import__(name)
  File "/home/sipam_geonode/geonode/geonode/base/models.py", line 56, in
<module>
    from geonode.utils import bbox_to_wkt
  File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in <module>
    from osgeo import ogr
ImportError: No module named osgeo
What I am doing seems to be crazy (;. But I separated my project in two
parts, in one side I have GeoNode Production working fine and on the other,
I need to have GeoNode-project. My goal is to have geonode-project working
fine and make the connection between them. A bridge project started from
its land edges (;
Kind regards
Julierme
On Thu, Aug 2, 2018 at 7:51 AM, francesco bartoli <xbartolone at gmail.com>
wrote:
> Hi Julierme,
> just to give you some quick ways to check what could be wrong.
> Check what GDAL version is installed or it isn't
> $ gdalinfo --version
> Check if the python bindings for GDAL are installed
> (virtual environment)
> $ python manage.py shell
> (geonode installed systemwide)
> $ geonode shell
> then in the interactive python shell
> Remember to make sure to match the GDAL binary version when you install
> the python bindings pygdal as already suggested by Toni.
> A great resource to improve your confidence to programming GeoNode with
> the interactive shell is the workshop from Paolo Corti:
> Il giorno gio 2 ago 2018 alle ore 12:27 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Toni,
>> Thank you very much for your reply. The problem remains even after your
>> suggested command lines. I will separate a brand new Ubuntu at 16.04LTS
>> machine and see what happens.
>> I appreciated your time and help.
>> Kind regards
>> Julierme
>> 2018-08-02 6:07 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>>> Hi Julierme,
>>> you´re on ubuntu, right? can you check:
>>> $ sudo apt-get install python-gdal gdal-bin libgdal20 libgdal-dev libgdal-devpython-gdal –y
>>> $ pip install pygdal==2.2.1.3
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198
>>> Tel  +49/ (0) 341 24 04 738
>>> Fax  +49/ (0) 341 24 04 73
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> Am 01.08.2018 um 19:12 schrieb geonode-users-request at lists.osgeo.org:
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180802/efd942bf/attachment-0001.html>
More information about the geonode-users mailing list
