[GeoNode-users] GeoNode-Project: migration and createsuperuser (Julierme Pinheiro)
francesco bartoli xbartolone at gmail.com
Thu Aug 2 09:27:05 PDT 2018
Sorry blame myself to made a direct reply in the previous message!
I think probably you have started with too many geonode setups but now just
to figure out this once forever the trick for inheritance is based on the
concept to have geonode (as a library) and geonode-project installed
together in the same virtual environment.
Once you get this then you can replace the geonode references with the same
from the geonode-project.
Hope this helps
Francesco
Il giorno gio 2 ago 2018 alle ore 18:06 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear Francesco,
> Sorry, I am just amazed the way GeoNode is built. You all do a wonderful
> work. I used the term bridge because I have to environments GeoNode
> Production and GeoNode-Project, and I have to connect ( please take the
> term "bridge" out of consideration) these two environments through Apache2
> configuration.
> Just to make sure that I was not doing anything wrong, I installed
> geonode-project at 2.8.0 and geonode-project at 2.6.3.
> I did just one change in site_base.css --> .home .jumbotron { background:
> yellow }
> I ran python manage.py collectstatic
> And Lastly, I did as in <http://geonode.org/dev-workshop/#/8/3>,
> geonode.conf
>  WSGIScriptAlias / /home/sipam_geonode/geonode/geonode/wsgi.py  #
> According to the third line after second "Warning" in
> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html
>      <Directory "/home/sipam_geonode/geonode/geonode/"> # According to the
> fourth bullet point in http://geonode.org/dev-workshop/#/8/3
> #     <Directory "/home/geonode/my_geonode/my_geonode/">
>          <Files wsgi.py>
>              Order deny,allow
>              Allow from all
>              Require all granted
>          </Files>
>         Order allow,deny
>         Options Indexes FollowSymLinks
>         Allow from all
>         IndexOptions FancyIndexing
>     </Directory>
>   <Directory "/home/sipam_geonode/"> # According to the fifth bullet point
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
> Within this configuration, GeoNode Production goes up and runs, but I do
> not see inheritance.  So, I am not connecting them correctly.
> Again I apologize for the term bridge.
> Thank you very much for your time and help.
> Kind regards
> Julierme
> On Thu, Aug 2, 2018 at 12:17 PM, francesco bartoli <xbartolone at gmail.com>
> wrote:
>> Responses inline.
>> Il giorno gio 2 ago 2018 alle ore 15:22 Julierme Pinheiro <
>>> Dear Francesco,
>>> Thank you very much for your reply and resource suggestion. I am taking
>>> a python course and as soon as I finished it, I will devour the information
>>> in http://www.paolocorti.net/foss4g_2017_geonode_solr/.
>>> <http://www.paolocorti.net/foss4g_2017_geonode_solr/>
>>> Regarding Gdalinfo, I have gdal at 2.2.1 and pygdal at 2.2.1.3
>>> geo at gis:~$ gdal-config --version
>>> 2.2.1
>>> 2.2.1
>>> geo at gis:~$ pip show pygdal
>>> Version: 2.2.1.3
>> According to your command you have pygdal installed systemwide which
>> doesn't mean you have it in each of the virtual environments. So for
>> instance:
>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode$ pip freeze
>> |grep -i gdal
>> should tell you that no entry is listed. This means you have to run "pip
>> install pygdal==2.2.1.3"
>>> Before entering to the resource you sent me, let me just give some more
>>> information about what I am trying to do. I created three virtualenv for
>>> GeoNode-Project named by: my_geonode, geonode_project, and sipam_geonode.
>>> Sorry if I am misunderstanding, but I think I can do that without mixing
>>> the requirements  (requirements.txt) for each GeoNode vesrion. Also I
>>> created three users /home/my_geonode; /home/geonode_project and
>>> /home/sipam_geonode.
>>> (my_geonode) geo at gis: /home/my_geonode/my_geonode  # contains
>>> GeoNode-Project at 2.8.0. installed according to the pdf in attached.
>>> Fine. GeoNode is up and running.
>>> One issue only: I collected the static directory by running python
>>> manage.py collectstatic, but I did not see css changes on the index.html.
>>> site_base.css ---> .home .jumbotron { background: yellow }
>>> (geonode_project) geo at gis: /home/geonode_project/my_geonode  # contains
>>> GeoNode-Project at 2.9.0. installed according to
>>> https://github.com/geosolutions-it/geonode-project
>>> Issue1: paver sync
>>> Response:
>>>  pavement.sync
>>>  python -W ignore manage.py makemigrations --noinput
>>> Traceback (most recent call last):
>>>   File "manage.py", line 31, in <module>
>>>     execute_from_command_line(sys.argv)
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 364, in execute_from_command_line
>>>     utility.execute()
>>>   File
>>> line 356, in execute
>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/base.py",
>>> line 283, in run_from_argv
>>>     self.execute(*args, **cmd_options)
>>>   File
>>> line 327, in execute
>>>     self.check()
>>>   File
>>> line 359, in check
>>>     include_deployment_checks=include_deployment_checks,
>>>   File
>>> line 346, in _run_checks
>>>     return checks.run_checks(**kwargs)
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/registry.py",
>>> line 81, in run_checks
>>>     new_errors = check(app_configs=app_configs)
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/urls.py",
>>> line 16, in check_url_config
>>>     return check_resolver(resolver)
>>>   File
>>> line 26, in check_resolver
>>>     return check_method()
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/urls/resolvers.py",
>>> line 254, in check
>>>     for pattern in self.url_patterns:
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/functional.py",
>>> line 35, in __get__
>>>     res = instance.__dict__[self.name] = self.func(instance)
>>>   File
>>> line 405, in url_patterns
>>>     patterns = getattr(self.urlconf_module, "urlpatterns",
>>> self.urlconf_module)
>>>   File
>>> line 35, in __get__
>>>   File
>>> line 398, in urlconf_module
>>>     return import_module(self.urlconf_name)
>>>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>>> import_module
>>>     __import__(name)
>>>   File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24,
>>> in <module>
>>>     from geonode.urls import urlpatterns
>>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py",
>>> line 89, in <module>
>>>     url(r'^catalogue/', include('geonode.catalogue.urls')),
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/conf/urls/__init__.py",
>>> line 50, in include
>>>     urlconf_module = import_module(urlconf_module)
>>> import_module
>>>     __import__(name)
>>>   File
>>> "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
>>> line 22, in <module>
>>>     from . import views
>>>   File
>>> "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
>>> line 29, in <module>
>>>     from pycsw import server
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pycsw/__init__.py",
>>> line 35, in <module>
>>>     __version__ = pkg_resources.require("pycsw")[0].version
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pkg_resources/__init__.py",
>>> line 892, in require
>>>     needed = self.resolve(parse_requirements(requirements))
>>>   File
>>> line 783, in resolve
>>>     raise VersionConflict(dist, req).with_context(dependent_req)
>>> pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
>>> (/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
>>> Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
>>> Captured Task Output:
>>> ---> pavement.sync
>>> Build failed running pavement.sync: Subprocess return code: 1
>>> Issue2: paver start
>>> *Note*: The issue seems to be related to xmltodict version. It is
>>> installed xmltodict 0.9.2, but it requires xmltodict 0.10.2. My concern is
>>> to try to upgrade the requirements version and get everything messed up.
>>> (geonode_project) geo at gis:/home/geonode_project/my_geonode$ pip show
>>> xmltodict
>>> Version: 0.9.2
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/autoreload.py",
>>> line 228, in wrapper
>>>     fn(*args, **kwargs)
>>>   File
>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/commands/runserver.py",
>>> line 124, in inner_run
>>>     self.check(display_num_errors=True)
>>>   File
>>> line 359, in check
>>>   File
>>>   File
>>>   File
>>>   File
>>>   File
>>> line 254, in check
>>>   File
>>> line 35, in __get__
>>>   File
>>>   File
>>> line 35, in __get__
>>>   File
>>> import_module
>>>     __import__(name)
>>> in <module>
>>>   File
>>> line 50, in include
>>> import_module
>>>     __import__(name)
>>>   File
>>>     from . import views
>>>   File
>>>   File
>>>   File
>>>   File
>>> GeoNode is now available.
>>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode  # contains
>>> GeoNode-Project at 2.6.x. installed according to
>>> http://geonode.org/dev-workshop/#/2/3
>>> Issues: python manage.py migrate
>>>            python manage.py createsuperuser
>>>            python manage.py shell
>>> Response:
>>>   File "manage.py", line 29, in <module>
>>>   File
>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 354, in execute_from_command_line
>>>     utility.execute()
>>>   File
>>> line 328, in execute
>>>     django.setup()
>>>   File
>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
>>> line 18, in setup
>>>     apps.populate(settings.INSTALLED_APPS)
>>>   File
>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/registry.py",
>>> line 108, in populate
>>>     app_config.import_models(all_models)
>>>   File
>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/config.py",
>>> line 198, in import_models
>>>     self.models_module = import_module(models_module_name)
>>> import_module
>>>     __import__(name)
>>>   File "/home/sipam_geonode/geonode/geonode/base/models.py", line 56, in
>>> <module>
>>>     from geonode.utils import bbox_to_wkt
>>>   File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in
>>> <module>
>>>     from osgeo import ogr
>>> ImportError: No module named osgeo
>>> What I am doing seems to be crazy (;. But I separated my project in two
>>> parts, in one side I have GeoNode Production working fine and on the other,
>>> I need to have GeoNode-project. My goal is to have geonode-project working
>>> fine and make the connection between them. A bridge project started from
>>> its land edges (;
>> Regardless of the version you have chosen and the corresponding virtual
>> environment please note that you definitively don't need the bridge at all.
>> The scope of geonode-project is right to ease the life of a developer and
>> basically everything is already bridged ;).
>> Just to let's figure out if somehow the workshop is gone to make it
>> confusing can you tell us where did you find such information to the need
>> of a bridge?
>> Maybe we can consider to rewrite that part.
>>> Kind regards
>>> Julierme
>>> On Thu, Aug 2, 2018 at 7:51 AM, francesco bartoli <xbartolone at gmail.com>
>>> wrote:
>>>> Hi Julierme,
>>>> just to give you some quick ways to check what could be wrong.
>>>> Check what GDAL version is installed or it isn't
>>>> $ gdalinfo --version
>>>> Check if the python bindings for GDAL are installed
>>>> (virtual environment)
>>>> $ python manage.py shell
>>>> (geonode installed systemwide)
>>>> $ geonode shell
>>>> then in the interactive python shell
>>>> Remember to make sure to match the GDAL binary version when you install
>>>> the python bindings pygdal as already suggested by Toni.
>>>> A great resource to improve your confidence to programming GeoNode with
>>>> the interactive shell is the workshop from Paolo Corti:
>>>> Il giorno gio 2 ago 2018 alle ore 12:27 Julierme Pinheiro <
>>>>> Hi Toni,
>>>>> Thank you very much for your reply. The problem remains even after
>>>>> your suggested command lines. I will separate a brand new Ubuntu at 16.04LTS
>>>>> machine and see what happens.
>>>>> I appreciated your time and help.
>>>>> Kind regards
>>>>> Julierme
>>>>> 2018-08-02 6:07 GMT-03:00 Toni Schönbuchner <
>>>>> toni.schoenbuchner at csgis.de>:
>>>>>> Hi Julierme,
>>>>>> you´re on ubuntu, right? can you check:
>>>>>> $ sudo apt-get install python-gdal gdal-bin libgdal20 libgdal-dev libgdal-devpython-gdal –y
>>>>>> $ pip install pygdal==2.2.1.3
>>>>>> Cheers,
>>>>>> Toni
>>>>>> CSGIS
>>>>>> Kolonnadenstraße 1
>>>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>>>> 04109 Leipzig
>>>>>> Mobil +49/ (0) 176 6680 3198
>>>>>> Tel  +49/ (0) 341 24 04 738
>>>>>> Fax  +49/ (0) 341 24 04 73
>>>>>> Web http://csgis.de
>>>>>> Hinweis gemäß § 33 BDSG
>>>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument
>>>>>> ist ausschließlich für den
>>>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>>>> diese E-Mail versehentlich
>>>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>>>> löschen Sie diese Nachricht
>>>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>>>> Vervielfältigung, Veränderung,
>>>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>>>> Am 01.08.2018 um 19:12 schrieb geonode-users-request at lists.osgeo.org:
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180802/5908f188/attachment-0001.html>
More information about the geonode-users mailing list
