[GeoNode-users] Geonode-Project: paver sync and paver start issue
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Aug 3 01:50:26 PDT 2018
Hello Julierme,
will try to have a look today.
geonode-project stuff has been now backported to official GeoNode
repositories
https://github.com/GeoNode/geonode-project
Whenever you find issues or want to propose enhancements/improvements, I'd
suggest to open issues directly there in order to keep track of the
dicsussions.
Il giorno mer 1 ago 2018 alle ore 16:58 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear GeoNode users,
> I am setting a new geonode-project in a python virtualenv following [1].
> While running all the command line, paver sync is hitting a error:
> Traceback (most recent call last):
>   File "manage.py", line 31, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 364, in execute_from_command_line
>     utility.execute()
>   File
> line 356, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/base.py",
> line 283, in run_from_argv
>     self.execute(*args, **cmd_options)
>   File
> line 327, in execute
>     self.check()
>   File
> line 359, in check
>     include_deployment_checks=include_deployment_checks,
>   File
> line 346, in _run_checks
>     return checks.run_checks(**kwargs)
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/registry.py",
> line 81, in run_checks
>     new_errors = check(app_configs=app_configs)
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/urls.py",
> line 16, in check_url_config
>     return check_resolver(resolver)
>   File
> line 26, in check_resolver
>     return check_method()
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/urls/resolvers.py",
> line 254, in check
>     for pattern in self.url_patterns:
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/functional.py",
> line 35, in __get__
>     res = instance.__dict__[self.name] = self.func(instance)
>   File
> line 405, in url_patterns
>     patterns = getattr(self.urlconf_module, "urlpatterns",
> self.urlconf_module)
>   File
> line 35, in __get__
>   File
> line 398, in urlconf_module
>     return import_module(self.urlconf_name)
>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> import_module
>     __import__(name)
>   File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24, in
> <module>
>     from geonode.urls import urlpatterns
>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py", line
> 89, in <module>
>     url(r'^catalogue/', include('geonode.catalogue.urls')),
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/conf/urls/__init__.py",
> line 50, in include
>     urlconf_module = import_module(urlconf_module)
> import_module
>     __import__(name)
>   File
> "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
> line 22, in <module>
>     from . import views
>   File
> "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
> line 29, in <module>
>     from pycsw import server
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pycsw/__init__.py",
> line 35, in <module>
>     __version__ = pkg_resources.require("pycsw")[0].version
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pkg_resources/__init__.py",
> line 892, in require
>     needed = self.resolve(parse_requirements(requirements))
>   File
> line 783, in resolve
>     raise VersionConflict(dist, req).with_context(dependent_req)
> pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
> (/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
> Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
> And paver start
> pavement.start
> ---> pavement.start_geoserver
> cd /home/geonode_project/my_geonode/geoserver/data
> java -version
> java version "1.8.0_181"
> Java(TM) SE Runtime Environment (build 1.8.0_181-b13)
> Java HotSpot(TM) 64-Bit Server VM (build 25.181-b13, mixed mode)
> java -Xms512m -Xmx2048m -server -XX:+UseConcMarkSweepGC
> -XX:MaxPermSize=512m
> -DGEOSERVER_DATA_DIR=/home/geonode_project/my_geonode/geoserver/data
> -Dgeofence.dir=/home/geonode_project/my_geonode/geoserver/data/geofence
> -jar
> /home/geonode_project/my_geonode/downloaded/jetty-runner-9.4.7.v20170914.jar
> --port 8080 --log /home/geonode_project/my_geonode/geoserver/jetty.log
> /home/geonode_project/my_geonode/scripts/misc/jetty-runner.xml > /dev/null &
> Starting GeoServer on http://localhost:8080/geoserver/
> Java HotSpot(TM) 64-Bit Server VM warning: ignoring option
> MaxPermSize=512m; support was removed in 8.0
> 2018-08-01 11:43:11.942:INFO::main: Logging initialized @483ms to
> org.eclipse.jetty.util.log.StdErrLog
> 2018-08-01 11:43:11.962:INFO:oejr.Runner:main: Runner
> 2018-08-01 11:43:12.832:INFO:oejs.Server:main: jetty-9.4.7.v20170914
> 2018-08-01 11:43:19.024:INFO:oejs.session:main: DefaultSessionIdManager
> workerName=node0
> 2018-08-01 11:43:19.029:INFO:oejs.session:main: No SessionScavenger set,
> using defaults
> 2018-08-01 11:43:19.032:INFO:oejs.session:main: Scavenging every 660000ms
> ago 01, 2018 11:43:20 AM
> it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
> WARNING: Failed to load the GDAL native libs. This is not a problem unless
> you need to use the GDAL plugins: they won't be enabled.
> java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
> ago 01, 2018 11:43:23 AM org.geoserver.platform.GeoServerExtensions
> checkContext
> WARNING: Extension lookup 'XStreamPersisterInitializer', but
> ApplicationContext is unset.
> checkContext
> WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is
> unset.
> checkContext
> WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is
> unset.
> checkContext
> unset.
> 2018-08-01 11:43:23.501:INFO:oejshC.geoserver:main: Initializing Spring
> root WebApplicationContext
> ago 01, 2018 11:43:40 AM org.geoserver.platform.GeoServerExtensions
> checkContext
> WARNING: Extension lookup 'MonitorDAO', but ApplicationContext is unset.
> checkContext
> unset.
> checkContext
> unset.
> checkContext
> unset.
> ago 01, 2018 11:43:42 AM org.geoserver.platform.GeoServerExtensions
> checkContext
> WARNING: Extension lookup 'GeoServerSecurityProvider', but
> checkContext
> unset.
> checkContext
> unset.
> checkContext
> unset.
> ERROR StatusLogger Log4j2 could not find a logging implementation. Please
> add log4j-core to the classpath. Using SimpleLogger to log to the console...
> Security framework of XStream not initialized, XStream is probably
> vulnerable.
> 2018-08-01 11:44:34.666:INFO:oejsh.ContextHandler:main: Started
> o.e.j.w.WebAppContext at 19bb089b
> {/geoserver,file:///home/geonode_project/my_geonode/geoserver/geoserver/,AVAILABLE}{../geoserver}
> 2018-08-01 11:44:34.676:INFO:oejs.AbstractNCSARequestLog:main: Opened
> 2018-08-01 11:44:34.716:INFO:oejs.AbstractConnector:main: Started
> ServerConnector at 3934e643{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
> 2018-08-01 11:44:34.721:INFO:oejs.Server:main: Started @83260ms
> 2018-08-01 11:44:35.206:INFO:oejshC.geoserver:qtp885284298-13:
> Initializing Spring FrameworkServlet 'dispatcher'
> The logs are available at
> ---> pavement.start_qgis_server
> ---> pavement.start_django
>  python -W ignore manage.py runserver 0.0.0.0:8000 &
> sleep 30
> Performing system checks...
> Unhandled exception in thread started by <function wrapper at
> 0x7f616da7f7d0>
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/autoreload.py",
> line 228, in wrapper
>     fn(*args, **kwargs)
>   File
> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/commands/runserver.py",
> line 124, in inner_run
>     self.check(display_num_errors=True)
>   File
> line 359, in check
>   File
>   File
>   File
>   File
>   File
> line 254, in check
>   File
> line 35, in __get__
>   File
>   File
> line 35, in __get__
>   File
> import_module
>     __import__(name)
> <module>
> 89, in <module>
>   File
> line 50, in include
> import_module
>     __import__(name)
>   File
>     from . import views
>   File
>   File
>   File
>   File
> GeoNode is now available.
> has anyone faced these issues and could give me a hint?
> [1] https://github.com/geosolutions-it/geonode-project
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180803/e5d1a622/attachment-0001.html>
More information about the geonode-users mailing list
