[GeoNode-users] Can't load layers on Geonode without loggin to Geoserver
Jose Cáceres jose.atyus at gmail.com
Wed Dec 5 18:43:19 PST 2018
Hi Alesio,
Thanks for your answer, I actually try to updated Geonode to 2.10 version
using the Deployment Using Docker instructions that you provided in this
link:
https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY/edit
It all goes well up to the point after I run:
docker-compose -f docker-compose.yml -f
docker-compose.override.localhost.yml up
I always got stuck in this point:
rabbitmq4geonode | missed heartbeats from client, timeout: 60s
And I'm not sure if this is due to slow connectivity from my network or
because I messed something up alone the way
Thanks for your help.
Kind Regards,
José
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
05/12/18
20:40:32
On Wed, Dec 5, 2018 at 2:20 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello,
> recently some work has been done both on master and 2.8.x branches in
> order to overcome this issue.
> Now the generation of the thumbnail does not rely on a WMS GetMap request
> anymore but dumps an image locally.
> You should try, if possible, to update your code and align to the latest
> commits.
> Il giorno lun 3 dic 2018 alle ore 16:13 Jose Cáceres <jose.atyus at gmail.com>
> ha scritto:
>> Hi,
>> I have a problem, I have mi geonode site configured to be open, and so
>> people can access the layers and compose maps without need to be logged in
>> into Geonode.
>> My problem is that I cannot load or view any thumbnails of the layers in
>> Geonode, without first login in into geoserver. After I logged in into
>> Geoserver, without loggin in into Geonode, I can access all the layers on
>> Geoserver. See the attached screenshot from how Geonode looks before and
>> after logging in Geoserver.
>> The only layer visible in the first scenario, is one that I uploaded
>> directly using the Geonode upload layer interface, the rest of the layers
>> (88) where uploaded directly into Geoserver in a local PostGIS database and
>> then run 'sudo geonode updatelayers' to incorporate them into Geonode.
>> Is there a way to access the layers without loggin in to Geoserver?
>> I'm running Geonode 2.8 with Geoserver 2.12
>> Kind regards
>> José David Cáceres
>> Ingeniero Ambiental
>> Máster en Tecnologías de la Información Geográfica
>> e-mail: jose.atyus at gmail.com
>> [image: Mailtrack]
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
>> notificado con
>> Mailtrack
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 03/12/18
>> 08:57:36
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
José David Cáceres
Ingeniero Ambiental
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181205/e29b572a/attachment.html>
More information about the geonode-users mailing list
