[GeoNode-users] Error when installing Geonode 2.6 Ubuntu
Franklin, Chris - Perth. CFranklin at rml.com.au
Tue Jan 2 18:45:30 PST 2018
Im installing Geonode 2.6.3 from PPA on Ubuntu 16.04 but keep getting this error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
geonode is already the newest version (2.6.3+thefinal0).
0 to upgrade, 0 to newly install, 0 to remove and 244 not to upgrade.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up geoserver-geonode (2.9.0) ...
Job for tomcat7.service failed because the control process exited with error code. See "systemctl status tomcat7.service" and "journalctl -xe" for details.
dpkg: error processing package geoserver-geonode (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of geonode:
geonode depends on geoserver-geonode | geoserver; however:
Package geoserver-geonode is not configured yet.
Package geoserver is not installed.
dpkg: error processing package geonode (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
geoserver-geonode
geonode
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any ideas what going wrong?
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180103/9553240e/attachment.html>
More information about the geonode-users mailing list
