[GeoNode-users] GeoNode Docker Start Containers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jul 30 00:57:44 PDT 2018
Hello Julierme,
that error is caused by some issue occurring during the startup of the
django machine.
You need to spot which changes you did that might have caused the error.
In order to try to fix it without re-creating the whole VM (and therefore
losing all your changes) you might try to change settings or code directly
on the container volumes.
You can use commands like
docker inspect djangor4geonode
in order to get the volume associated. Then you need to find the volume
location on the local machine and maybe look on the logs in order to
understand what's causing the error.
You should be able to find them into  /var/log/geonode.log   on the docker
volume.
Il giorno ven 27 lug 2018 alle ore 19:30 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear GeoNode Users,
> I am stopping/Starting  the containers nginx4geonode and
> geoserver4geonode  to make changes in the settings and local_settings.py in
> ~/geoode/geonode/*.
> Everything was working fine, but now I am facing a issue:
> django4geonode container won't start-up. <docker ps> always return:
> STATUS Up 5 seconds and most of the time STATUS Restarting (1) 31 seconds
> ago.  It is taking hours and django4geonode does not start.
> Sorry for my lack of knowledge on using docker, but my attempt was to stop
> and start the container, and it never gets started.
> Even with the restarting process, the response in the browser is *502 Bad
> Gateway* / nginx/1.15.0.
> Does anyone have face something similar and could give me a hint on this
> issue?
> nginx4geonode and geoserver4geonode starts, only django4geonode won't
> start-up.
> Thank you very much for your time in advance.
> I appreciated your help
> Kind regards
> Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180730/bba09ce2/attachment.html>
More information about the geonode-users mailing list
