[GeoNode-users] GeoNode Docker Start Containers
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Jul 30 15:16:22 PDT 2018
Dear Francesco and Alessio,
Thank you very much for your reply. I removed geonode directory and I
cloned a new geonode.git. Now I have brand new Docker GeoNode running.
My goal is to configure settings.py and local_settings.py as follow:
1 - Set SITE_HOST and SITE_HOST_PORT
1 - Set ALLOWED_HOST and PROXY_ALLOWED_HOST
2 - Set ACCOUNT E-MAILS
In order to achieve my goal, I did the following:
1 - # I stopped all containers
$ docker stop nginx4geonode django4geonode geoserver4geonode celery4geonode
db4geonode rabbitmq4geonode
2 - # I made a copy of local_settings.py.geoserver.sample as
local_settings.py and a copy of settings.py as settings.py.copy
3 - Before running <docker-compose up -d>, I changed django.env setting
GEONODE_LB_HOST_IP=198.162.0.2 and GEONODE_LB_PORT=80
The site is responding in http://198.162.0.2. I think SITE_HOST and
SITE_HOST_PORT configuration is achieved.
4 - Changing settings.py
4.1 - Changing PROXY_ALLOWED_HOSTS
I added the IP 198.162.0.2  to PROXY_ALLOWED_HOSTS = ['localhost',
'django', 'geonode', '192.168.0.2' ], but django.env also has
PROXY_ALLOWED_HOST and changed it ALLOWED_HOSTS = ['localhost', 'django',
I got confused here. Should I add the IP only into django.env or should I
add it to settings.py too? Or should I add it only to seetings.py?
4.2 settings.py  EMAIL CONFIG
# Define email service on GeoNode
EMAIL_ENABLE = strtobool(os.getenv('EMAIL_ENABLE', 'True'))
if EMAIL_ENABLE:
    EMAIL_BACKEND = os.getenv('DJANGO_EMAIL_BACKEND',
default='django.core.mail.backends.smtp.EmailBackend')
    EMAIL_HOST = 'smtp.sipa.edu'
    EMAIL_PORT = 587
    EMAIL_HOST_USER = 'osgeo.geonode'
    EMAIL_HOST_PASSWORD = 'passwd
    EMAIL_USE_TLS = True
    DEFAULT_FROM_EMAIL = 'osgeo.geonode at sipa.edu'
else:
default='django.core.mail.backends.console.EmailBackend')
ACCOUNT_OPEN_SIGNUP = True
ACCOUNT_APPROVAL_REQUIRED = strtobool(
    os.getenv('ACCOUNT_APPROVAL_REQUIRED', 'True')
ACCOUNT_ADAPTER = 'geonode.people.adapters.LocalAccountAdapter'
ACCOUNT_CONFIRM_EMAIL_ON_GET = True
ACCOUNT_EMAIL_REQUIRED = True
ACCOUNT_EMAIL_VERIFICATION = True
ACCOUNT_EMAIL_CONFIRMATION_EMAIL = True
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = True
4.3 settings.py  SITEURL CONFIG
I got confused in here. As I mentioned in item 3, django.env is set as
GEONODE_LB_HOST_IP=198.162.0.2 and GEONODE_LB_PORT=80. Though SITEURL =
os.getenv('SITEURL', "http://localhost:8000/") in the seetings.py, do I
still have to change it to http://198.162.0.2?
5 - Changing local_settings.py
5.1 - SITEURL CONFIG
I got confused in here. SITEURL is set as SITEURL = "http://localhost/" in
local_settings, but I set GEONODE_LB_HOST_IP=198.162.0.2 and
GEONODE_LB_PORT=80 in django.env. Do I still have to change SITEURL to
SITEURL = "http://198.162.0.2/" in local_settings? Does it make sense to
have the local_settings.py? Or should I use only settings.py? There was not
local_settings.py.sample as used to be for Python virtualenv setup, but I
copied local_settings.py.geoserver.sample as local_settings.py.
5.2 ALLOWED_HOSTS
I set ALLOWED_HOSTS = [HOSTNAME, 'localhost', '198.162.0.2']. The file
django.env does no have settings to ALLOWED_HOSTS, therefore, I think I
have to keep it in local_settings. Am I right?
Could you please give me some insights for the points I got confused?
I appreciated your time in advance
Kind Regards
Julierme
On Mon, Jul 30, 2018 at 5:16 AM, francesco bartoli <xbartolone at gmail.com>
wrote:
> Can you kindly describe a little bit what your are trying to do and also
> share the docker-compose file that it is supposed to run?
> Il giorno ven 27 lug 2018 alle ore 19:30 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear GeoNode Users,
>> I am stopping/Starting  the containers nginx4geonode and
>> geoserver4geonode  to make changes in the settings and local_settings.py in
>> ~/geoode/geonode/*.
>> Everything was working fine, but now I am facing a issue:
>> django4geonode container won't start-up. <docker ps> always return:
>> STATUS Up 5 seconds and most of the time STATUS Restarting (1) 31 seconds
>> ago.  It is taking hours and django4geonode does not start.
>> Sorry for my lack of knowledge on using docker, but my attempt was to
>> stop and start the container, and it never gets started.
>> Even with the restarting process, the response in the browser is *502
>> Bad Gateway* / nginx/1.15.0.
>> Does anyone have face something similar and could give me a hint on this
>> issue?
>> nginx4geonode and geoserver4geonode starts, only django4geonode won't
>> start-up.
>> Thank you very much for your time in advance.
>> I appreciated your help
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180730/9a293ca6/attachment.html>
More information about the geonode-users mailing list
