[GeoNode-users] GeoNode
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed Jun 20 06:18:54 PDT 2018
Hi Simone,
Thank you very much for your reply. I am configuring GeoNode Production
(GP) using GeoNode DevMode (GD). And I am changing all elements in the
index.html (GP) template by editing site_index.html. The reason I am
looking for the index.html in GD is just to take a look at the code, mainly
"showcase" configuration.
I know that I would write a paragraph using the following: <p>{% blocktrans
%} {% endblocktrans %}</p>, but the source code in the browser shows me
this: <p>... </p>
I am in need the index.html just to compare the site_index.html with it.
I appreciated your time and help.
Kind regards
Julierme
On Wed, Jun 20, 2018 at 3:12 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, since you are using a geonode_project you can put it somewhere in the
> site_index.html so that it will override the default geonode index.html.
> The goal of the geonode_project is to let you change all parts of geonode
> without touching the original code.
> Best
> Il giorno mar 19 giu 2018 alle ore 23:07 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi GeoNode developers,
>> I am in need to write a new <section id= "showcase"> for my GeoNode
>> project.
>> I am looking for the index.html file < find . -name index.html> in
>> /home/my_geonode/ and I can not find it.
>> I have the html piece of code bellow, but I need to write it in Django.
>> Could you point me to the index.html path for GeoNode at 2.8.0 installed in
>> a virtualenv in /home/my_geonode/?
>> I appreciated your time.
>> Kind regards
>> Julierme
>> <section id="showcase">    <div class="row">      <div class="container text-center">        <h2>Featured Datasets</h2>        <div class="row home-facets">                           <div class="col-md-6">            <p><a href="/layers/"><i class="fa fa-square-o fa-4x rotate-45"></i></a></p>            <h2><a href="/layers/">No Layers</a></h2>            <p>Click to search for geospatial data published by other users, organizations and public sources. Download data in standard formats.</p>                        <p class="text-center"><a class="btn btn-default" href="/layers/" role="button">Explore layers »</a></p>                      </div>          <div class="col-md-6">            <p><a href="/maps/"><i class="fa fa-map-marker fa-4x"></i></a></p>            <h2><a href="/maps/">No Maps</a></h2>            <p>Data is available for browsing, aggregating and styling to generate maps which can be saved, downloaded, shared publicly or restricted to specify users only.</p>                        <p><a class="btn btn-default" href="/maps/" role="button">Explore maps »</a></p>                      </div>          <div class="col-md-6">            <p><a href="/documents/"><i class="fa fa-newspaper-o fa-4x"></i></a></p>            <h2><a href="/documents/">No Documents</a></h2>            <p>As for the layers and maps GeoNode allows to publish tabular and text data, manage theirs metadata and associated documents.</p>                        <p class="text-center"><a class="btn btn-default" href="/documents/" role="button">Explore documents »</a></p>                      </div>          <div class="col-md-6">            <p><a href="/people/"><i class="fa fa-user fa-4x"></i></a></p>            <h2><a href="/people/">1 User</a></h2>            <p>Geonode allows registered users to easily upload geospatial data and various documents in several formats.</p>            <p><a class="btn btn-default" href="/people/" role="button">See users »</a></p>          </div>                </div>      </div>    </div>    <div class="row">        <div class="container text-center">                        <div ng-app="featured">              <div ng-repeat="item in featured | limitTo:4">                <div class="col-md-3">                  <a href="{{ item.detail_url }}"><img ng-src="{{ item.thumbnail_url }}" /></a>                  <h4>{{ item.title | limitTo: 20 }}{{item.title.length > 20 ? '...' : ''}}</h4>                </div>              </div>            </div>      		            <p><a href="/search/">Explore all datasets</a></p>        </div>    </div>  </section>
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180620/9893696e/attachment-0001.html>
More information about the geonode-users mailing list
