[GeoNode-users] Add Plugins to Geoexplorer Viewer for Geonode
Paolo Corti pcorti at gmail.com
Tue Mar 6 06:46:11 PST 2018
Hi
These are excellent instructions, it would be worth to include them in
the documentation.
One thing which is worth to add: if you need to debug gxp and geoext,
you can set "GEONODE_CLIENT_LOCATION = 'http://localhost:9090/'" in
settings and then run "ant debug". This way you will be able to debug
(for example to add breakpoints) all of the client components. It is
also an handy way to debug your custom plugins and widgets.
cheers
Paolo
On Tue, Mar 6, 2018 at 4:29 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Hi Joshi,
> first thing to do is to update the Javascript code. GeoExplorer used by
> GeoNode is quite far from the original boundless SDK, abandoned several
> years ago.
> The source code can be downloaded here
> https://github.com/GeoNode/geoexplorer
> (be careful to git update the submodules also)
> To add new features and/or plugins you need to modify build.cfg and
> build-debug.cfg
> To rebuild the packages you need to run "ant" from the root folder
> Ant will create two JS files under
> "geoexplorer\build\geoexplorer\WEB-INF\app\static\script"
> 1. GeoExplorer.js is the obfuscated and compacted version
> 2. GeoExplorer-debug.js it the clear version (useful to debug things during
> development)
> To debug the Javascript you can simply change the GeoNode template
> "geo_header.html" and make it pointing to your debug version
> e.g.:
> <!-- script src="{{ STATIC_URL }}geoexplorer/script/GeoExplorer.js?v={{
> VERSION }}" type="text/javascript"></script -->
> <script type="text/javascript"
> src="/path_to_/GeoExplorer-debug.js"></script>
> Once you are happy with your changes and want to create a new version on
> Pypi you need to do two things:
> 1. Commit your updates to https://github.com/GeoNode/geoexplorer
> 2. Commit your new compiled JS files to
> https://github.com/GeoNode/django-geoexplorer into
> https://github.com/GeoNode/django-geoexplorer/tree/master/geoexplorer/static/geoexplorer/script
> 3. Update the version of
> https://github.com/GeoNode/django-geoexplorer/blob/master/setup.py
> 4. Commit the new package on Pypi
> 5. Update the GeoNode dependencies
>  - https://github.com/GeoNode/geonode/blob/master/requirements.txt#L36
>  - https://github.com/GeoNode/geonode/blob/master/setup.py#L134
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-03-06 10:06 GMT+01:00 Joshi, Jigeeshu
> <Jigeeshu.Joshi at ils-forschung.de>:
>> Hi All,
>> I want to add some features in Map viewer (Geoexplorer) in Geonode (like
>> info widget which describes the map/project) . Can anyone guide me how this
>> could be done?
>> From the post I have referred so far I understood that-  we need to build
>> geoexplorer  viewer from Boundless sdk locally. Add/develop all
>> functionalities/plugins required and then integrate/overwrite into Geonode
>> as a new Map Viewer. Is this correct?  Can you provide more info on how this
>> could be achieved.
>> Or is it possible to add plugins directly to the existing geoexplorer in
>> Geonode ? More info... ?
>> I am unable to find sufficient information on internet to go ahead with
>> the task. Your help will be appreciated.
>> Thanks!
>> Jio
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
