[GeoNode-users] Geonode 2.10 rc4 and problems with Geoserver hatch
Jorge Gustavo Rocha jgr at geomaster.pt
Thu Nov 8 02:42:18 PST 2018
Ciao Matteo,
The style is OK and it works well on my Geoserver.
I suspect that you need to install libbatik-java.
Try on the server:
sudo apt install libbatik-java
Some additional packages will be installed.
Report back if this is enough.
Good luck,
Jorge
Às 09:15 de 08/11/18, Matteo Conte escreveu:
> Hi all,
>   I've installed Geoserver 2.14 (inside Geonode 2.10 rc4). When I try to
> create a style with a polygon hatch I get an error on preview. This is my
> style:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <StyledLayerDescriptor version="1.0.0"
>     xsi:schemaLocation="http://www.opengis.net/sld
> StyledLayerDescriptor.xsd"
>     xmlns="http://www.opengis.net/sld>     xmlns:ogc="http://www.opengis.net/ogc>     xmlns:xlink="http://www.w3.org/1999/xlink>     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>   <NamedLayer>
>     <Name>Hatching fill</Name>
>     <UserStyle>
>       <Title>SLD Cook Book: Hatching fill</Title>
>       <FeatureTypeStyle>
>         <Rule>
>           <PolygonSymbolizer>
>             <Fill>
>               <GraphicFill>
>                 <Graphic>
>                   <Mark>
>                     <WellKnownName>shape://horline</WellKnownName>                     <Stroke>
>                       <CssParameter name="stroke">#0000ff</CssParameter>
>                       <CssParameter name="stroke-width">1</CssParameter>
>                     </Stroke>
>                   </Mark>
>                   <Size>16</Size>
>                 </Graphic>
>               </GraphicFill>
>             </Fill>
>           </PolygonSymbolizer>
>         </Rule>
>       </FeatureTypeStyle>
>     </UserStyle>
>   </NamedLayer>
> </StyledLayerDescriptor>
> And this is the error:
> org.apache.wicket.WicketRuntimeException: Method onRequest of interface
> org.apache.wicket.behavior.IBehaviorListener targeted at
> org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1 at 2223b377 on
> component [GeoServerAjaxFormLink [Component id = preview]] threw an
> exception at
> org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:268)
> at
> org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241)
> at
> org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248)
> at
> org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
> at
> org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
> at
> org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
> at
> org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
> at
> org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
> at
> org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
> at
> org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
> at
> org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
> at
> org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:660) at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:741) at
> org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:157)
> at
> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
> at
> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
> at
> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
> at
> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
> at
> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
> at
> org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
> org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:741) at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
> at
> org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53) at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
> at
> at
> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
> at
> at
> at
> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
> at
> org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
> at
> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:83) at
> at
> org.springframework.orm.hibernate3.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:198)
> at
> org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
> at
> at
> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
> at
> at
> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
> at
> at
> at
> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
> at
> at
> at
> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
> at
> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
> at
> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
> at
> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
> at
> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
> at
> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
> at
> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
> at
> at
> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
> at
> at
> at
> at
> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
> at
> at
> at
> org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
> at
> at
> at
> org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:112)
> at
> at
> at
> org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:158)
> at
> at
> at
> at
> org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:176)
> at
> at
> at
> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
> at
> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
> at
> at
> at
> at
> org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
> at
> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
> at
> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
> at
> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
> at
> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
> at
> at
> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90) at
> at
> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at
> at
> at
> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
> at
> at
> at
> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
> at
> at
> at
> org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
> at
> at
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
> at
> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
> at
> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:490)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
> at
> org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:668)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
> at
> org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:408)
> at
> org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
> at
> org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:770)
> at
> org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1415)
> at
> org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
> at
> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
> at
> org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
> at java.lang.Thread.run(Thread.java:748) Caused by:
> java.lang.reflect.InvocationTargetException at
> sun.reflect.GeneratedMethodAccessor1496.invoke(Unknown Source) at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498) at
> org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
> ... 120 more Caused by: java.lang.NoClassDefFoundError:
> org/apache/batik/anim/dom/SAXSVGDocumentFactory at
> org.geotools.renderer.style.RenderableSVGCache.getRenderableSVG(RenderableSVGCache.java:92)
> at
> org.geotools.renderer.style.SVGMarkFactory.getShape(SVGMarkFactory.java:35)
> at
> org.geotools.renderer.style.SLDStyleFactory.getShape(SLDStyleFactory.java:1419)
> at
> org.geotools.renderer.style.SLDStyleFactory.getTexturePaint(SLDStyleFactory.java:1130)
> at
> org.geotools.renderer.style.SLDStyleFactory.getPaint(SLDStyleFactory.java:1087)
> at
> org.geotools.renderer.style.SLDStyleFactory.setPolygonStyleFill(SLDStyleFactory.java:427)
> at
> org.geotools.renderer.style.SLDStyleFactory.createPolygonStyle(SLDStyleFactory.java:383)
> at
> org.geotools.renderer.style.SLDStyleFactory.createStyleInternal(SLDStyleFactory.java:337)
> at
> org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFactory.java:295)
> at
> org.geoserver.wms.legendgraphic.BufferedImageLegendGraphicBuilder.buildLegendGraphic(BufferedImageLegendGraphicBuilder.java:454)
> at
> org.geoserver.wms.web.data.StyleAdminPanel$7.onClick(StyleAdminPanel.java:409)
> at
> org.geoserver.web.wicket.GeoServerAjaxFormLink.onSubmit(GeoServerAjaxFormLink.java:45)
> at
> org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:111)
> at
> org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:215)
> at
> org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:787) at
> org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:171)
> at
> org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
> at
> org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:601)
> ... 124 more
> Can you help me?
> Kind regards
> Matteo
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181108/a27a591a/attachment-0001.html>
More information about the geonode-users mailing list
