[GeoNode-users] Best way to install geonode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Nov 9 05:46:11 PST 2018
Yes, sure.
The instructions are a bit old but still valid.
At most you could experience minor issues with the packages versions.
Il giorno ven 9 nov 2018 alle ore 14:39 Annalisa Schiavon <
annalisa.schiavon at gmail.com> ha scritto:
> Hi Alessio,
> the first time I chose a different password for DB's geonode user. Than I
> change it to geonode in Postgres and run again the paver commands. But
> something is still wrong.
> local_settings seems correct now, maybe it's better if I start to install
> from a clean server.
> Can I follow
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> to install Geonode 2.8 on Ubuntu 16.04 or is outdated/wrong ?
> Because I could install a VM in my local VirtualBox (in ubuntu client
> 16.04) and than test it locally, before migrate the virtual machine in
> VMWARE, it will more simple for me, but I can't with Ubuntu 18.04.
> Moreover, I have some difficulties with Postgres 10, I'd prefer 9.5.
> Thanks again,
> Annalisa
> Il giorno ven 9 nov 2018 alle ore 13:19 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hai Annalisa,
>> it looks to me that you haven't correctly setup the local_settings.py
>> environment variables before running the paver commands.
>> Please double check you have a DB installed with the correct
>> username/password and that the info on local_settings file are correct.
>> Il giorno ven 9 nov 2018 alle ore 12:24 Annalisa Schiavon <
>>> Hi Alessio,
>>> I've tried to follow your document: "GeoNode 2.9.x -Deployment on Ubuntu
>>> 18.04" (
>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
>>> I've installed a brand new ubuntu 18.04 server on our WMWARE.
>>> When I run the command
>>> (geonode) system at gaia:~/geonode$ sudo WORKON_HOME=/home/system/Envs/geonode DJANGO_SETTINGS_MODULE=geonode.local_settings GEONODE_ETC=/home/system/geonode/geonode GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data geonode_updateip -p 192.168.31.80
>>> I have many errors like:
>>> django.db.utils.ProgrammingError: relation "django_site" does not existLINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
>>> and I see that my geonode DB is empty!
>>> I tried to run again
>>> DJANGO_SETTINGS_MODULE=geonode.local_settings paver reset; \
>>>  paver setup; \
>>>  paver sync; \
>>>  python manage.py collectstatic --noinput
>>> I get an error on reset:
>>> [Errno 3] No such process
>>> ---> pavement.stop_qgis_server
>>> but nothing else.
>>> I've have no experience with Virtual Env, so I wonder if all command
>>> after
>>>    mkvirtualenv --no-site-packages geonode
>>> are to run in virtual env or not.
>>> I found another error after running "  pip install -r requirements.txt
>>> --upgrade--no-cache --no-cache-dir ":
>>> Command "python setup.py egg_info" failed with error code 1 in
>>> /tmp/pip-install-6qw4Pu/Twisted/
>>> Any suggestions?
>>> Annalisa
>>> Il giorno ven 26 ott 2018 alle ore 16:38 Alessio Fabiani <
>>>> Uhm... well, that command should install the GeoNode dependencies.
>>>> Maybe this is the reason why you are not able to find some packages.
>>>> Anyway, you must run paver reset from the "my_geonode" root folder,
>>>> where the "pavement.py" file is located. If you already did that, then I
>>>> guess your installation is a bit messed up.
>>>> Il giorno ven 26 ott 2018 alle ore 16:24 Paulo Frias <
>>>> pfrias82 at gmail.com> ha scritto:
>>>>> Yes, but after that I had to downgrade some python packages.
>>>>> On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> From the link you sent to me, did you run also this one?
>>>>>> pip install -e . --upgrade
>>>>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <
>>>>>>> I've followed this instructions
>>>>>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>>>>>> After "pip install Paver==1.2.4"
>>>>>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver
>>>>>>> reset
>>>>>>> Build failed: Unknown task: reset
>>>>>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>>>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>>>>>> However, it seems to me that the issue is related to a missing
>>>>>>>> dependency.
>>>>>>>> Try maybe by typing
>>>>>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <
>>>>>>>>> Hi Alessio,
>>>>>>>>> The  (pip install -r requirements.txt --upgrade) worked fine
>>>>>>>>> after another try.
>>>>>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>>>>>> This is the error produced:
>>>>>>>>> paver reset
>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>   File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line
>>>>>>>>> 7, in <module>
>>>>>>>>>     from paver.tasks import main
>>>>>>>>> ImportError: No module named paver.tasks
>>>>>>>>> Any idea how to solve this?
>>>>>>>>> Thanks,
>>>>>>>>> Paulo
>>>>>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>>>>>> Hi Paulo,
>>>>>>>>>> can you describe what's happening with a bit more detail?
>>>>>>>>>> That command should just start downloading the Python
>>>>>>>>>> dependencies. If it is stuck, most probably there's a problem reaching the
>>>>>>>>>> PyPi repositories.
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>> I'm trying to install Geonode on Mac os X, following the
>>>>>>>>>>> tutorial you recommended (
>>>>>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>>>>>> Can you help me with some possible solution?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Paulo Frias
>>>>>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>>>>>> Hi Julierme,
>>>>>>>>>>>> please see my responses below.
>>>>>>>>>>>> "1 - can I make geonode-project my production environment? I
>>>>>>>>>>>> meant run GeoNode-Project as my production instance on the web."
>>>>>>>>>>>> Sure, but you will need to tweak a bit security options and
>>>>>>>>>>>> settings in order to secure and optimize your instance. Especially
>>>>>>>>>>>> important are the admin passwords and openid keys. This is valid in any
>>>>>>>>>>>> case though.
>>>>>>>>>>>> "2 -  do I need GeoNode Core to run together with
>>>>>>>>>>>> GeoNode-Project?"
>>>>>>>>>>>> geonode-project makes use of geonode-core as a dependency.
>>>>>>>>>>>> Until we do final releases (2.10 and 2.8), meaning that packages will go on
>>>>>>>>>>>> Pypi repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode
>>>>>>>>>>>> Core?"
>>>>>>>>>>>> geonode-project runs independently, but it still needs
>>>>>>>>>>>> geonode as a dependency. However by using it, you won't touch the
>>>>>>>>>>>> geonode-core. This will allow you to easily keep it up to date with the
>>>>>>>>>>>> development version, without clashes.
>>>>>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>>>>>> The tutorial and the documentation in general is outdated. We
>>>>>>>>>>>> are lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>>>>>> We will try to do it when we start officially the release
>>>>>>>>>>>> process.
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>>>>>> look.
>>>>>>>>>>>>> Now:
>>>>>>>>>>>>> GeoNode-Project?
>>>>>>>>>>>>> Core?
>>>>>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>>>>>> Kind regards
>>>>>>>>>>>>> Julierme
>>>>>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>>>>>>> Thanks for the tip!
>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most
>>>>>>>>>>>>>>> buggy and unstable one.
>>>>>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way
>>>>>>>>>>>>>>> to customize the interface, at least some part of it, without the need of
>>>>>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin
>>>>>>>>>>>>>>> gui.
>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>>>>>> So you advise against the deb package installation, also if
>>>>>>>>>>>>>>>> I don't think to develop on geonode,  only to customize the look?
>>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>>>>>> If you want to install geonode for development, I would
>>>>>>>>>>>>>>>>> suggest following the procedure here
>>>>>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>>>>>>> If you want to start customizing your own portal (but
>>>>>>>>>>>>>>>>> still develop it), I would suggest starting from a geonode-project
>>>>>>>>>>>>>>>>> template. In that case, follow the instructions here
>>>>>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant
>>>>>>>>>>>>>>>>> or docker. There are several ways and configurations around that you might
>>>>>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon
>>>>>>>>>>>>>>>>> <annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>>> Please someone may confirm that installation by deb
>>>>>>>>>>>>>>>>>> packages, with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at
>>>>>>>>>>>>>>>>>> now?)
>>>>>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>>>>>>> installation (
>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa
>>>>>>>>>>>>>>>>>> Schiavon <annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04,
>>>>>>>>>>>>>>>>>>> installed via apt-get, following these commands:
>>>>>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes
>>>>>>>>>>>>>>>>>>> in logos, colors and so on:
>>>>>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>>>>>>  -epy,rst
>>>>>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to
>>>>>>>>>>>>>>>>>>> 2.8 (jumping the 2.6 release)?
>>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>>>>> This email is intended only for the person or entity to
>>>>>>>>>>>>>>>>> which it is addressed and may contain information that is privileged,
>>>>>>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> notizia.
>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/6340019a/attachment-0001.html>
More information about the geonode-users mailing list
