[GeoNode-users] (no subject)
TC Haddad tchaddad at gmail.com
Thu Nov 22 02:33:22 PST 2018
Hi all,
I need some help with a Geonode dependency issue on Ubuntu 16.04.5 LTS.
When I try to do apt-get upgrade, I get the following:
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
geonode : Depends: python-gn-gsimporter but it is not installed
          Depends: python-django-bootstrap3-datetimepicker-2 but it is not
installed
          Depends: python-python-memcached but it is not installed
E: Unmet dependencies. Try using -f.
Then when I try to do apt-get -f install, I get the following:
Correcting dependencies... Done
The following additional packages will be installed:
 python-django-bootstrap3-datetimepicker-2 python-gn-gsimporter
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
Need to get 0 B/26.6 kB of archives.
After this operation, 143 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 196241 files and directories currently installed.)
Preparing to unpack .../python-gn-gsimporter_1.0.2-1_all.deb ...
Unpacking python-gn-gsimporter (1.0.2-1) ...
dpkg: error processing archive
/var/cache/apt/archives/python-gn-gsimporter_1.0.2-1_all.deb (--unpack):
trying to overwrite '/usr/lib/python2.7/dist-packages/gsimporter/_util.py',
which is also in package python-gsimporter 1.0.0-1
Preparing to unpack
.../python-django-bootstrap3-datetimepicker-2_2.5.0-1_all.deb ...
Unpacking python-django-bootstrap3-datetimepicker-2 (2.5.0-1) ...
/var/cache/apt/archives/python-django-bootstrap3-datetimepicker-2_2.5.0-1_all.deb
(--unpack):
trying to overwrite
'/usr/lib/python2.7/dist-packages/bootstrap3_datetime/__init__.py', which
is also in package python-django-bootstrap3-datetimepicker 2.2.3.0-1
Preparing to unpack .../python-python-memcached_1.59-1_all.deb ...
Unpacking python-python-memcached (1.59-1) ...
/var/cache/apt/archives/python-python-memcached_1.59-1_all.deb (--unpack):
trying to overwrite '/usr/lib/python2.7/dist-packages/memcache.py', which
is also in package python-memcache 1.57-1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any ideas how I can resolve this?
Tanya
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181122/8be96d76/attachment.html>
More information about the geonode-users mailing list
