[GeoNode-users] Zoom to layer extend does not work (Paulo Frias)
Matteo Conte matteo.conte at abitat.it
Tue Oct 2 00:23:28 PDT 2018
Hi Alessio,
If you can do it would be greatly appreciated. I tried much times to install geonode following http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html instructions but every time some error block me.
Kind Regards
Matteo
Da: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
A: "matteo.conte" <matteo.conte at abitat.it>
Cc: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>, "geonode-users" <geonode-users at lists.osgeo.org>
Inviato: Lunedì, 1 ottobre 2018 16:10:13
Oggetto: Re: [GeoNode-users] Zoom to layer extend does not work (Paulo Frias)
Uhm,
I'm not aware of an "official" documentation page to do that. If you are not in a hurry, I can devote some time creating one.
Il giorno lun 1 ott 2018 alle ore 16:01 Matteo Conte < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] > ha scritto:
Hi Alessio,
yes I used apt-get to install geonode. Where I can find informations about these ways?
Kind regards
Matteo
Da: "Alessio Fabiani" < [ mailto:alessio.fabiani at geo-solutions.it | alessio.fabiani at geo-solutions.it ] >
A: "matteo.conte" < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] >
Cc: "Alessio Fabiani" < [ mailto:alessio.fabiani at geo-solutions.it | alessio.fabiani at geo-solutions.it ] >, "geonode-users" < [ mailto:geonode-users at lists.osgeo.org | geonode-users at lists.osgeo.org ] >
Inviato: Lunedì, 1 ottobre 2018 14:18:35
Do you mean by using "apt-get" package?
If so, yes, there are ways to update it manually, but it won't be straight not easy to achieve unfortunately.
Il giorno lun 1 ott 2018 alle ore 12:27 Matteo Conte < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] > ha scritto:
BQ_BEGIN
Hi Alessio,
I've installed geonode from quick install. Is possible to keep update this type of installation?
Kind regards,
Matteo
Cc: "geonode-users" < [ mailto:geonode-users at lists.osgeo.org | geonode-users at lists.osgeo.org ] >
Inviato: Venerdì, 28 settembre 2018 10:40:53
Dear all,
this issue has been already fixed on the latest versions. You should try to update your instance to the latest ones.
If you want to give it a try, you can try this very easy setup and test it locally:
[ https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project | https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project ]
There are also ways to deploy this on a public instance:
[ https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#start-your-server | https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#start-your-server ]
[ https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#if-you-want-to-run-the-instance-on-a-public-site | https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#if-you-want-to-run-the-instance-on-a-public-site ]
quite straightforward.
The advantages of those approaches are that:
1. You will have up-to-date GeoNode and GeoServer versions
2. You will be able to keep GeoNode updates in the future
Il giorno ven 28 set 2018 alle ore 10:07 Matteo Conte < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] > ha scritto:
BQ_BEGIN
I have same issue. Geoserver layer preview work fine.
Kind regards
Matteo
geonode-users mailing list
[ https://lists.osgeo.org/mailman/listinfo/geonode-users | https://lists.osgeo.org/mailman/listinfo/geonode-users ]
GeoServer Professional Services from the experts! Visit [ http://goo.gl/it488V | http://goo.gl/it488V ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
[ http://www.geo-solutions.it/ | http://www.geo-solutions.it ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
BQ_END
@alfa7691
GeoSolutions S.A.S.
BQ_END
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181002/e399a75c/attachment-0001.html>
More information about the geonode-users mailing list
