[GeoNode-users] basic authentication with GeoNode 2.8, GeoServer 2.14 and GeoFence
Paolo Corti pcorti at gmail.com
Wed Oct 3 06:44:59 PDT 2018
Yes, you are right Alessio, that was!
I upgraded the staging a few days ago and forgot to add the line with
ip for GeoServer in the Django OAuth Toolkit application table. Now
GetCapabilities works well again.
Sorry for the noise and thanks again :)
p
On Wed, Oct 3, 2018 at 4:24 AM Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> By the way,
> I noticed that http://128.31.22.103/geoserver Layer Preview is empty.
> As long as this is happening that means that there's some misconfiguration on your security settings.
> Moreover, any chance to update the WAR of GeoServer with the latest build here?
> http://build.geonode.org/geoserver/latest/geoserver-2.14.x.war
> Il giorno mer 3 ott 2018 alle ore 10:16 Alessio Fabiani <alessio.fabiani at geo-solutions.it> ha scritto:
>> Hi Paolo,
>> yeps, it is quite strange indeed.
>> It really looks to me that it is due to GeoFence rules somehow. Sometimes the rules of GeoFence could be a bit tricky.
>> Any chance to send here all the rules associated to one of those layers?
>> Il giorno mer 3 ott 2018 alle ore 01:03 Paolo Corti <pcorti at gmail.com> ha scritto:
>>> Hi Alessio
>>> all of the layers in our instance are published and advertised on GeoServer.
>>> For example try this layer in our staging instance.
>>> Layer details page in GeoNode:
>>> http://128.31.22.103/layers/geonode:Neighborhoods_BRA_1
>>> Layer GetCapabilities:
>>> http://128.31.22.103/geoserver/geonode/Neighborhoods_BRA_1/wms?service=WMS&request=GetCapabilities
>>> The layer GetCapabilities is correctly returned when I am logged as
>>> GeoServer admin, but it returns a 404 when I am not.
>>> Thanks for your help!
>>> Paolo
>>> On Tue, Oct 2, 2018 at 4:28 PM Alessio Fabiani
>>> > Hi Paolo,
>>> > it is working here. Remember that the Layer must be published too, which means "Advertised" on GeoServer.
>>> > Il giorno mar 2 ott 2018 alle ore 22:13 Paolo Corti <pcorti at gmail.com> ha scritto:
>>> >> Hi Alessio
>>> >> the url I am using it is correct. If I open it in an authenticated
>>> >> browser (logged in as GeoServer admin), it returns the correct
>>> >> GetCapabilities document.
>>> >> Unfortunately it is not working from a not authenticated sessions. I
>>> >> believe GeoFence is not giving access to the layer.
>>> >> I realized that in my previous email I didn't include the correct link
>>> >> to the log file https://paste.ofcode.org/3aBryGaRK7Xz3j3ySqXxfkN
>>> >> hope this helps you to suggest a solution to this problem
>>> >> thanks!
>>> >> Paolo
>>> >> On Tue, Oct 2, 2018 at 3:45 PM Alessio Fabiani
>>> >> > As an instance
>>> >> > http://dev.geonode.geo-solutions.it/geoserver/geonode/states/wms?request=GetCapabilities
>>> >> > Il giorno mar 2 ott 2018 alle ore 21:16 Paolo Corti <pcorti at gmail.com> ha scritto:
>>> >> >> Dear list
>>> >> >> This is most likely for Alessio, but maybe someone else in the list can help.
>>> >> >> I am experiencing this in GeoNode 2.8 and GeoServer 2.14.
>>> >> >> I would need to access GeoServer OGC endpoints with curl or owslib
>>> >> >> using basic authentication. Unfortunately this doesn't look to work
>>> >> >> anymore - while it was working on previous versions GeoNode/GeoServer.
>>> >> >> This is a sample request I do:
>>> >> >> curl -v -u user:password -XGET -H "Accept: text/xml"
>>> >> >> http://myip/geoserver/geonode/layername/wms
>>> >> >> I receive a 404.
>>> >> >> Here is what I see in GeoServer log file: https://paste.ofcode.org/
>>> >> >> When opening the same url in a web browser authenticated with GeoNode
>>> >> >> I don't get the 404.
>>> >> >> Any hint here? Thanks in advance!
>>> >> >> Paolo
>>> >> >> Paolo Corti
>>> >> >> Geospatial software developer
>>> >> >> web: http://www.paolocorti.net
>>> >> >> twitter: @capooti
>>> >> >> skype: capooti
>>> >> >> _______________________________________________
>>> >> >> geonode-users mailing list
>>> >> >> geonode-users at lists.osgeo.org
>>> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> >> > GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
>>> >> > Ing. Alessio Fabiani
>>> >> > @alfa7691
>>> >> > Founder/Technical Lead
>>> >> > GeoSolutions S.A.S.
>>> >> > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> >> > phone: +39 0584 962313
>>> >> > fax:     +39 0584 1660272
>>> >> > mob:   +39 331 6233686
>>> >> > http://www.geo-solutions.it
>>> >> > http://twitter.com/geosolutions_it
>>> >> > Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> >> > This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
>>> >> Paolo Corti
>>> >> twitter: @capooti
>>> >> skype: capooti
>>> > @alfa7691
>>> > GeoSolutions S.A.S.
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
>> @alfa7691
>> GeoSolutions S.A.S.
> @alfa7691
> GeoSolutions S.A.S.
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
