[GeoNode-users] gs-geofence-server : cannot be resolved to absolute file path
francesco bartoli xbartolone at gmail.com
Tue Oct 16 08:06:31 PDT 2018
Hi Eduin,
I'm facing with failures to start on 2.12.x but 2.14.x (2.13.x as well) is
working from my tests. Can you double check with 2.14.x in a clean tomcat
instance?
Thanks,
Francesco
Il giorno mar 16 ott 2018 alle ore 16:32 Eduin Yezid Carrillo Vega <
ecarrillo at umaic.org> ha scritto:
> Thank you Alessio.
> Geoserver did´t start. It hangs. It starts again when
> gs-geofence-server-xx.xx.jar is removed from WEB-INF, but no layer is
> displayed due to lack of permissions server.
> El jue., 11 de oct. de 2018 a la(s) 02:42, Alessio Fabiani (
> alessio.fabiani at geo-solutions.it) escribió:
>> It is just a warning. As long ad GeoServer starts correctly, you can just
>> ignore it.
>> Il giorno mer 10 ott 2018 alle ore 21:28 Eduin Yezid Carrillo Vega <
>>> Thanks for run up build server again. Now I´m getting this error with
>>> geofence server. This error had been reported last year to this list, but I
>>> tested with Geonode 2.8x and 2.10x and it looks same response.
>>> Primary log looks like WARNING for geofence-default-override.properties
>>> file not found but whole TOMCAT stopped working
>>> - If i delete /WEB-INF/lib/gs-geofence-server-xx.xx.jar, error gone, but
>>> layers do not load
>>> - If I restore jar to /WEB-INF/lib/, error returns
>>> Tested in ubuntu with custom:
>>> * geonode.git at 2.8 + geoserver-2.12.x
>>> * geonode.git at 2.10rc4 + geoserver-2.14.x
>>> Thanks for your help
>>>  WARN [geoserver.config] - Error reading resource URL
>>> [jar:file:/usr/share/geoserver214/WEB-INF/lib/gs-geofence-server-2.14-20181006.100834-490.jar!/geofence-default-override.properties]
>>> java.io.FileNotFoundException: URL
>>> cannot be resolved to absolute file path because it does not reside in the
>>> file system:
>>>         at
>>> org.springframework.util.ResourceUtils.getFile(ResourceUtils.java:215)
>>>         at
>>> org.springframework.core.io.AbstractFileResolvingResource.getFile(AbstractFileResolvingResource.java:53)
>>>         at
>>> org.springframework.core.io.UrlResource.getFile(UrlResource.java:213)
>>>         at
>>> org.geoserver.config.SpringResourceAdaptor.relative(SpringResourceAdaptor.java:35)
>>>         at
>>> org.geoserver.config.GeoServerPropertyOverrideConfigurer.setLocations(GeoServerPropertyOverrideConfigurer.java:49)
>>>         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>         at
>>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
>>>         at
>>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
>>>         at java.lang.reflect.Method.invoke(Method.java:498)
>>>         at
>>> org.springframework.beans.BeanWrapperImpl$BeanPropertyHandler.setValue(BeanWrapperImpl.java:354)
>>>         at
>>> org.springframework.beans.AbstractNestablePropertyAccessor.processLocalProperty(AbstractNestablePropertyAccessor.java:467)
>>>         at
>>> org.springframework.beans.AbstractNestablePropertyAccessor.setPropertyValue(AbstractNestablePropertyAccessor.java:290)
>>>         at
>>> org.springframework.beans.AbstractNestablePropertyAccessor.setPropertyValue(AbstractNestablePropertyAccessor.java:278)
>>>         at
>>> org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:95)
>>>         at
>>> org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:75)
>>>         at
>>> org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1570)
>>>         at
>>> org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1284)
>>>         at
>>> org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
>>>         at
>>> org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483)
>>>         at
>>> org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:312)
>>>         at
>>> org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
>>>         at
>>> org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:308)
>>>         at
>>> org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
>>>         at
>>> org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:151)
>>>         at
>>> org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:687)
>>>         at
>>> org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:525)
>>>         at
>>> org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443)
>>>         at
>>> org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325)
>>>         at
>>> org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
>>>         at
>>> org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
>>>         at
>>> org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5068)
>>>         at
>>> org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5584)
>>>         at
>>> org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
>>>         at
>>> org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
>>>         at
>>> org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
>>>         at
>>> org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
>>>         at
>>> org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:677)
>>>         at
>>> org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1962)
>>>         at
>>> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
>>>         at java.util.concurrent.FutureTask.run(FutureTask.java:266)
>>>         at
>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
>>>         at
>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
>>>         at java.lang.Thread.run(Thread.java:748)
>>> oct 10, 2018 2:02:36 PM org.geoserver.platform.GeoServerExtensions
>>> checkContext
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181016/0e149b6e/attachment-0001.html>
More information about the geonode-users mailing list
