[GeoNode-users] Best way to install geonode
Paulo Frias pfrias82 at gmail.com
Fri Oct 26 07:18:58 PDT 2018
I've followed this instructions
https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
After "pip install Paver==1.2.4"
(Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
Build failed: Unknown task: reset
On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Uhm, that is very strange. How did you setup GeoNode?
> However, it seems to me that the issue is related to a missing dependency.
> Try maybe by typing
> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com>
> ha scritto:
>> Hi Alessio,
>> The  (pip install -r requirements.txt --upgrade) worked fine after
>> another try.
>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>> This is the error produced:
>> Traceback (most recent call last):
>>   File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>> <module>
>>     from paver.tasks import main
>> ImportError: No module named paver.tasks
>> Any idea how to solve this?
>> Thanks,
>> Paulo
>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>> Hi Paulo,
>>> can you describe what's happening with a bit more detail?
>>> That command should just start downloading the Python dependencies. If
>>> it is stuck, most probably there's a problem reaching the PyPi repositories.
>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <pfrias82 at gmail.com>
>>> ha scritto:
>>>> Hi Alessio,
>>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>>> recommended (
>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>> When I run the command
>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>> Can you help me with some possible solution?
>>>> Thanks,
>>>> Paulo Frias
>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>> Hi Julierme,
>>>>> please see my responses below.
>>>>> "1 - can I make geonode-project my production environment? I meant run
>>>>> GeoNode-Project as my production instance on the web."
>>>>> Sure, but you will need to tweak a bit security options and settings
>>>>> in order to secure and optimize your instance. Especially important are the
>>>>> admin passwords and openid keys. This is valid in any case though.
>>>>> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
>>>>> geonode-project makes use of geonode-core as a dependency. Until we do
>>>>> final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>>>> geonode-project runs independently, but it still needs geonode as a
>>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>>> will allow you to easily keep it up to date with the development version,
>>>>> without clashes.
>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>>>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>> The tutorial and the documentation in general is outdated. We are
>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>> cleanup it. I'm very sorry about that.
>>>>> We will try to do it when we start officially the release process.
>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>> Hi Alessio,
>>>>>> I would like to make some questions related to Annalisa's
>>>>>> installation question. I installed geonode-project only to customize the
>>>>>> look.
>>>>>> Now:
>>>>>> Thank you very much for your time in advance
>>>>>> Kind regards
>>>>>> Julierme
>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>> Thanks for the tip!
>>>>>>> Annalisa
>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>>>>>>> and unstable one.
>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>> changing the files or the templates.
>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>> Ok, thank you so much.
>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>> don't think to develop on geonode,  only to customize the look?
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>>>> following the procedure here
>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>> want to evaluate.
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>>> What advantages does have VM Setup with VirtualBox installation (
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>>>>> Because in https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>> Annalisa
>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>> Hi all.
>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>> production, currently?
>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>>>>> apt-get, following these commands:
>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>  -epy,rst
>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>> Thank you,
>>>>>>>>>>>> Annalisa
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/cd1b88e8/attachment-0001.html>
More information about the geonode-users mailing list
