[GeoNode-users] Best way to install geonode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Oct 26 07:38:26 PDT 2018
Uhm... well, that command should install the GeoNode dependencies. Maybe
this is the reason why you are not able to find some packages.
Anyway, you must run paver reset from the "my_geonode" root folder, where
the "pavement.py" file is located. If you already did that, then I guess
your installation is a bit messed up.
Il giorno ven 26 ott 2018 alle ore 16:24 Paulo Frias <pfrias82 at gmail.com>
ha scritto:
> Yes, but after that I had to downgrade some python packages.
> On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> From the link you sent to me, did you run also this one?
>> pip install -e . --upgrade
>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>>> I've followed this instructions
>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>> After "pip install Paver==1.2.4"
>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver
>>> reset
>>> Build failed: Unknown task: reset
>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>> However, it seems to me that the issue is related to a missing
>>>> dependency.
>>>> Try maybe by typing
>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <
>>>> pfrias82 at gmail.com> ha scritto:
>>>>> Hi Alessio,
>>>>> The  (pip install -r requirements.txt --upgrade) worked fine after
>>>>> another try.
>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>> This is the error produced:
>>>>> reset
>>>>> Traceback (most recent call last):
>>>>>   File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7,
>>>>> in <module>
>>>>>     from paver.tasks import main
>>>>> ImportError: No module named paver.tasks
>>>>> Any idea how to solve this?
>>>>> Thanks,
>>>>> Paulo
>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>> Hi Paulo,
>>>>>> can you describe what's happening with a bit more detail?
>>>>>> That command should just start downloading the Python dependencies.
>>>>>> If it is stuck, most probably there's a problem reaching the PyPi
>>>>>> repositories.
>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>> Hi Alessio,
>>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial
>>>>>>> you recommended (
>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>>> When I run the command
>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>> Can you help me with some possible solution?
>>>>>>> Thanks,
>>>>>>> Paulo Frias
>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>> Hi Julierme,
>>>>>>>> please see my responses below.
>>>>>>>> "1 - can I make geonode-project my production environment? I meant
>>>>>>>> run GeoNode-Project as my production instance on the web."
>>>>>>>> Sure, but you will need to tweak a bit security options and
>>>>>>>> settings in order to secure and optimize your instance. Especially
>>>>>>>> important are the admin passwords and openid keys. This is valid in any
>>>>>>>> case though.
>>>>>>>> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
>>>>>>>> geonode-project makes use of geonode-core as a dependency. Until we
>>>>>>>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode
>>>>>>>> Core?"
>>>>>>>> geonode-project runs independently, but it still needs geonode as a
>>>>>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>>>> without clashes.
>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>> We will try to do it when we start officially the release process.
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>>> Hi Alessio,
>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>> look.
>>>>>>>>> Now:
>>>>>>>>> Core?
>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>> Kind regards
>>>>>>>>> Julierme
>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>>> Thanks for the tip!
>>>>>>>>>> Annalisa
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most
>>>>>>>>>>> buggy and unstable one.
>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>>>> don't think to develop on geonode,  only to customize the look?
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>> If you want to install geonode for development, I would
>>>>>>>>>>>>> suggest following the procedure here
>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>>> installation (
>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed
>>>>>>>>>>>>>>> via apt-get, following these commands:
>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>>  -epy,rst
>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>>>>> it is addressed and may contain information that is privileged,
>>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> notizia.
>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/d045b948/attachment-0001.html>
More information about the geonode-users mailing list
