[GeoNode-users] Best way to install geonode
Paulo Frias pfrias82 at gmail.com
Fri Oct 26 08:04:22 PDT 2018
Yes, with OSX. I had also issues with gdal and because of that I'm trying
with Anaconda to set the virtual environment and to install gdal through
"conda install gdal".
On Fri, 26 Oct 2018 at 15:58, Toni Schönbuchner <toni.schoenbuchner at csgis.de>
wrote:
> Great.
> Are you on OSX? If so I’ ve lately had some issues with brew packages /
> gdal.
> Let me know if you encounter further dependency errors.
> Cheers,
> Toni
> Am 26.10.2018 um 16:53 schrieb Paulo Frias <pfrias82 at gmail.com>:
> Probably a good shot in the dark.  I've named it "geonode" and not
> "my_genode" but I just erased the virtual environment to start over again.
> On Fri, 26 Oct 2018 at 15:42, Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Hi Paulo,
>> Just a shot in the dark.
>> When you started your project from template did you name it my_geonode?
>> If not you should double check to use the correct settings:
>> DJANGO_SETTINGS_MODULE=*your_namend_geonode.settings *paver reset
>> Cheers,
>> Toni
>> Am 26.10.2018 um 16:21 schrieb geonode-users-request at lists.osgeo.org:
>> Send geonode-users mailing list submissions to
>> geonode-users at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> geonode-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-users digest..."
>> Today's Topics:
>>   1. Re: Best way to install geonode (Alessio Fabiani)
>> Message: 1
>> Date: Fri, 26 Oct 2018 16:21:38 +0200
>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>> To: Paulo Frias <pfrias82 at gmail.com>
>> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>,  geonode-users
>> <geonode-users at lists.osgeo.org>
>> Subject: Re: [GeoNode-users] Best way to install geonode
>> Message-ID:
>> <CAM7ZvLLpVZXQauUZ9OmQNZLWB6iCtP=BP-cK82HDgUNvsLgZUQ at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> From the link you sent to me, did you run also this one?
>> pip install -e . --upgrade
>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>> I've followed this instructions
>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>> After "pip install Paver==1.2.4"
>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
>> Build failed: Unknown task: reset
>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>> Uhm, that is very strange. How did you setup GeoNode?
>> However, it seems to me that the issue is related to a missing dependency.
>> Try maybe by typing
>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>> Hi Alessio,
>> The  (pip install -r requirements.txt --upgrade) worked fine after
>> another try.
>> Now I'm stucked in the command
>> (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>> This is the error produced:
>> reset
>> Traceback (most recent call last):
>>  File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>> <module>
>>    from paver.tasks import main
>> ImportError: No module named paver.tasks
>> Any idea how to solve this?
>> Thanks,
>> Paulo
>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>> Hi Paulo,
>> can you describe what's happening with a bit more detail?
>> That command should just start downloading the Python dependencies. If
>> it is stuck, most probably there's a problem reaching the PyPi
>> repositories.
>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>> pfrias82 at gmail.com> ha scritto:
>> Hi Alessio,
>> I'm trying to install Geonode on Mac os X, following the tutorial you
>> recommended (
>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>> When I run the command
>> Nothing happens (I let it run on terminal for more than 2 hours).
>> Can you help me with some possible solution?
>> Thanks,
>> Paulo Frias
>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>> Hi Julierme,
>> please see my responses below.
>> "1 - can I make geonode-project my production environment? I meant
>> run GeoNode-Project as my production instance on the web."
>> Sure, but you will need to tweak a bit security options and settings
>> in order to secure and optimize your instance. Especially important are
>> the
>> admin passwords and openid keys. This is valid in any case though.
>> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
>> geonode-project makes use of geonode-core as a dependency. Until we
>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>> repositories, yes, you'll need the geonode-core among the python deps.
>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>> geonode-project runs independently, but it still needs geonode as a
>> dependency. However by using it, you won't touch the geonode-core. This
>> will allow you to easily keep it up to date with the development version,
>> without clashes.
>> "4 - If I am not misunderstanding, the tutorial in here <
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>> The tutorial and the documentation in general is outdated. We are
>> lacking of resources and, unfortunately, we did not found time yet to
>> cleanup it. I'm very sorry about that.
>> We will try to do it when we start officially the release process.
>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Alessio,
>> I would like to make some questions related to Annalisa's
>> installation question. I installed geonode-project only to customize the
>> look.
>> Now:
>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>> the same GeoNode version or upgrade it to GeoNode 2.9.x?
>> Thank you very much for your time in advance
>> Kind regards
>> Julierme
>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>> annalisa.schiavon at gmail.com> wrote:
>> Thanks for the tip!
>> Annalisa
>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>> Yes, absolutely. Currently, the deb installation is the most buggy
>> and unstable one.
>> It is worth notice that now GeoNode provides natively a way to
>> customize the interface, at least some part of it, without the need of
>> changing the files or the templates.
>> Take a look at the GeoNode Themes option on the Django Admin gui.
>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>> annalisa.schiavon at gmail.com> ha scritto:
>> Ok, thank you so much.
>> So you advise against the deb package installation, also if I
>> don't think to develop on geonode,  only to customize the look?
>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>> If you want to install geonode for development, I would suggest
>> following the procedure here
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>> If you want to start customizing your own portal (but still
>> develop it), I would suggest starting from a geonode-project template. In
>> that case, follow the instructions here
>> Otherwise, you can virtual machines either using vagrant or
>> docker. There are several ways and configurations around that you might
>> want to evaluate.
>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>> Please someone may confirm that installation by deb packages,
>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>> What advantages does have VM Setup with VirtualBox installation
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html
>> And than the installation step by step described in
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>> If I want to changes logos, colors and texts, is it recommended
>> install geonode-project and create a template, in similar way than once?
>> Because in https://github.com/GeoNode/geonode-project I find
>> instructions only for a Python virtual environment.
>> Thank you for any hint.
>> Annalisa
>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>> Hi all.
>> What is the best way to install geonode on Ubuntu for
>> production, currently?
>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>> apt-get, following these commands:
>> sudo add-apt-repository ppa:geonode/stable
>> sudo apt-get update
>> sudo apt-get install geonode
>> Then I had installed geonode-project for a few changes in
>> logos, colors and so on:
>> django-admin startproject geoportale20 --template=
>> https://github.com/GeoNode/geonode-project/archive/master.zip
>> -epy,rst
>> sudo pip install -e geoportale20
>> There are some procedures to migrate data from 2.4 to 2.8
>> (jumping the 2.6 release)?
>> Thank you,
>> Annalisa
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati
>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo
>> scrivente.
>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>> notizia.
>> This email is intended only for the person or entity to which it
>> is addressed and may contain information that is privileged, confidential
>> or otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of
>> this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake,
>> please
>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Con riferimento alla normativa sul trattamento dei dati personali
>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
>> “GDPR”),
>> si precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> this
>> please
>> @alfa7691
>> GeoSolutions S.A.S.
>> “GDPR”),
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> this
>> please
>> @alfa7691
>> GeoSolutions S.A.S.
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> this
>> please
>> @alfa7691
>> GeoSolutions S.A.S.
>> this
>> please
>> @alfa7691
>> GeoSolutions S.A.S.
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
>> this
>> please
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment.html
>> Subject: Digest Footer
>> End of geonode-users Digest, Vol 45, Issue 108
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/a278f701/attachment-0001.html>
More information about the geonode-users mailing list
