[GeoNode-users] Remove layer from GeoNode but keep in GeoServer
Michael Fedak mikefedak at gmail.com
Tue Sep 4 10:21:03 PDT 2018
Hello,
Try switching the layers you do not want added to not be advertised. You
can do this via the Edit Layer page in geoserver, there should be a
'Advertised''
checkbox. Then run updatelayers with the --skip-unadvertised flag. See here
for more details:
http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt_commands/index.html#updatelayers
On Tue, Sep 4, 2018 at 12:43 PM Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Hi list,
> Using GeoNode 2.8 installed from the Ubuntu ppa.
> I manually added several layers in GeoServer and then I published them
> using `geonode updatelayers` command. However, there are some layers in
> GeoServer that I do not want to list in GeoNode.
> If I delete the layer in GeoNode site, it will also be deleted in
> GeoServer, right? How can I 'unlist' a layer from GeoNode and still keep it
> in GeoServer?
> Cheers
> Daniel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180904/be505341/attachment.html>
More information about the geonode-users mailing list
