[GeoNode-users] WMS name clashes / contributors agreement problem
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Sep 7 01:03:15 PDT 2018
Dear Fina,
I will try to investigate on that. Can you please explain exactly the issue
you are having with the contribution agreement and the steps you did?
That said, if you want to send PRs it is still ok, we can review them, but
accordingly to the new rules, they must be sent first to the master branch
and related to a specific issue describing the technical problem and, if
applicable/possible, the proposed solution.
Il giorno gio 6 set 2018 alle ore 19:40 Fina, Stefan <
Stefan.Fina at ils-forschung.de> ha scritto:
> We are a team of GeoNode users with some development capacities that we
> would like to bring in to the GeoNode community. We currently have a
> problem with WMS name clashes that we actually know how to fix with some
> code changes, see https://github.com/GeoNode/geonode/pull/3875. We also
> provided a fix for another problem recently that was accepted (
> https://github.com/GeoNode/ansible-geonode/pull/45).
> Due to problems with the contributors agreement our fix for the WMS name
> clashes has now been declined. Could you pls reconsider this and check
> what’s wrong with the contributors agreement?
> Stefan
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180907/0e56f6fc/attachment.html>
More information about the geonode-users mailing list
