[GeoNode-users] WMS name clashes / contributors agreement problem
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Sep 12 07:31:56 PDT 2018
Hi Stefan,
currently I really can't figure out what the problem could be. However, if
you need this thing done on GeoNode, send me pointers to your repo/branch
and I will take care of doing the PR.
I will try to ask around if any other user is experiencing such issue.
Il giorno mer 12 set 2018 alle ore 14:20 Fina, Stefan <
Stefan.Fina at ils-forschung.de> ha scritto:
> Hi Francesco,
> I just tried one more time, same result with the message: “We're sorry,
> but something went wrong.” Can you check?
> Stefan
> *Von:* francesco bartoli [mailto:xbartolone at gmail.com]
> *Gesendet:* Freitag, 7. September 2018 17:01
> *An:* Alessio Fabiani
> *Cc:* Fina, Stefan; geonode-users
> *Betreff:* Re: [GeoNode-users] WMS name clashes / contributors agreement
> problem
> Hi Stefan,
> can you give another try?
> Thanks,
> Francesco
> Il giorno ven 7 set 2018 alle ore 15:02 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
> Can you give it a try?
> Il giorno ven 7 set 2018 alle ore 14:45 Fina, Stefan <
> Many thanks for your response, Alessio, here is what happens in detail:
> filling in the form at https://www.clahub.com/agreements/GeoNode/geonode
> with correct email address, name and affiliation information results in the
> error shown in the screenshot.
> Stefan
> *Fehler! Es wurde kein Dateiname angegeben.*
> *Von:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
> *Gesendet:* Freitag, 7. September 2018 10:03
> *An:* Fina, Stefan
> *Cc:* geonode-users
> problem
> Dear Fina,
> I will try to investigate on that. Can you please explain exactly the
> issue you are having with the contribution agreement and the steps you did?
> That said, if you want to send PRs it is still ok, we can review them, but
> accordingly to the new rules, they must be sent first to the master branch
> and related to a specific issue describing the technical problem and, if
> applicable/possible, the proposed solution.
> Il giorno gio 6 set 2018 alle ore 19:40 Fina, Stefan <
> We are a team of GeoNode users with some development capacities that we
> would like to bring in to the GeoNode community. We currently have a
> problem with WMS name clashes that we actually know how to fix with some
> code changes, see https://github.com/GeoNode/geonode/pull/3875. We also
> provided a fix for another problem recently that was accepted (
> https://github.com/GeoNode/ansible-geonode/pull/45).
> Due to problems with the contributors agreement our fix for the WMS name
> clashes has now been declined. Could you pls reconsider this and check
> what’s wrong with the contributors agreement?
> Stefan
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
> * This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.*
> @alfa7691
> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180912/e139a123/attachment-0001.html>
More information about the geonode-users mailing list
