[GeoNode-users] WMS name clashes / contributors agreement problem
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 13 06:57:23 PDT 2018
Issue here: https://github.com/GeoNode/geonode/issues/3914
PR here: https://github.com/GeoNode/geonode/pull/3915
Il giorno gio 13 set 2018 alle ore 15:03 francesco bartoli <
xbartolone at gmail.com> ha scritto:
> Hi Stefan,
> sorry for the problem but I cannot figure out what the problem is. Did the
> error change from your previous message? Could you give me more information
> on which page is failing and which redirections are you facing with? I
> configured a new hook into github which I thought it was working(green
> light)
> Thanks,
> Francesco
> Il giorno gio 13 set 2018 alle ore 12:15 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> I see,
>> I guess the only way would be to change the way we configured it on
>> github, i.e. via the clahub.
>> I have to figure out other ways to provide Osgeo CLA for GeoNode. Most
>> probably we will need to provide a file containing the list of the
>> contributors.
>> Il giorno gio 13 set 2018 alle ore 12:02 Fina, Stefan <
>> Stefan.Fina at ils-forschung.de> ha scritto:
>>> Hi Alessio,
>>> the PR is/was posted here: https://github.com/GeoNode/geonode/pull/3875.
>>> It would be great if you could take care of this.
>>> However, since we are planning to contribute long-term we think it would
>>> help the whole community if the problem with the contributors agreement
>>> could be fixed. I’m not the only one who experienced it, other team members
>>> had the same issue.
>>> Stefan
>>> *Von:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
>>> *Gesendet:* Mittwoch, 12. September 2018 16:32
>>> *An:* Fina, Stefan
>>> *Cc:* Francesco Bartoli; Alessio Fabiani; geonode-users
>>> *Betreff:* Re: [GeoNode-users] WMS name clashes / contributors
>>> agreement problem
>>> Hi Stefan,
>>> currently I really can't figure out what the problem could be. However,
>>> if you need this thing done on GeoNode, send me pointers to your
>>> repo/branch and I will take care of doing the PR.
>>> I will try to ask around if any other user is experiencing such issue.
>>> Il giorno mer 12 set 2018 alle ore 14:20 Fina, Stefan <
>>> Hi Francesco,
>>> I just tried one more time, same result with the message: “We're sorry,
>>> but something went wrong.” Can you check?
>>> Stefan
>>> *Von:* francesco bartoli [mailto:xbartolone at gmail.com]
>>> *Gesendet:* Freitag, 7. September 2018 17:01
>>> *An:* Alessio Fabiani
>>> *Cc:* Fina, Stefan; geonode-users
>>> agreement problem
>>> Hi Stefan,
>>> can you give another try?
>>> Thanks,
>>> Francesco
>>> Il giorno ven 7 set 2018 alle ore 15:02 Alessio Fabiani <
>>> Can you give it a try?
>>> Il giorno ven 7 set 2018 alle ore 14:45 Fina, Stefan <
>>> Many thanks for your response, Alessio, here is what happens in detail:
>>> filling in the form at https://www.clahub.com/agreements/GeoNode/geonode
>>> with correct email address, name and affiliation information results in the
>>> error shown in the screenshot.
>>> Stefan
>>> *Fehler! Es wurde kein Dateiname angegeben.*
>>> *Gesendet:* Freitag, 7. September 2018 10:03
>>> *An:* Fina, Stefan
>>> *Cc:* geonode-users
>>> agreement problem
>>> Dear Fina,
>>> I will try to investigate on that. Can you please explain exactly the
>>> issue you are having with the contribution agreement and the steps you did?
>>> That said, if you want to send PRs it is still ok, we can review them,
>>> but accordingly to the new rules, they must be sent first to the master
>>> branch and related to a specific issue describing the technical problem
>>> and, if applicable/possible, the proposed solution.
>>> Il giorno gio 6 set 2018 alle ore 19:40 Fina, Stefan <
>>> We are a team of GeoNode users with some development capacities that we
>>> would like to bring in to the GeoNode community. We currently have a
>>> problem with WMS name clashes that we actually know how to fix with some
>>> code changes, see https://github.com/GeoNode/geonode/pull/3875. We also
>>> provided a fix for another problem recently that was accepted (
>>> https://github.com/GeoNode/ansible-geonode/pull/45).
>>> Due to problems with the contributors agreement our fix for the WMS name
>>> clashes has now been declined. Could you pls reconsider this and check
>>> what’s wrong with the contributors agreement?
>>> Stefan
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
>>> * This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.*
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180913/7495de9d/attachment-0001.html>
More information about the geonode-users mailing list
