[GeoNode-users] GeoNode Project master Docker - Upload layers
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Sep 17 09:51:46 PDT 2018
Hi Simone,
I have several instances of GeoNode-Project in different VMs.
GeoNode-Project at 2.7 Docker Centos7 VM
Issue:
Django container gets a new one every time docker-compose up is run.
GeoNode-Project at 2master Docker Centos7 VM
Issue:
Related to upload layers
*Unable to
usecom.vividsolutions.jts.geom.impl.CoordinateArraySequenceFactory at 32f58c5e
to produce CoordinateSequence with dimension 2*
Thank you very much for your reply. I appreciated your time.
Kind regards
Julierme
On Sat, Sep 15, 2018 at 5:18 AM Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi,
> which version of GeoNode are you using. Keep in mind that the
> geonode-project branch you use should follow the geonode's version.
> Best
> Il giorno ven 14 set 2018 alle ore 22:37 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear users,
>> I had geonode-project at 2.7 running perfectly fine, including uploading
>> layers. Now, I am running GeoNode-Project at master, but I am unable to
>> upload data layers. The following message is shown at the end of the
>> uploading layers process:
>> *Unable to
>> This would not happen on version 2.7
>> Any comment on this issue would be very appreciated.
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180917/caa5abc5/attachment.html>
More information about the geonode-users mailing list
