[GeoNode-users] GeoNode Project master Docker - Upload layers
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Sep 17 10:36:07 PDT 2018
Hi Francesco,
Thank you very much for your reply. I have GeoNode-Project at 2.7 installed
via Docker in a Centos7 VM and I had edited the templates html (site_base
and site_index) and css file (site_base). GeoNode site was working
smoothly. But lately, after running docker-compose down and right after
docker-compose up, this last command resets the django container (the
container gets a new ID), and why I see that, after running docker-compose
up the templates [1] and static [2] returns to their default configuration.
[1]
https://github.com/GeoNode/geonode-project/tree/2.7/project_name/templates
[2]
https://github.com/GeoNode/geonode-project/tree/2.7/project_name/static/css
I appreciated your time
Kind regards
Julierme
On Mon, Sep 17, 2018 at 2:02 PM francesco bartoli <xbartolone at gmail.com>
wrote:
> Hi Julierme,
> the master branch is not supposed to be always in a safe docker build, at
> least until we could have time and maybe sponsors to introduce a reliable
> CI/CD procedure.
> With regards to the sentence "Django container gets a new one every time
> docker-compose up is run.", can you please elaborate more the issue? Is not
> clear what you are facing with.
> Thanks,
> Francesco
> Il giorno lun 17 set 2018 alle ore 18:52 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Simone,
>> I have several instances of GeoNode-Project in different VMs.
>> GeoNode-Project at 2.7 Docker Centos7 VM
>> Issue:
>> Django container gets a new one every time docker-compose up is run.
>> GeoNode-Project at 2master Docker Centos7 VM
>> Issue:
>> Related to upload layers
>> *Unable to
>> usecom.vividsolutions.jts.geom.impl.CoordinateArraySequenceFactory at 32f58c5e
>> to produce CoordinateSequence with dimension 2*
>> Thank you very much for your reply. I appreciated your time.
>> Kind regards
>> Julierme
>> On Sat, Sep 15, 2018 at 5:18 AM Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> which version of GeoNode are you using. Keep in mind that the
>>> geonode-project branch you use should follow the geonode's version.
>>> Best
>>> Il giorno ven 14 set 2018 alle ore 22:37 Julierme Pinheiro <
>>>> Dear users,
>>>> I had geonode-project at 2.7 running perfectly fine, including uploading
>>>> layers. Now, I am running GeoNode-Project at master, but I am unable to
>>>> upload data layers. The following message is shown at the end of the
>>>> uploading layers process:
>>>> *Unable to
>>>> This would not happen on version 2.7
>>>> Any comment on this issue would be very appreciated.
>>>> Kind regards
>>>> Julierme
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180917/6e229744/attachment.html>
More information about the geonode-users mailing list
