[GeoNode-users] Map rendering slow at GeoNode (Dev Gis)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 23 01:01:46 PDT 2019
Dear Deb,
from the GeoServer logs, your ROLE REST endpoint is misconfigured
Apr 21, 2019 12:30:01 AM org.geoserver.security.GeoServerRestRoleService
connectToRESTEndpoint
WARNING: null
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)...
thus causing read timeouts.
You need to fix the GeoServer configuration accordingly.
Il giorno lun 22 apr 2019 alle ore 16:20 Dev Gis <deviirmr at gmail.com> ha
scritto:
> Thank you, Toni,
> The log files are available at
> https://www.dropbox.com/sh/yq8j6962u64znzd/AABCyn2y7O7YHmb4kYamJCbla?dl=0
> Let me know, I will be happy to provide you with more info.
> Regards
> Deb
> On Mon, Apr 22, 2019 at 11:14 AM Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Dear Deb,
>> I still have some corrupt layer or style under suspicion.
>> But as a first step it would be interesting to see what is geoserver is
>> doing
>> all the time when replying to some request. Would it work for you to:
>> trunctate geoserver logs .f.e.
>> $ sudo truncate -s 0 /var/log/tomcat7/catalina.out
>> (set correct path)
>> Visit following URL:
>> http://geonode.iwlearn.org/geoserver/wms?access_token=b55d194d64dd11e98d7d000d3ab6a624&LAYERS=geonode%3Aadmin01_bnd&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=admin01_bnd&FORMAT=image%2Fpng&TILED=true&SRS=EPSG%3A900913&BBOX=11897270.576875,1252344.27125,12210356.644687,1565430.3390625&WIDTH=256&HEIGHT=256
>> Send the log file (without doing other requests) again.
>> Also it would be interesting to have a look at memory usage f.e. with $
>> top
>> (press shift +m to sort by memory usage)
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Tel  +49/ (0) 341 24 04 738
>> Fax  +49/ (0) 341 24 04 739
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 22.04.2019 um 00:46 schrieb Dev Gis <deviirmr at gmail.com>:
>> <geoserver.log>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190423/ad269a40/attachment.html>
More information about the geonode-users mailing list
