[GeoNode-users] Uploading Shapefile(Polygon features) - Displaying as Point in GeoNode Map/layer View
Naresh N naresh919 at gmail.com
Wed Apr 24 01:32:16 PDT 2019
Dear Simone/All
Kindly help to resolve the issue '*Uploading Shapefile of type polygon/line
in GeoNode 2.4  showing as Point Layer in Map/ Viewer section'*
Uploaded Shapefile type of polygon/line though GeoNode Interface, it is
displaying features as points.  I could able to understand by debugging the
flow of the code, GeoServer(2.7.4) *assigning default point SLD *for
uploaded shapefile of type polygon/line.
Please find the attached screenshot of GeoServer embedded in GeoNode.  It
shows *the_geom* type as* Geometry  *instead of showing* as
Multipolygon/MultiLine.*
*Please help us to find which is the code responsible in GeoServer/GeoNode
decides the_geom type?*
Please let me know any other information required further to understand the
issue
Note:1.* For testing  I have used higher version of GeoServer(2.13.1)  and
uploaded shapefile , then the_geom type is showing as expected based on
uploaded Shpefile type as ** Multipolygon/MultiLine and found no issues. I
think it is issue of GeoServer 2.7.4 and PostgresQL 10/PostGIS 2.5.2*
*         2. Deployed System Details of GeoNode 2.4*
*              RHEL 7.2, 64 bit*
*              PostgresQL: 10.0*
*              PostGIS: 2.5.2*
*              GeoServer : 2.7.4  ( the geoserver.war file which is
packaged with GeoNode is used)*
*Thanks&Regards,*
*Naresh.N*
On Mon, Apr 15, 2019 at 3:24 PM Naresh N <naresh919 at gmail.com> wrote:
> Dear All,
> kindly help to resolve the *issue*  '*Uploading Shapefile of type
> polygon/line in GeoNode 2.4  showing as Point Layer in Map/ Viewer section'*
> *Please answer my following  doubts and hep to resolve the issue*
> 1. Is GeoNode 2.4 compatible with PostgreSQL 10.7 and PostGIS 2.5.2
> 2. Uploaded Shapefile of type Polygon in  PostgreSQL Database table
> showing* the_geom attribute data type* as  as Geometry (PgAdmin4).
> and even in GeoServer Layer  interface 'the_geom' attribute data type
> showing as Geometry. How to correct ' the{_geom' attribute data type based
> on features type in Shapefile . Which part of the code in GeoNode verifies
> and assigns the attribute type of Shapefile.
> Kindly help me to fix the issue and please let me  know any other
> information required.
> Thanks&Regards,
> Naresh.N
> On Wed, Apr 10, 2019 at 2:35 PM Naresh N <naresh919 at gmail.com> wrote:
>> Dear Simone,
>> Please kindly see the trailing mail and help me to solve the issue. I
>> have already posted in GeoNode discussion forum, not able to solve the
>> isssue.
>> Kindly help in this regard.
>> Thanks&Regards,
>> Naresh
>> ---------- Forwarded message ---------
>> From: Naresh N <naresh919 at gmail.com>
>> Date: Mon, Apr 8, 2019 at 4:58 PM
>> Subject: Uploading Shapefile(Polygon features) - Displaying as Point in
>> To: geonode-users lists.osgeo.org <geonode-users at lists.osgeo.org>,
>> Alessio Fabiani <alessio.fabiani at geo-solutions.it>, Simone Dalmasso <
>> simone.dalmasso at gmail.com>
>> Dear All,
>> I have deployed the GeoNode 2.4 version by following  the instructions
>> http://docs.geonode.org/en/2.4.x/tutorials/install_and_admin/setup_on_centos/index.html
>> *ISSUE : *When I am uploading shapefile(polygon), it is taking the
>> default point SLD. Hence when I am viewing the Uploaded Shapfeil(polygon)
>> as WMS in Map/Layer View , it is displaying as point.
>> *Kindly help me to resolve this issue. *
>> GeoNode Deployed system configuration are
>> *OS:*RHEL 7.2, 64 bit , GeoNode2.4 version
>> the issue.
>> Thanks&Regards,
>> Naresh.N
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/6edcc06c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190424/6edcc06c/attachment-0001.png>
More information about the geonode-users mailing list
