[GeoNode-users] MapStore2 Viewer - Custom WMTS background map
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Apr 26 05:25:44 PDT 2019
Yes sure, it will be very welcome.
In that case the PR must be done directly to the MapStore repo. We will
take care to include it in the next releases.
Il giorno ven 26 apr 2019 alle ore 14:23 Pascal Coulon <
Pascal.Coulon at scisys.co.uk> ha scritto:
> Alessio.
> This is a great reply, thanks for the update. I thought it would be the
> case. I will create a pull request for this and you may wish to have it.
> The use of Ordnance Survey API in mapstore may be useful for many in the UK.
> Regards,
> Pascal
> *From:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Sent:* 26 April 2019 13:20
> *To:* Pascal Coulon <Pascal.Coulon at scisys.co.uk>
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] MapStore2 Viewer - Custom WMTS background
> map
> Hello Pascal,
> well, unfortunately at this time this is not quite easy to achieve in
> MapStore2.
> There are plans to introduce a generic "TMS" Provider in the next release,
> but at this time only configured providers are supported. See the list here
> https://mapstore.readthedocs.io/en/latest/developer-guide/maps-configuration/#providers-and-variants
> In order to add your own provider, you should roughly follow those steps:
> 1) download the geonode-mapstore-client source code
> git clone https://github.com/geosolutions-it/geonode-mapstore-client.git
> 2) go to folder geonode-mapstore-client/geonode_mapstore_client/client and
> run
> git submodule update --recursive
> 3) edit the file ConfigProvider.js and add your new provider
> vim MapStore2/web/client/utils/ConfigProvider.js
> 4) rebuild the library; from
> npm run compile
> 5) install your local version of the python library; from
> pip install -e .
> 6) go back to geonode source folder and run
> python manage.py collectstatic
> 7) restart the server after having updated the MS2_DEFAULT_BACKGROUNDs
> config accordingly
> Hope this helps.
> By the way, the same procedure applies whenever you would like to
> update/customize MapStore2 somehow.
> Regards,
> Alessio.
> Il giorno ven 26 apr 2019 alle ore 12:01 Pascal Coulon <
> All,
> We have decided to use MapStore2 as the main viewer in Geonode (2.10RC4).
> We would like to set-up a custom WMTS or XYZ (tile) layer for the
> background map. We are based in the UK and we would need to use the
> Ordnance Survey OGC feed for this.
> In our settings.py we have set-up the following config.
> DEFAULT_MAP_CRS = "EPSG:3857"
> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>     INSTALLED_APPS += (
>         'mapstore2_adapter',
>         'geonode_mapstore_client',)
> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore'  # DEPRECATED use
> HOOKSET instead
> GEONODE_CLIENT_HOOKSET = "geonode_mapstore_client.hooksets.MapStoreHookSet"
> MAPSTORE_DEBUG = False
> ### The key to access OS API as obfuscated. #####
> DEFAULT_MS2_BACKGROUNDS = [
>              "type":"wmts",
>              "title":"Ordnance Survey",
>               "allowedSRS": {
>               "EPSG:3857": True
>              "url": [
> https://api2.ordnancesurvey.co.uk/mapping_api/v1/service/zxy/EPSG:3857/Outdoor
> 3857/${z}/${x}/${y}.png?key=xxxxx"
>              "visibility": False,
>              "group":"background",
>               "matrixIds": [
>                   "EPSG:3857",
>               "tileMatrixSet": [
>              "capabilitiesURL": "
> https://api2.ordnancesurvey.co.uk/mapping_api/v1/service/wmts?Request=GetCapabilities&key=XXXXXXXXXXXX
> MAPSTORE_BASELAYERS = DEFAULT_MS2_BACKGROUNDS
> The background data from OS does not get properly set and we get some
> JavaScript errors that lead us to believe that we are not setting the
> background layer the proper way.
> Any help or recommendation would be gratefully received.
> Regards,
> Pascal
> SCISYS UK Limited. Registered in England and Wales No. 4373530.
> Registered Office: Methuen Park, Chippenham, Wiltshire SN14 0GB, UK.
> Before printing, please think about the environment.
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
> * This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.*
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190426/99aea827/attachment-0001.html>
More information about the geonode-users mailing list
