[GeoNode-users] Unable to see a newly added layer in Geoserver in Geonode
Nicolas D. hieloynieve at gmail.com
Tue Dec 10 06:58:00 PST 2019
What should I give you as details for "-settings = geonode.settings"?
Le mar. 10 déc. 2019 à 15:47, Nicolas D. <hieloynieve at gmail.com> a écrit :
> I uploaded a layer to GeoServer as (
> https://geoserver.geo-solutions.it/edu/en/adding_data/add_shp.html)
> After, I am able to see the new layer in the GeoServer Layers page
> I have made changes to the GeoFence Data Rules by creating new rules for
> the services (GWC, WMS, *, WPS, WFS)
> For import data to geonode, i used the python manage.py updatelayers
> command for it but it doesn't work.
> I'm using a virtual environment. For start geonode I use the command: source
> env/bin/activate, then I set on the folder of the application (cd
> "folder"), to launch the services: paver start.
>    - Specs: GeoNode version: 2.8 with mapstore viewer, GeoServer version:
>    2.14.3, Ubuntu server
> Le mar. 10 déc. 2019 à 15:31, Francesco Bartoli <xbartolone at gmail.com> a
> écrit :
>> All of them are missing the declaration of the settings to use, are you
>> in a virtual environment or something? Can you try by explicitly declaring
>> it?
>> —settings=geonode.settings
>> Il 10 dic 2019, 15:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>> scritto:
>> I tried these different commands:
>> - python manage.py updatelayers
>> - python manage.py updatelayers --skip-geonode-registered -w geonode
>> - python manage.py updatelayers -w geonode
>> Each time, it does not work
>> Le mar. 10 déc. 2019 à 15:09, Francesco Bartoli <xbartolone at gmail.com> a
>> écrit :
>>> What’s then the literal command you are trying to run?
>>> Il 10 dic 2019, 15:05 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>> scritto:
>>> Thank you for your help. Sorry, it's an oversight on my part. I will pay
>>> attention next time.
>>> I looked at the geonode / settings.py file to check for correct setting
>>> parameters.
>>> The OGC dictionary parameters are as follows
>>> OGC_SERVER = {
>>>     'default': {
>>>         'BACKEND': 'geonode.geoserver',
>>>         'LOCATION': GEOSERVER_LOCATION,
>>>         'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
>>>         'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
>>>         'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
>>>         # PUBLIC_LOCATION needs to be kept like this because in dev mode
>>>         # the proxy won't work and the integration tests will fail
>>>         # the entire block has to be overridden in the local_settings
>>>         'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
>>>         'USER': OGC_SERVER_DEFAULT_USER,
>>>         'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
>>>         'MAPFISH_PRINT_ENABLED': True,
>>>         'PRINT_NG_ENABLED': True,
>>>         'GEONODE_SECURITY_ENABLED': True,
>>>         'GEOFENCE_SECURITY_ENABLED': GEOFENCE_SECURITY_ENABLED,
>>>         'GEOFENCE_URL': os.getenv('GEOFENCE_URL', 'internal:/'),
>>>         'WMST_ENABLED': False,
>>>         'BACKEND_WRITE_ENABLED': True,
>>>         'WPS_ENABLED': True,
>>>         'LOG_FILE': '%s/geoserver/data/logs/geoserver.log'
>>>         % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
>>>         # Set to name of database in DATABASES dictionary to enable
>>>         # 'datastore',
>>>         'DATASTORE': os.getenv('DEFAULT_BACKEND_DATASTORE', ''),
>>>         'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
>>>         'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
>>>         'BACKOFF_FACTOR': float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR',
>>> '0.3')),
>>>         'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE', '10')),
>>>         'POOL_CONNECTIONS':
>>> int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS', '10')),
>>> Are the variables correct?
>>> Should I check other settings in the file for this to work?
>>> Nicolas
>>> Le mar. 10 déc. 2019 à 14:31, Francesco Bartoli <xbartolone at gmail.com>
>>> a écrit :
>>>> Please look at the documentation
>>>> http://docs.geonode.org/en/2.10.x/basic/index.html#geonode-settings
>>>> And also, please remember to reply to the list so the discussion can be
>>>> useful for others
>>>> Il 10 dic 2019, 14:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>> scritto:
>>>> Hi,
>>>> Thank you for your reply. Where can I find the settings.py file? What
>>>> settings do I need to configure or check for this to work properly?
>>>> Regards,
>>>> Nicolas
>>>> Le mar. 10 déc. 2019 à 13:54, Francesco Bartoli <xbartolone at gmail.com>
>>>> a écrit :
>>>>> Hi,
>>>>> apparently it doesn’t accomplish to access GeoServer properly so the
>>>>> question is how does your settings.py look like?
>>>>> Francesco
>>>>> Il 10 dic 2019, 11:15 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>>> scritto:
>>>>> Hi,
>>>>> I tried using the updatelayers function to Update the GeoNode
>>>>> application with the GeoServer data. I used python manage.py updatelayers,
>>>>> but I do not understand why it does not work. I have attached the errors
>>>>> displayed. Can you please help me to find out what's wrong? Thank you in
>>>>> advance, truthfully yours,
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/80c99265/attachment-0001.html>
More information about the geonode-users mailing list
