[GeoNode-users] Unable to see a newly added layer in Geoserver in Geonode
Francesco Bartoli xbartolone at gmail.com
Tue Dec 10 14:13:12 PST 2019
In GeoNode there is a complex security layer of permissions and authorization through GeoServer based on the OAuth2. More on this here http://docs.geonode.org/en/2.10.x/advanced/components/index.html#geonode-security-backend
Hope this clarifies
Il 10 dic 2019, 22:44 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> Thanks for these informations. I will see to install the latest version 2.10.
> So, I wanted to know why when we add data in geoserver, we can't see them through a WMS url in other applications? While the data added in geonode they are visible through a WMS url.
> > Le mar. 10 déc. 2019 à 19:07, Francesco Bartoli <xbartolone at gmail.com> a écrit :
> > > DJANGO_SETTINGS_MODULE=geonode.settings and —settings=geonode.settings are equivalent. That said, I’m still seeing a connection error but I cannot say what that should be. However, be careful about the fact that 2.8 is no longer maintained. I would recommend to upgrade as soon as possible
> > > Hope this helps
> > > F.
> > > Il 10 dic 2019, 18:36 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> > > > you're right, I haven't seen this page. Thank you, it's interesting because that's exactly what I want to do, since I also want to add data from a POSTGIS database.
> > > > When I use the DJANGO_SETTINGS_MODULE = geonode.settings python manage.py updatelayers --help function, it works correctly as shown in website.
> > > > By cons, when I want to add the data with this command: DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -w geonode -f Measures, it does not work. I have attached the displayed errors.
> > > > Can you please tell me the parameters to configure for this function to work properly? what is the next step to test what's wrong?
> > > > > Le mar. 10 déc. 2019 à 16:02, Francesco Bartoli <xbartolone at gmail.com> a écrit :
> > > > > > I guess you didn’t have a look at the documentation http://docs.geonode.org/en/2.10.x/admin/mgmt_commands/index.html#management-command-updatelayers :)
> > > > > > Il 10 dic 2019, 15:58 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> > > > > > > What should I give you as details for "-settings = geonode.settings"?
> > > > > > > > Le mar. 10 déc. 2019 à 15:47, Nicolas D. <hieloynieve at gmail.com> a écrit :
> > > > > > > > > I uploaded a layer to GeoServer as (https://geoserver.geo-solutions.it/edu/en/adding_data/add_shp.html)
> > > > > > > > > After, I am able to see the new layer in the GeoServer Layers page
> > > > > > > > > I have made changes to the GeoFence Data Rules by creating new rules for the services (GWC, WMS, *, WPS, WFS)
> > > > > > > > > For import data to geonode, i used the python manage.py updatelayers command for it but it doesn't work.
> > > > > > > > > I'm using a virtual environment. For start geonode I use the command: source env/bin/activate, then I set on the folder of the application (cd "folder"), to launch the services: paver start.
> > > > > > > > > • Specs: GeoNode version: 2.8 with mapstore viewer, GeoServer version: 2.14.3, Ubuntu server
> > > > > > > > > > Le mar. 10 déc. 2019 à 15:31, Francesco Bartoli <xbartolone at gmail.com> a écrit :
> > > > > > > > > > > All of them are missing the declaration of the settings to use, are you in a virtual environment or something? Can you try by explicitly declaring it?
> > > > > > > > > > > Il 10 dic 2019, 15:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> > > > > > > > > > > > I tried these different commands:
> > > > > > > > > > > > - python manage.py updatelayers
> > > > > > > > > > > > - python manage.py updatelayers --skip-geonode-registered -w geonode
> > > > > > > > > > > > - python manage.py updatelayers -w geonode
> > > > > > > > > > > > Each time, it does not work
> > > > > > > > > > > > > Le mar. 10 déc. 2019 à 15:09, Francesco Bartoli <xbartolone at gmail.com> a écrit :
> > > > > > > > > > > > > > What’s then the literal command you are trying to run?
> > > > > > > > > > > > > > Il 10 dic 2019, 15:05 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> > > > > > > > > > > > > > > Thank you for your help. Sorry, it's an oversight on my part. I will pay attention next time.
> > > > > > > > > > > > > > > I looked at the geonode / settings.py file to check for correct setting parameters.
> > > > > > > > > > > > > > > The OGC dictionary parameters are as follows
> > > > > > > > > > > > > > > OGC_SERVER = {
> > > > > > > > > > > > > > >     'default': {
> > > > > > > > > > > > > > >         'BACKEND': 'geonode.geoserver',
> > > > > > > > > > > > > > >         'LOCATION': GEOSERVER_LOCATION,
> > > > > > > > > > > > > > >         'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
> > > > > > > > > > > > > > >         'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
> > > > > > > > > > > > > > >         'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
> > > > > > > > > > > > > > >         # PUBLIC_LOCATION needs to be kept like this because in dev mode
> > > > > > > > > > > > > > >         # the proxy won't work and the integration tests will fail
> > > > > > > > > > > > > > >         # the entire block has to be overridden in the local_settings
> > > > > > > > > > > > > > >         'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
> > > > > > > > > > > > > > >         'USER': OGC_SERVER_DEFAULT_USER,
> > > > > > > > > > > > > > >         'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
> > > > > > > > > > > > > > >         'MAPFISH_PRINT_ENABLED': True,
> > > > > > > > > > > > > > >         'PRINT_NG_ENABLED': True,
> > > > > > > > > > > > > > >         'GEONODE_SECURITY_ENABLED': True,
> > > > > > > > > > > > > > >         'GEOFENCE_SECURITY_ENABLED': GEOFENCE_SECURITY_ENABLED,
> > > > > > > > > > > > > > >         'GEOFENCE_URL': os.getenv('GEOFENCE_URL', 'internal:/'),
> > > > > > > > > > > > > > >         'WMST_ENABLED': False,
> > > > > > > > > > > > > > >         'BACKEND_WRITE_ENABLED': True,
> > > > > > > > > > > > > > >         'WPS_ENABLED': True,
> > > > > > > > > > > > > > >         'LOG_FILE': '%s/geoserver/data/logs/geoserver.log'
> > > > > > > > > > > > > > >         % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
> > > > > > > > > > > > > > >         # Set to name of database in DATABASES dictionary to enable
> > > > > > > > > > > > > > >         # 'datastore',
> > > > > > > > > > > > > > >         'DATASTORE': os.getenv('DEFAULT_BACKEND_DATASTORE', ''),
> > > > > > > > > > > > > > >         'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
> > > > > > > > > > > > > > >         'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
> > > > > > > > > > > > > > >         'BACKOFF_FACTOR': float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR', '0.3')),
> > > > > > > > > > > > > > >         'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE', '10')),
> > > > > > > > > > > > > > >         'POOL_CONNECTIONS': int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS', '10')),
> > > > > > > > > > > > > > > Are the variables correct?
> > > > > > > > > > > > > > > Should I check other settings in the file for this to work?
> > > > > > > > > > > > > > > Nicolas
> > > > > > > > > > > > > > > > Le mar. 10 déc. 2019 à 14:31, Francesco Bartoli <xbartolone at gmail.com> a écrit :
> > > > > > > > > > > > > > > > > Please look at the documentation http://docs.geonode.org/en/2.10.x/basic/index.html#geonode-settings
> > > > > > > > > > > > > > > > > And also, please remember to reply to the list so the discussion can be useful for others
> > > > > > > > > > > > > > > > > Il 10 dic 2019, 14:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> > > > > > > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > Thank you for your reply. Where can I find the settings.py file? What settings do I need to configure or check for this to work properly?
> > > > > > > > > > > > > > > > > > Regards,
> > > > > > > > > > > > > > > > > > Nicolas
> > > > > > > > > > > > > > > > > > > Le mar. 10 déc. 2019 à 13:54, Francesco Bartoli <xbartolone at gmail.com> a écrit :
> > > > > > > > > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > > > apparently it doesn’t accomplish to access GeoServer properly so the question is how does your settings.py look like?
> > > > > > > > > > > > > > > > > > > > Francesco
> > > > > > > > > > > > > > > > > > > > Il 10 dic 2019, 11:15 +0100, Nicolas D. <hieloynieve at gmail.com>, ha scritto:
> > > > > > > > > > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > > > > I tried using the updatelayers function to Update the GeoNode application with the GeoServer data. I used python manage.py updatelayers, but I do not understand why it does not work. I have attached the errors displayed. Can you please help me to find out what's wrong? Thank you in advance, truthfully yours,
> > > > > > > > > > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > > > > > > > > > geonode-users mailing list
> > > > > > > > > > > > > > > > > > > > > geonode-users at lists.osgeo.org
> > > > > > > > > > > > > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/e35f4b59/attachment-0001.html>
More information about the geonode-users mailing list
