[GeoNode-users] CSS, HTML in docker
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Dec 17 01:36:37 PST 2019
Hi Matheus,
well, this usually depends on how you installed GeoNode. In Django
framework the templates can be overridden.
The easiest way, of course (but also the dirtiest), would be to remove
those parts from the "index.html" template or, alternatively, modify the
"base.css" by "hiding" the DIVs from the stylesheet.
Il giorno lun 16 dic 2019 alle ore 18:58 Matheus Ximenes <
Matheus.ximenes2016 at outlook.com> ha scritto:
> Cool, thanks!
> Alessio, hi
> before answer works, but the file that change is index.html.
> now i would like to know is:
> How can i disable these parts:
> "Search for Data" and "Discover the available datasets"
> i think it's not just removing this part of index.html
> *De:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Enviado:* segunda-feira, 16 de dezembro de 2019 06:22
> *Para:* Matheus Ximenes <Matheus.ximenes2016 at outlook.com>
> *Cc:* geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>;
> geonode-users <geonode-users-bounces at lists.osgeo.org>; geonode-devel <
> geonode-devel at lists.osgeo.org>
> *Assunto:* Re: [GeoNode-users] CSS, HTML in docker
> Dear Matheus,
> all HTML files are located into the various "templates" folders. If I
> correctly understood your needs, most probably you will need to change the
> "base.html" template file.
> CSS and Javascripts are located in the "static" folder instead.
> Il giorno ven 13 dic 2019 alle ore 19:33 Matheus Ximenes <
> hi,
> First i installed the geonode core, after the geonode from docker, now i
> want to make a modification in major html of my geonode and wolud like to
> know where this directory is.
> How i installed the geonode from docker in geonode core, they are the same
> directory? for example:
> if i acess this way:
> /opt/geonode/geonode/static
> and change anything, will that change my GeoNode that runs on localhost?
> i would need to find directory that give chance to change this:
> The name in the new tab.
> I can't find this folder, if anyone  helps me, it will be very important
> to me,
> thanks,
> Matheus Ximenes
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191217/89edc654/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191217/89edc654/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191217/89edc654/attachment-0003.png>
More information about the geonode-users mailing list
