[GeoNode-users] Command updatelayers and createsuperuser in docker-compose
Andres Juarez albertoandres.juarez at gmail.com
Wed Feb 13 06:06:59 PST 2019
Hello Giovanni
Thanks for the clarification.
What would be the correct way to execute these commands?
*docker-compose exec django django-admin updatelayers*
Is this the same as running it in the bash of the container?
do not take the .env
If I run *python manage.py updatelayers* outside the container, I get the
error
ImportError: No module named geonode.settings
Thank you and sorry for my newbie question ...
El mar., 5 feb. 2019 a las 6:12, G. Allegri (<
giovanni.allegri at geo-solutions.it>) escribió:
> When you exec into the docker container the Dockerfile entrypoint is not
> hit, thus the .env variables are not translated and set to the variables
> expected by GeoNode.
> Giovanni
> Il giorno mar 5 feb 2019 alle ore 02:05 Andres Juarez <
> albertoandres.juarez at gmail.com> ha scritto:
>> Hello
>> It worked, I was able to create the superuser and publish the layers from
>> geoserver.
>> Thank you very much for the help...
>> regards
>> El lun., 4 feb. 2019 a las 20:47, MDG DEE (<kula009 at gmail.com>) escribió:
>>> Hello,
>>> I had a similar issue before. Here is the solution someone offered and
>>> it worked for me:
>>> Log into your django container docker exec -it ...and try:
>>> mkdir -p /usr/src/app/; \
>>>     source $HOME/.override_env; \
>>>     echo DATABASE_URL=$DATABASE_URL; \
>>>     echo GEODATABASE_URL=$GEODATABASE_URL; \
>>>     echo SITEURL=$SITEURL; \
>>>     echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
>>>     echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION; \
>>>     django-admin createsuperuser
>>> this will create your new superuser correctly.
>>> Ran
>>> On Mon, Feb 4, 2019 at 3:38 PM Andres Juarez <
>>> albertoandres.juarez at gmail.com> wrote:
>>>> Hello Francesco, thanks for the reply
>>>> I access the container django4my_geonode with
>>>> docker exec -i -t django4my_geonode bash
>>>> then I execute
>>>> python manage.py migrate
>>>> (because without this it did not allow to create the superuser), then
>>>> python manage.py createsuperuser
>>>> and after loading the layers in geoserver run
>>>> regards
>>>> and thanks again ...
>>>> El lun., 4 feb. 2019 a las 18:36, Francesco Bartoli (<
>>>> xbartolone at gmail.com>) escribió:
>>>>> Can you briefly show which commands have been executed and against
>>>>> which container?
>>>>> Regards,
>>>>> Francesco
>>>>> Il 4 feb 2019, 21:43 +0100, Andres Juarez <
>>>>> albertoandres.juarez at gmail.com>, ha scritto:
>>>>> Hello everyone
>>>>> I continue with Geonode 2.10 in docker, and I find a problem when
>>>>> executing the updatelayers command.
>>>>> I have several layers in a postgres database on another server, and I
>>>>> load it through a geoserver store.
>>>>> The updatelayers command runs flawlessly and warns me that the layers
>>>>> were updated, but they do not appear in the geonode layers section.
>>>>> However, I can create an empty map and load these same layers using the add
>>>>> layer button, selecting 'Geoserver - Public layers'.
>>>>> The same happens when executing createsuperuser, the process ends
>>>>> successfully in the command line, but I can not log in with that user.
>>>>> Thank you in advance for any help you can provide.
>>>>>    Andrés Juarez
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>    Andrés Juarez
>>    Andrés Juarez
> Giovanni Allegri
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
>  (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
   Andrés Juarez
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190213/0511f70d/attachment.html>
More information about the geonode-users mailing list
