[GeoNode-users] Is it possible to have a library of reusable styles
Alessio Fabiani alessio.fabiani at gmail.com
Fri Feb 22 00:44:47 PST 2019
Hi Peter,
no GeoNode customization at all, just configuration settings.
The client libraries are pluggable in recent GeoNodes.
Il giorno ven 22 feb 2019 alle ore 02:59 Peter Thiem <peterthiem at gmail.com>
ha scritto:
> Looks great Alessio, thanks!
> I've been using version "Powered by GeoNode version 2.10rc4", checked out
> from github/master on 15/2/2019, and built using the docker instructions.
> Should be a recent version, most likely I just am not doing (and don't
> understand) the right thing to set up a reusable style.
> >  I'd suggest waiting a bit until we release a new GIS client for GeoNode.
> Any guess when this would be? In any case, i hope to have only a light or
> zero customisation instance of geonode, so that it will be easier to
> upgrade, so I may be able to proceed with the current version, then upgrade
> upon the release of a new version.
> Cheers.
> On Thu, 21 Feb 2019 at 19:53, Alessio Fabiani <alessio.fabiani at gmail.com>
> wrote:
>> Dear Peter,
>> which version of GeoNode you are currently using? The issue you describe
>> seems to be related to a quite old version of it.
>> About your questions, I'd suggest waiting a bit until we release a new
>> GIS client for GeoNode [1] which should fulfill your requirements.
>> Here below few screenshots on how it looks and the zoom levels (it can
>> zoom up to 1:2)
>> [image: image.png]
>> [image: image.png]
>> [image: image.png]
>> [image: image.png]
>> [1] -
>> https://github.com/geosolutions-it/geonode-mapstore-client#geonode-client---
>> *WARNING: Only working on GeoNode 2.10+*
>> Il giorno gio 21 feb 2019 alle ore 01:13 Peter Thiem <
>> peterthiem at gmail.com> ha scritto:
>>> Hi Geonode users,
>>> I'm considering using geonode to store and share and visualise large
>>> number of farm plot maps for a research farm.
>>> Each layer for a research study would have a number of attributes for
>>> each farm plot collected during the experiment (i.e. fertiziler amount,
>>> moisture, seek yield, plant height, etc).
>>> I'm thinking to use a different style for each type of attribute, that
>>> could be associated with the layer depending the attributes that layer has,
>>> and the user can choose between the associated styles.
>>> In my attempts to get them to work, i create styles in the geonode admin
>>> interface, but then they seem to get deleted automatically if they are not
>>> associated with a layer.
>>> And to really get the layer setup and working, i seem to need to create
>>> it in geoserver and in geonode.
>>> I'm not sure i understand how Geonode manages styles and intends for
>>> users to operate them.
>>> Questions.
>>> Is it possible and sensible to have a library of styles that can be
>>> shared between maps? Why or why not?
>>> Or are styles really meant to be associated with a single layer (rather
>>> than as a library)?
>>> If so, how would I set them up, properly?
>>> Is there a better approach to making it easier for the users to
>>> visualise different attributes in each layer?
>>> Cheers, Peter.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/e9d03acd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/e9d03acd/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/e9d03acd/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/e9d03acd/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190222/e9d03acd/attachment-0007.png>
More information about the geonode-users mailing list
