[GeoNode-users] Print Map Preview
Alessio Fabiani alessio.fabiani at gmail.com
Thu Feb 28 01:00:27 PST 2019
Hi Julierme,
indeed is possible to customize the printing module (see attached
screenshots)
[image: image.png]
[image: image.png]
Mostly you have to tweak the printing yaml file inside the GeoServer DATA
DIR.
Try to have a look at the following documentation
https://docs.geoserver.org/latest/en/user/extensions/printing/index.html
Il giorno mer 27 feb 2019 alle ore 16:07 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear users,
> I am running GeoNode-Project at 2.8 installed via Docker on an Ubuntu at 18.04
> LTS server. I am in need to edit the default Print Preview map as adding a
> logo and some text and date, information that is coming from Postgres
> table.  Said that:
> 1 - I am searching for some documentation that could help me to achieve
> that. I found this resource
> <http://docs.geonode.org/en/master/tutorials/advanced/adv_data_mgmt/pretty_maps/map_decorations.html>
> , but it seems to be actions on Layer preview and not a Print Preview.
> 2 - There is something wrong with the default print preview map. The print
> preview shows the layers over that map, but the saved pdf document does not
> show the layers.
> Any help on items 1 and 2 will be very appreciated.
> Kind regards
> Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190228/3cba915f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190228/3cba915f/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190228/3cba915f/attachment-0003.png>
More information about the geonode-users mailing list
