[GeoNode-users] Migrating from GeoNode 2.4.1 to 2.10.x
Paolo Pasquali paolo.pasquali at gmail.com
Tue Jan 15 02:35:19 PST 2019
I have fixed the projection error for most of the layers by adding a custom
CRS in GeoServer (that I missed to migrate) and using the pg_dump for the
geonode_data db only. Not sure which one helped solve this issue (maybe
both?) but a few layers still have that weird projection set (assigned by
default?).
However this didn't solve the issue of the unpublished vector layers in
GeoServer. If I manually publish them one by one, they work in GeoNode as
well (it seems they are now linked to GeoNode again).
But I have hundreds of them...
Do you know where GeoServer store the information whether a layer is
published or not?
Thanks for your help!
Ciao
P.
On Mon, Jan 14, 2019 at 10:39 PM Francesco Bartoli <xbartolone at gmail.com>
wrote:
> It sounds strange but something definitively to figure out what is
> responsible of this weird behavior. I guess the source epsg was different.
> Can you check if the same behavior would happen by using only the pg_dump
> utility?
> Ciao
> Francesco
> Il 14 gen 2019, 22:08 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>,
> ha scritto:
> Ciao Francesco,
> The upload works.
> But I've found a clue.
> If I try to manually publish from GeoServer each layer that needs to
> migrated it seems that all have a weird EPSG (EPSG:404000).
> I've used pg_dumpall. Is it possible that something went wrong? The
> postgis version?
> Thanks!
> P.
> On Mon, Jan 14, 2019 at 9:46 PM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Ciao Paolo,
>> Apart the data you are trying to migrate does the normal upload form work
>> if you try with a shapefile?
>> Francesco
>> Il 14 gen 2019, 18:41 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>,
>> ha scritto:
>> Dear all,
>> I'm trying to migrate my data from an old 2.4.1 to the latest GeoNode.
>> I've followed the documentation by Olivier Dalang (very helpful, thanks!)
>> [1] and adapted to my docker installation [2].
>> I'm almost there, but while all my raster layers are ok (except some
>> minor issue), the vector layers are present in GeoNode but not published by
>> GeoServer. Although the datastore in GeoServer seems properly configured to
>> connect to PostGIS no vector layer is published.
>> I'm missing something...
>> Best,
>> Paolo
>> [1]
>> https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install
>> [2] https://github.com/ppasq/masdap/wiki/Migration
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190115/a5a33451/attachment.html>
More information about the geonode-users mailing list
