[GeoNode-users] The "gsconfig" module thing!
1520 gis juliermeopensourcedeveloper at gmail.com
Wed Jul 17 09:40:32 PDT 2019
Dear Toni,
Thank you very much for the update. If I am not wrong, that means that
GeoNode / GeoNode-Project / is all compatible to python3.
Kind regards
Julierme
On Wed, Jul 17, 2019 at 5:43 AM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Community,
> regarding below message of Alessio. The old library gsconfig has been
> replaced
> in master with following commit:
> https://github.com/GeoNode/geonode/commit/92ed66c7d6e20147414e9a28a3f63f43ba0b76fd
> The commit will be soon backported to branch 2.10.x (latest release).
> A word of caution: In case you’re using the old gsconfig with new code you
> might
> run into problems: To reflect those changes don’t forget to run the well
> known
> pip install -r requirements.txt — upgrade
> after your pull:
> Cheers,
> – T.
> Am 10.07.2019 um 10:01 schrieb geonode-users-request at lists.osgeo.org:
> Dear GeoNode devs, users,
> as you might already know, GeoNode relies on a python library, started by
> boundless several years ago, called "gsconfig", which basically handles
> almost all the APIs communication with GeoServer.
> Currently, the library seems to be abandoned and messed up.
> There are tentatives to make it compliant with Python 3, but the code is
> full of errors and they do not accept PRs anymore.
> With the latest versions of GeoServer, we need to update some API calls.
> Moreover, very soon, we will need to make this fundamental library
> compliant with Python 3.
> Probably the easiest way would be to fork this library and create a
> "gsconfig3" or something hosted by the GeoNode github repo.
> Any thoughts? Comments or feedbacks?
> Alessio.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190717/474483bc/attachment-0001.html>
More information about the geonode-users mailing list
