[GeoNode-users] Changing theme of geonode
pierluigi de rosa pierluigi.derosa at gmail.com
Fri Mar 8 05:34:52 PST 2019
Thanks for your answer.
Now it works
Pierluigi
Il giorno ven 8 mar 2019 alle ore 14:29 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi Pierluigi,
> If you installed Geonode usgin the apt-get command, then the file that you
> need to nodify for you index is:
> /usr/local/lib/python2.7/dist-packages/geonode/templates/index.html
> Remember always restart Apache afterwards.
> Kind Regards,
> José
> El El vie, 8 de mar. de 2019 a las 07:23, pierluigi de rosa <
> pierluigi.derosa at gmail.com> escribió:
>> Dear Julierme,
>> I'm modifing this file here:
>> /usr/local/lib/python2.7/dist-packages/geonode/contrib/geosites/site_template/templates/site_index.html
>> But not changes are detected.
>> In my system is the only file I have called site_index.html
>> I'm writing this line:
>> <h1>"Multi.park S.D.I."{% trans "Welcome" %}</h1>
>> But only Welcome appear.
>> Instead I'm able to change the css that in
>> /var/www/geonode/static/geonode/css
>> Thanks
>> Pierluigi
>> Il giorno ven 8 mar 2019 alle ore 13:53 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>> Dear Pierluigi,
>>> I think you need to look over GeoNODE Project as in [1]. And make
>>> changes to site_base.html and site_index.html [2] and site_base.css[3].
>>> [1] https://github.com/GeoNode/geonode-project/tree/master
>>> [2]
>>> https://github.com/GeoNode/geonode-project/tree/master/project_name/templates
>>> [3]
>>> https://github.com/GeoNode/geonode-project/tree/master/project_name/static/css
>>> I hope it helps.
>>> Kind regards
>>> Julierme
>>> On Fri, Mar 8, 2019 at 9:32 AM pierluigi de rosa <
>>> pierluigi.derosa at gmail.com> wrote:
>>>> Dear User,
>>>> I'm trying to change the theme of geonode installation. The
>>>> installation have been done using the quick installation as here [0].
>>>> I need to change some text in the index and following the page [1]
>>>> modifying site_index.html
>>>> Anyway the changes are not detected. I think I'm changing the wrong
>>>> file.
>>>> What is the html file I need to change?
>>>> Thanks
>>>> Pierluigi
>>>> [0]
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html
>>>> [1]
>>>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
>>>> Ing. Pierluigi De Rosa (PhD in Earth Science)
>>>> Contract Professor of Geographic Information System at University of
>>>> Perugia
>>>> cel: 3497558268 / fax: 075 7823038
>>>> skype: pierluigi.derosa
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Perugia
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
Contract Professor of Geographic Information System at University of Perugia
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190308/c9897e14/attachment.html>
More information about the geonode-users mailing list
