[GeoNode-users] Load CVS file.
Yewondwossen Assefa assefay at gmail.com
Fri Mar 29 11:04:15 PDT 2019
Hi Francesco, Ariel
I was under the impression that a csv file could be loaded as a layer.
There was some time ago a discussion on a functionality a to join
geographical files and csv files. After checking in github, I realized that
it is not possible yet.
I will upload it as a document for now and recommend users to do their join
outside Geonode and upload joined shape file.
Many thanks for your support.
Ariel, very nice to hear from you.
Regards
Y. Assefa
On Fri, Mar 29, 2019, 19:21 Francesco Bartoli <xbartolone at gmail.com> wrote:
> Ciao Ariel,
> He was talking to a not-geographical csv so it wouldn’t make sense to
> become a layer imho
> Francesco
> P.S. It is great to have you onboard again
> Il 29 mar 2019, 16:21 +0100, Ariel Nunez <ingenieroariel at gmail.com>, ha
> scritto:
> Fra,
> I think Assefay is referring to having the csv become a Layer. Kind of
> like:
> http://docs.geonode.org/en/master/tutorials/devel/geonode_apis/importer/rest_examples.html#uploading-a-csv-file-to-postgis-while-transforming-it
> -a
> On Fri, Mar 29, 2019 at 9:52 AM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
> Hi,
> You can upload it under documents.
> Hope this helps
> Francesco
> Il 29 mar 2019, 15:36 +0100, Yewondwossen Assefa <assefay at gmail.com>, ha
> scritto:
> Hi Stefan,
> I am talking of non-geographical CSV (just attributes). For geographical
> elements, I always use shape files.
> You mention that It should work with the non-geographical CVS? I get the
> following message: Only Shapefiles, GeoTiffs, and ASCIIs are supported. You
> uploaded a .csv file
> Thanks
> On Fri, Mar 29, 2019 at 5:32 PM Stefan Steiniger <ssteiniger at uc.cl> wrote:
> Hi,
> it depends what type of CSV. That is, you mean a file with point
> coordinates to display it as in a map, or just a spread sheet, as an xls so
> people can download?The latter is no problem, but a "geographical CSV" is.
> stefan
> On Fri, Mar 29, 2019 at 11:11 AM Yewondwossen Assefa <assefay at gmail.com>
> wrote:
> Hi all,
> What would be the way to go to be able to upload CSV file?
> The installation was done using the quick installation.
> I have I tried to set 'BACKEND': 'geonode.importer', in settings.py but
> that did not help.
> Are there other setting I should look for?
> Thanks
> Y. Assefa
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190329/66d2dfab/attachment.html>
More information about the geonode-users mailing list
