[GeoNode-users] Show Layers on Layer view page (Jose Cáceres)
Jose Cáceres jose.atyus at gmail.com
Sun Mar 31 08:10:09 PDT 2019
Hi everyone,
Just as a followed up on my previous issue, I found that
the DEFAULT_MAP_CRS = "EPSG:900913" on my local_settings.py, so I changed
that to "EPSG:3857", also I noticed that the EPSG in which most of my
layers are defined (EPSG:32616) wasn't on the 'SUPPORTED_CRS' list, so I
added that as well.
And now the layers are showing as expected, showing the full extent of each
layer on the preview window.
Thanks to Toni and to everyone else for your help.
Kind regards,
José
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
31/03/19
09:08:36
On Sun, Mar 31, 2019 at 8:31 AM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Jose,
> To update to Master, Do I need another machine or it can be done on the
>> same server? The problem is I just have the one server to get it done,  and
>> is not particular powerful (2 cores, 4GB memory, 60GB on disk).
> I understand your problem with having only one server. For every option I
> can think of this
> guide from Oliver should give you an idea of what to backup first and how:
> https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install
> *A) Backup -> test locally -> reset your VM ->  import / migrate all data
> live again*
> This might be one of the cleanest but also work intense solutions.
>     - Backup your live data
>     - Test the installation/migration locally (you could use vagrant for
> spinning an Ubuntu instance in seconds)
>     - Create a snapshot of your live VM (!!!)
>     - Reset your live instance to a fresh state
>     - Repeat the install with your production VM and migrate/import your
> data as you did locally.
> *B) Use GeoServer and Postgresql install from apt -> manually install the
> core.*
> Again a snapshot gives you safety. Don´t miss to make use of it if you
> can!
>     - Clone geonode-project master branch
> https://github.com/GeoNode/geonode-project
>     - Follow the README to create a virtualenv which will isolate python
> packages from globally installed by apt
>     - Enable the geoserver boilerplate settings file
> https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample
>       and add your credentials/path for PostgreSQL and geoserver.
>     - Update Apache conf that it´s pointing to your new Geonode install
> (backup the conf file!)
>     - Migrate your database as mentioned in Olivier's readme and if needed
> upgrade geoserver to a newer version.
> *C) Install geonode docker -> and migrate your apt setup*
> This might be the most secure solution as you can always easily uninstall
> docker again and restart your
> stack. Be prepared that docker install might need some more knowledge
> regarding its configuration.
>     - Backup all your data,
>     - Shut down the current Postgres, Geoserver, Apache, etc setup
>     - Install the docker stack
>     - Migrate your data and continue using docker
> Find here a good writeup where to start with docker:
> https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY
> (credits: https://geo-solutions.it)
>  I try once before following the instructions provided here
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit for
>> Ubuntu 18.04, but I don't know if this update can be done in Ubuntu 16.04
>> as well.
> For all options you could use Ubuntu Bionic or Xenial.
> With A) and B) the install differs a bit  (different package Versions) but
> the migration steps are the same.
> If you´re familiar with Docker and your server resources suffice I would
> suggest Option C.
> If you new to Docker at all I would go with B)
> ( A) would be the last I would do )
> These are all just rough ideas which might need fine tuning here and there
> but I hope
> you get the ideas. If you need more insights don´t hesitate to ask.
> And,
>      ⚠️ don´t forget backups, backups, backups ;)
> Best regards,
> Toni
> Am 31.03.2019 um 15:08 schrieb Jose Cáceres <jose.atyus at gmail.com>:
> Hi,
> One more thing I forgot to mention, I don't know if is relevant, if I load
> any layers on the geoexplorer client on /maps/new, it does show the extent
> of the layers automatically as I load them, the problem is just on the
> preview of the layer on the /layers/layer_name page.
> Kind regards,
> José
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: jose.atyus at gmail.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190331/d5ab7e61/attachment-0001.html>
More information about the geonode-users mailing list
