[GeoNode-users] (no subject)
Amedeo Fadini amefad at gmail.com
Mon May 6 07:40:53 PDT 2019
Hi Naresh,
Could you please check what values are written in your local_settings.py
for the following variables?
GEOSERVER_LOCATION
GEOSERVER_PUBLIC_LOCATION
The first should be http://localhost:8080/geoserver
The second should be https://<your server>/geoserver
Amedeo
Il giorno lun 6 mag 2019 alle ore 11:11 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear All,
> Please help to enable https for GeoNode
> Please find the details below in which GeoNdde deployed
> *Server OS*: RHEL 7.2
> *GeoNode Version*: 2.4
> *Bits*:64 -bit machine.
> Apache 2.4.6
> Python:2.7.5
> GeoServer :2.7.4
> Tomcat Version:7.0.54
> The following commands executed. (followed from *http://docs.geonode.org/en/2.4.x/tutorials/advanced/geonode_production/ssl.html?highlight=ssl
> <http://docs.geonode.org/en/2.4.x/tutorials/advanced/geonode_production/ssl.html?highlight=ssl>*
> 1. Copied the our SSL key and certificate to the following locations
>    As, We are using WildCard.crt  The following were copied
>     a. SSLcertificateFile  with    Wildcard.crt,
>     b. SSLCertificateKeyFile  with server.key
>     c. SSLCertificateChainFile  with Intermediate.crt
> 2.   Apache Configuration  as mentioned in above , I have modified in our
> geonode.conf file
> 3.  Tomcat Configuration - Edited Server.xml and done required changes
> 4. GeoNode Configuration - Changed Site Url to https
> 5. GeoServer Configuration - Changed web.xml
> After doing above and restarting tomcat,apache site was redirecting to
> https, however when I am uploading data it is showing following error *SSLHandshakeError:
> [SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:765)*
> File "/home/geonode/geonode/layers/views.py", line 171, in layer_upload
> [Mon May 06 10:34:55.699359 2019] [:error] [pid 39822]
>  title=form.cleaned_data["layer_title"],
> [Mon May 06 10:34:55.699361 2019] [:error] [pid 39822]   File
> "/home/geonode/geonode/layers/utils.py", line 470, in file_upload
> [Mon May 06 10:34:55.699363 2019] [:error] [pid 39822]
>  defaults=defaults
> [Mon May 06 10:34:55.699365 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/django/db/models/manager.py", line 154,
> in get_or_create
> [Mon May 06 10:34:55.699368 2019] [:error] [pid 39822]     return
> self.get_queryset().get_or_create(**kwargs)
> [Mon May 06 10:34:55.699370 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/modeltranslation/manager.py", line 341,
> in get_or_create
> [Mon May 06 10:34:55.699372 2019] [:error] [pid 39822]     return
> super(MultilingualQuerySet, self).get_or_create(**kwargs)
> [Mon May 06 10:34:55.699375 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/django/db/models/query.py", line 383, in
> get_or_create
> [Mon May 06 10:34:55.699377 2019] [:error] [pid 39822]
>  obj.save(force_insert=True, using=self.db)
> [Mon May 06 10:34:55.699384 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/polymorphic/polymorphic_model.py", line
> 90, in save
> [Mon May 06 10:34:55.699393 2019] [:error] [pid 39822]     return
> super(PolymorphicModel, self).save(*args, **kwargs)
> [Mon May 06 10:34:55.699395 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/django/db/models/base.py", line 545, in
> save
> [Mon May 06 10:34:55.699397 2019] [:error] [pid 39822]
>  force_update=force_update, update_fields=update_fields)
> [Mon May 06 10:34:55.699399 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/django/db/models/base.py", line 569, in
> save_base
> [Mon May 06 10:34:55.699401 2019] [:error] [pid 39822]
> [Mon May 06 10:34:55.699403 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/django/dispatch/dispatcher.py", line 185,
> in send
> [Mon May 06 10:34:55.699405 2019] [:error] [pid 39822]     response =
> receiver(signal=self, sender=sender, **named)
> [Mon May 06 10:34:55.699407 2019] [:error] [pid 39822]   File
> "/home/geonode/geonode/geoserver/signals.py", line 74, in geoserver_pre_save
> [Mon May 06 10:34:55.699409 2019] [:error] [pid 39822]
>  charset=instance.charset)
> [Mon May 06 10:34:55.699410 2019] [:error] [pid 39822]   File
> "/home/geonode/geonode/geoserver/helpers.py", line 1053, in geoserver_upload
> [Mon May 06 10:34:55.699412 2019] [:error] [pid 39822]     workspace =
> cat.get_default_workspace()
> [Mon May 06 10:34:55.699414 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/geoserver/catalog.py", line 876, in
> [Mon May 06 10:34:55.699416 2019] [:error] [pid 39822]     ws.fetch()
> [Mon May 06 10:34:55.699418 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/geoserver/support.py", line 174, in fetch
> [Mon May 06 10:34:55.699420 2019] [:error] [pid 39822]     self.dom =
> self.catalog.get_xml(self.href)
> [Mon May 06 10:34:55.699425 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/geoserver/catalog.py", line 211, in
> get_xml
> [Mon May 06 10:34:55.699428 2019] [:error] [pid 39822]     response,
> content = self.http.request(rest_url)
> [Mon May 06 10:34:55.699430 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1572, in
> request
> [Mon May 06 10:34:55.699432 2019] [:error] [pid 39822]     (response,
> content) = self._request(conn, authority, uri, request_uri, method, body,
> headers, redirections, cachekey)
> [Mon May 06 10:34:55.699434 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1319, in
> _request
> [Mon May 06 10:34:55.699436 2019] [:error] [pid 39822]     (response,
> content) = self._conn_request(conn, request_uri, method, body, headers)
> [Mon May 06 10:34:55.699438 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1254, in
> _conn_request
> [Mon May 06 10:34:55.699440 2019] [:error] [pid 39822]     conn.connect()
> [Mon May 06 10:34:55.699442 2019] [:error] [pid 39822]   File
> "/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1046, in
> connect
> [Mon May 06 10:34:55.699444 2019] [:error] [pid 39822]     raise
> SSLHandshakeError(e)
> [Mon May 06 10:34:55.699445 2019] [:error] [pid 39822] SSLHandshakeError:
> Please help me to resolve the issue and let me know any other information
> require further.
> Thanks&Regards,
> Naresh.N
> Thanks&Regards,
> Naresh
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190506/459d7959/attachment-0001.html>
More information about the geonode-users mailing list
