[GeoNode-users] Changing Theme for Geonode 2.10
Cliff Patterson cpatterson at psdrcs.com
Wed May 8 10:05:40 PDT 2019
Hi Angelos,
Thanks for your help, but I can't get Geonode-project up and running. I
just get error after error. I am using the instructions on github
https://github.com/GeoNode/geonode-project
For example, when running pip install -r requirements.txt --upgrade:
ERROR: Complete output from command python setup.py egg_info:
    ERROR: Failed `CDLL(libgeos_c.so.1)`
    Failed `CDLL(libgeos_c.so)`
      File "<string>", line 1, in <module>
      File "/tmp/pip-install-UUny1E/Shapely/setup.py", line 38, in <module>
        from shapely._buildcfg import geos_version_string, geos_version, \
      File "shapely/_buildcfg.py", line 167, in <module>
        fallbacks=['libgeos_c.so.1', 'libgeos_c.so'])
      File "shapely/_buildcfg.py", line 161, in load_dll
        libname, fallbacks or []))
    OSError: Could not find library geos_c or load any of its variants
ERROR: Command "python setup.py egg_info" failed with error code 1 in
Error when running: pip install pygdal==$PYGDAL_VERSION
ERROR: Invalid requirement: '.8'
At this point, nothing works... So let's start over.
What is the starting point to install a version of geonode that can be
customized on a fresh installation of Ubuntu 18.04?
Big thanks!
Cliff
On Wed, May 8, 2019 at 5:25 AM Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> Hi,
> Please keep posting to GeoNode mailing list so that others can follow
> and help.
> Since you used the pre-release ppa, only geonode is installed, without a
> geonode-project setup for customization.
> Please have a look here for details:
> Best,
> Angelos
> On 5/8/19 4:05 AM, Cliff Patterson wrote:
> > I was not sure which directory to edit in order to customize the look of
> > geonode (e.g. change logo, menu colour). Ultimately I would like to
> create
> > a theme that I can replicate on several servers, but not sure how to
> > proceed. I installed on Ubuntu 18.04 using the geonode pre-release PPA.
> > With the default settings, there are two "static" directories when I
> search
> > the server for "geonode", one at:
> > /usr/local/lib/python2.7/dist-packages/geonode/static/geonode/
> > And another in the web root:
> > /var/www/geonode/static/geonode
> > I'm not that familiar with Django so really not sure which directory to
> > edit. The docs say "Your GeoNode project has a directory already set up
> for
> > storing your own images at <my_geonode>/static/img
> > ". Where is <my_geonode>?
> > Cheers,
> > Cliff
> > On Tue., May 7, 2019, 5:28 p.m. Angelos Tzotsos, <gcpp.kalxas at gmail.com>
> > wrote:
> >> Hi Cliff,
> >> The documentation seems right. Are you working with a geonode-project or
> >> are you trying to customize the geonode itself?
> >> Cheers,
> >> Angelos
> >> On 5/7/19 11:48 PM, Cliff Patterson wrote:
> >> Are there docs on how to change the geonode theme (e.g. brand logo) when
> >> installing 2.10 from the testing PPA? The instructions here do not seem
> to
> >> be valid:
> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/theme_admin.html#theme-admin
> >> Thanks!
> >> Cliff
> >> _______________________________________________
> >> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://
> lists.osgeo.org/mailman/listinfo/geonode-users
> >> Angelos Tzotsos, PhD
> >> Charter Member
> >> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
> Charter Member
Cliff Patterson Ph.D.
*PSD* | Senior GIS Consultant
P: 519-690-2565 ext. 2565
www.psdrcs.com
London | 148 Fullarton St. 9th Floor
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190508/d4b27a75/attachment.html>
More information about the geonode-users mailing list
