[GeoNode-users] FW: Widget issue
Silvia Salsone salsone at planetek.it
Mon Nov 18 00:45:05 PST 2019
Thank you for helping, Simone, and hi all,
When I read your reply I was pretty sure I didn’t have that button neither for maps. But checking further, I noticed anonymous users don’t have the widget option on existing maps. They need to create their own ones to be able to create widgets but they cannot save them (according to our current permission settings). A registered user can actually create widget on existing maps.
Is this the behaviour you expect?
Thank you very much.
Cheers,
Silvia
From: Simone Giannecchini [mailto:simone.giannecchini at geo-solutions.it]
Sent: sabato 16 novembre 2019 13:21
To: Silvia Salsone <salsone at planetek.it>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Widget issue
Ciao Silvia,
in the current version widgets are available only for maps not on the layer preview.
If this is not your problem then we need more information to understand what is going on.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services<https://gnldr.online/tracker/click?redirect=http%3A%2F%2Fbit.ly%2Fgs-services&dID=1573906802524&linkName=http://bit.ly/gs-services> for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it<https://gnldr.online/tracker/click?redirect=http%3A%2F%2Fwww.geo-solutions.it&dID=1573906802524&linkName=http://www.geo-solutions.it>
http://twitter.com/<https://signtr.online/tracker/click?redirect=http%3A%2F%2Ftwitter.com%2F&dID=1573906835409&linkName=http://twitter.com/>geosolutions_it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Fri, Nov 15, 2019 at 6:22 PM Silvia Salsone <salsone at planetek.it<mailto:salsone at planetek.it>> wrote:
Hi everyone,
We are having an issue with the widgets. We can’t see the widget button, neither in the TOC nor on the menu above the attribute table. Do we need to enable it? Does it appear in specific cases?
Thank you for helping.
Cheers,
Silvia
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191118/7b54e9b7/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191118/7b54e9b7/attachment.jpg>
More information about the geonode-users mailing list
