[GeoNode-users] Trouble executing containers
Francesco Bartoli xbartolone at gmail.com
Fri Nov 22 11:45:35 PST 2019
Did you check if the port 80 is free on your computer? I see you run some commands but  I want to make sure you double check in the right place
Best
Francesco
Il 22 nov 2019, 15:47 +0100, Matheus Ximenes <Matheus.ximenes2016 at outlook.com>, ha scritto:
> Hello everyone,
> When i try to run the containers, whit the following command:
> docker-compose -f docker-compose.yml up -d
> i get the error bellow:
> ERROR: for nginx4my_geonode  Cannot start service geonode: driver failed programming external connectivity on endpoint nginx4my_geonode (199361378a45ea708d42fbfc0139fe8636d310e92872480da02cc107d72cbbf6): Bind for 0.0.0.0:80 failed: port is already allocated
> ERROR: for geonode  Cannot start service geonode: driver failed programming external connectivity on endpoint nginx4my_geonode (199361378a45ea708d42fbfc0139fe8636d310e92872480da02cc107d72cbbf6): Bind for 0.0.0.0:80 failed: port is already allocated
> ERROR: Encountered errors while bringing up the project.
> I already tried use:
> sudo netstat -tlpn | grep 80
> sudo fuser -k 80/tcp
> after all, the error persists. Would be greatfull if anyone could help me
> thank you
> Matheus Ximenes
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191122/3ad5824a/attachment.html>
More information about the geonode-users mailing list
