[GeoNode-users] UNABLE TO LOAD METADATA FROM GEONETWORK
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Oct 25 07:46:54 PDT 2019
Hi XAVIER,
just to be clear, GeoNode won't get anything from GeoNetwork. It will just
add metadata records to GeoNetwork and read them when you ask, from
GeoNode, to download the metadata.
So, if you expect to see the layers configured into GeoNetwork ingested
into GeoNode, this feature is not implemented unfortunately.
Il giorno ven 25 ott 2019 alle ore 09:42 XAVIER RAYO SARRIAS <
xrayo at utm.csic.es> ha scritto:
> Hi all,
> I’ve been trying this for a few weeks with no success.
> We have server with *geonetwork* already running and with many metadata
> on it.
> Now I have installed *geonode* and uploaded some data which I would like
> to merge with the metadata.
> I have followed the instructions here :
> http://docs.geonode.org/en/2.8.1/tutorials/admin/csw_settings/index.html modifying
> the settings.py file pointing it to our geonetwork server:
> *# CSW settings*
> *CATALOGUE = {*
> *    'default': {*
> *        # The underlying CSW implementation*
> *        # default is pycsw in local mode (tied directly to GeoNode Django
> DB)*
> *        #'ENGINE': 'geonode.catalogue.backends.pycsw_local',*
> *        # pycsw in non-local mode*
> *        # 'ENGINE': 'geonode.catalogue.backends.pycsw_http',*
> *        # GeoNetwork opensource*
> *         'ENGINE': 'geonode.catalogue.backends.geonetwork',*
> *        # deegree and others*
> *        # 'ENGINE': 'geonode.catalogue.backends.generic',*
> *        # The FULLY QUALIFIED base url to the CSW instance for this
> GeoNode*
> *        #'URL': urljoin(SITEURL, '/catalogue/csw'),*
> *         'URL': 'http://myserver/geonetwork/srv/en/csw
> <http://myserver/geonetwork/srv/en/csw>',*
> *        # 'URL': 'http://localhost:8080/deegree-csw-demo-3.0.4/services
> <http://localhost:8080/deegree-csw-demo-3.0.4/services>',*
> *        # login credentials (for GeoNetwork)*
> *         'USER': ‘admin',*
> *         'PASSWORD': ‘mypassword',*
> *        # 'ALTERNATES_ONLY': True,*
> Am I doing something wrong or missing something?
> What should I do to connect my geonode layers to use the metadata from our
> geonetwork server?
> Thank very much for your help!
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191025/1dd51f72/attachment-0001.html>
More information about the geonode-users mailing list
